Everything posted by garypl
Thanks Colt - look forward to seeing your pics of thread path! Gary
Colt - are you using regular bonded nylon thread? I have a lube pot, but have not used it. How did you route the thread through the pot without increasing the tension excessively? Do you see any benefit to using the lube pot unless you are sewing materials other than veg tan? Gary
Alligator wallet
garypl replied to Prestige593's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Both look nice, bit l’ll have to agree with Mutt that black is the real thing! Gary -
Email the pictures to yourself and this should reduce the size so you can post them here. Gary
I bought a roll of brown paper at Lowe’s for about $15 - it is 36” wide and there is quite a bit on the roll. It feels about the same as paper grocery bags, but a little thinner. I tear off a piece that is @15” long x 36” wide, fold it in half and use it to cover my granite surface while gluing and staining. When it gets nasty I flip it over to the clean side and depending on how bad it is I can sometimes turn it inside out and use it again. Gary
Gun scabbard
garypl replied to barbedwireboutique's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice job! What type leather and finish did you use? Gary -
Exactly!
As I approach the corner and I see my stitch will be too far ahead of the corner, I slowly move the stitch lever toward reverse, but not all the way . You will see the foot move to the rear a bit - turn the fly wheel by hand and watch the tip of the needle. When you are close to the surface, do the final adjustment and then push the needle into the leather. Once it is set, you can go the rest of the way down and then lift the presser feet and rotate the leather 90 degrees. Gary mark a spot on a practice piece and sew to the spot, adjusting at the very end so you hit the spot dead on...
Yippi - are you referring to the locking set screw on the bobbin case that keeps the bobbin tension screw from moving? Gary
Thanks Tom - I will try adjusting the stitch length by hand - might be easier than fooling with the stitch length adjuster. Gary
I don’t know if I am doing it correctly or if this is what everyone means by handstretching the stitch, but I use the stitch length adjustment to position the stitch so it hits the point. Is this what you are referring to? Gary
I buy from Ohio Travel Bag. Here is a link to one of the clips they sell: https://ohiotravelbag.com/products/item/c02c7af2-f38d-46a9-8deb-e4455ac51def/P-2326 Better to find a supplier nearer to you, but this is one resource. They do ship internationally. Good luck! Gary
Looks well made and should give your friend many years of service! Gary
Welcome Winn! Nice job on the sheath. Please let us know construction details, I.e., type and weight of the leather, thread size, finish used, etc. Gary
Very nice work there Wedgetail. Clean lines! Gary
Ross, that’s exactly the same reason I was happy to find a circle template - always looking for lids to use to draw circles!
I saw the Windfire circle templates in this forum some time ago and they look really wel made, but oh they are pricey. I see how you can draw concentric circles by moving up or down one size, but how does it work when you have to skip a size or two? Nice feature is that you can probably cut leather using the template- can’t do that with the plastic model I bought. I figured for under $3 the plastic model would be worth a try and it seems to work quite well. Gary
Finish/dye background
garypl replied to D2G's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
If you want to just darken the background behind a raised carving, you can use dye or leather paint. I have used both with good results. Apply with a brush or for paint I use a small bottle with needle tip to get up close around the carving. Gary -
When I handsew gussets I simply mark stitch lines on both pieces, then layout the holes with either an overstitcher, pricking chisel, or sometimes I just run the pieces through my unthreaded machine. Now you have two pieces of leather with holes spaced identically and the same distance from the edge. I don’t glue the gussets - just saddle stitch, so it’s easy to push the awl through the first hole, look for the second hole and slip the awl through, then use your needles. Works great! Gary
I’m planning a design that calls for concentric circles to create a border. I’ve been trying to figure out the best way to draw them. Went to Hobby Lobby today and while browsing around I found this circle drawing device that allows you to draw concentric circles up to 4” in diameter. Simply position the template, put a stylus in one of the holes and rotate the inner template. Move the stylus to another hole and draw another circle concentric with the first - simple and easy to get perfect results. With discount coupons I think the cost was about $2.80! Gary
Thanks for posting this link Floyd - this is a very clear manual for the 441 machine! Gary
My CB4500 stand looks identical to Forester's
From what I remember, if 51% or more of the product value is from parts and labor from the USA, you can consider it made in the USA for export purposes. Gary
