Everything posted by garypl
I don't have that many patterns to worry about, but you should be able to scan the patterns at 100% to get them in digital format - put some index marks on them to check the scale (If you make two marks a couple of inches apart and mark the distance between them, when you print them back out you can measure the printout to ensure the scale has not changed. If they are too large for your scanner, take them to a print shop - they should have a large scanner that will work. Then you can store the digital files online and on your computer. Gary
Sheath for a Leatherman
garypl replied to MacB's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Nice work!- 14 replies
- sheath
- leatherman
(and 1 more)
Thread brand general questions....
garypl replied to SamuelBrand's topic in Leatherwork Conversation
I have only bought bonded nylon thread from Toledo Sewing (see banner ads) and I have had no problem and have not tried to buy elsewhere. If it's not broke I don't try to fix it! Gary -
No idea what I'm doing, but happy to be here!
garypl replied to JiffyJones's topic in Member Gallery
That is a very cool bag front! Can't wait to see it finished and painted! Concerning the finish, I recommend you take some scraps of this leather and experiment with different waxes/finishes to see how they wlil affect the color. Then you can apply to your project. Gary -
Ross - that makes sense now - what confused me was the holes cut into the wood boards - I guess they are just to make it easier to grab the dies. Thanks for the explanation! Gary
Long Wallet
garypl replied to DarkGoku's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Don't feel lonesome! Edge finishing is often a frustrating effort for me too!- 7 replies
- leather wallet
- cowboy wallet
(and 2 more)
I guess I'm not certain what the wood is used for - I always thought clicker dies were just metal that you put on top of the leather. Does the wood allow for more even pressure underneath the press? Gary
My quick draw knife sheath pattern
garypl replied to builderofstuff's topic in Patterns and Templates
So you unlock the knife, carefully insert the tip and it automatically contacts the two rivets which guide the blade back up. Seems like it would require more space inside the sheath to do this, but it works, so must be something you need to try to really see how it works!- 15 replies
- quick draw
- knife sheath
(and 1 more)
Hey Ross - how are all the wooden forms used? Gary
Hi Chris - I saw this when you originally posted it in 2016, but I still cannot figure out how you reinsert the knife into the sheath so the tip if the blade catches the upper rivet! What is the sequence to properly resheath the knife? Nice design! Gary- 15 replies
- quick draw
- knife sheath
(and 1 more)
Long Wallet
That's a great looking wallet! Stamping looks very good. The only comment I have is that the edges look like they could have been sanded/finished a bit more. Nice work! Gary- 7 replies
- leather wallet
- cowboy wallet
(and 2 more)
When you buy leather you normally select the thickness you want. If you request a thinner piece, let's say from Wickett & Craig, and you have to have it split down from a thicker piece - you pay the same price as you would buying the hide unsplit. At least that's been my experience. Gary
My workbench / shop has never ever looked so neat!
When it all works out ...
garypl replied to Brooks125's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I sometimes use a vacuum press for small items - I use my seal a meal vacuum and as long as the item fits in the small bags it does a good job! I put a smooth piece of thin wood under the leather to prevent the diamond pattern from the back side of the bag from imprinting on the leather. Those shop presses I think are only recommended when you are using blue guns - am I correct? I don't think I would be comfortable putting a real gun under that much pressure. Gary -
Cross Draw Holster
garypl replied to Firewalker's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Now that I took a closer look I do see that the stitching doesn't go all the way around the toe! Good point about the rear sight - you could also mold the leather a bit around the cylinder to keep the revolver from going too deep in the holster. That's what I like about leather working - so many different ways to do things and I am always learning! Gary- 8 replies
- .454 casull
- punisher
(and 2 more)
Beautiful holster! I really like the contrasting colors. Gary
Brooks, that is some very tight molding! Did you vacuum form it or do it by hand? I am always curious to learn what type leather, finish, thread is used to give me a better idea what works best. Nice job! Gary -
Cross Draw Holster
Scott, that’s a cool looking holster! Do you always use a closed toe design or do you switch between open and closed? I prefer the open design, but I have made them both ways. Gary- 8 replies
- .454 casull
- punisher
(and 2 more)
Ross, my brain can’t process that stamp design! I kind of see what you are referring to, but I don’t think I could do it! That deerskins lining must make for a nice snug fit. Is it glued to the back side of the front panel? Again, nice job! Gary
Set of Beer Growlers
garypl replied to garypl's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thanks Ross - wish the carving was a little more visible on the darker case - light has to be shining right on it to see it well. -
Thanks Kiwi - My wife just wrapped them up - we are exchanging Christmas gifts late this year due to a death in the family. I will take a picture on Saturday when they are opened! -
Hey Ross - nice job on the sheath. What weight leather did you use? Also curious about the step between the hilt and the carved front of the sheath - what is the purpose of this? That’s a nice looking stamp design, how did you stamp it? First column up the middle and stamp to the right and left or did you start on one side and make your way over to the opposite side? Only critique is that the center arrowhead stamps are cut off a bit just before they reach the retaining strap. Gary
Field notes cover
garypl replied to Fire88's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I like it! Nice job on the cover design. Gary -
Thanks Mutt! I am sure there are folks who prefer your design over mine. I appreciate your comment but I think you would be able to sell a lot more using your design because it is more suitable for production! Gary -
Finally finished a set of beer growlers for my sons. Made of 4-5 oz veg tan and trim is upholster leather. One handle is made from a crocodile belt I bought 30 years ago - it must have shrunk because it is too small for me now! Bottle is supported by two straps that criss cross and go up the sides of the main body. Finished inside and out with my homemade leather balm made of beeswax, carnuba wax, NFO and lanolin. Outside was also given a coat of Atom Wax. Gary
