DJole
Everything posted by DJole
  1. Another work in progress For doing HEMA (Historical European Martial Arts), a basic fencing mask is a good start, but they're not really enough protection for using steel in tournaments. Thus, there are mask overlays on the market, which add padding and protection to your head (a good thing to do!). I decided that I could make my own custom overlay, using leather to add the rigid or semi-rigid "plating" to the mask. These are the first two pieces. (I'll add others as I complete them.) The larger one goes on the forehead, a place which sees a lot of sword strikes. It will get some foam padding underneath it later on. The smaller one goes under the chin, and it will hold an additional throat protector that goes over the mask bib. That protector bit will be riveted to the strip of leather Using a fencing mask, I made a pattern from paper to get the curves right, then cut them out of leather. The border is done with a Tandy stamp, a Christmas gift (Craftool Pro Stamp-Border D2171) from their recent sale. I sewed both pieces together using my new stitching pony (brought back from Korea). The seam is left standing up, for more reinforcement. I got them nice and wet, then molded them to the fencing mask itself, strapping them down to hold shape as they dried. I used a block-out resist for the big inside panels, and a Tandy Antique Black for the border itself. The edges were burnished with water. I may use an edge paint, but I haven't decided yet. I left the leather a natural color-- it's a nice contrast. I then riveted the strip to the chin piece, and wet-molded that to shape. I have the patterns for the throat plate, but I haven't completed that part yet. I'm really pleased with the way they look so far (and they're really nice on the mask itself-- but no pictures of that yet!) to be completed: 1) Create and attach throat plates (probably leather articulation). 2) Finish design for sides and top of mask, create the same. 3) mount all pieces so they strap tightly on. 4) add foam padding 5) make back of head panel.
  2. This is a work in progress. I'm making a piece of throat /neck armor called a gorget. I have a metal one, but I wanted to see if I could do one out of leather that would be rigid enough for use in some sword combat arts (i.e. rapier fencing or HEMA longsword, but not SCA rattan.) So, here's a test of the concept of cuir bouilli. I spent a LOT of time doing Google research and reading a few sets of instructions. Testing this thick leather, I found that immersing it in 180 degree (Farenheit) water for about 20-30 seconds seemed to be right. I am not sure that belly leather, which is what I am using here, is the best thing for this project, since some pieces still seemed less rigid than I wanted. Yet after re-boiling them, I ran into the problem of the leather getting brittle. I don't recommend trying to re-boil the pieces if they don't seem rigid enough. One problem is shrinkage and warping -- to really get this right, I need a frame or mold for each piece. I did end up using my metal gorget to shape part of it (after wrapping it in plastic to keep wet leather off), which helped. I decided to attach the neck pieces to the front and back shoulder pieces using tabs (as visible in the Side picture)and brass rivets. I wouldn't recommend doing it -- the tabs get really think and hard when the leather is boiled. I didn't boil the tabs for the front piece, which made them easier. But next time, I'll just use a piece of leather to attach the two pieces together. The front piece (with the decorated panel) is two pieces. The decorated panel holds the pieces together, and acts as a reinforcement. Things to complete: (1) line the flesh side and add a small bit of padding for comfort, clear up raw edges. (2) add "blade trap" strip to the front piece. (3) decide how to strap them together into one unit. (4) apply final layer of finish to everything. Dyes used: Angelus Wine Tone for shoulder pieces, Angelus Lt. Brown for throat pieces.
  3. I have used Eco-flow on some things, and I find that the colors are not as intense as spirit dye colors (Fiebings, Angelus, etc.) Also, since they are water based, they will bleed color unless you really cover them well with a water-proof finish of some sort. (I only keep some around for use by the occasional Boy Scout troop demo and so on. ) However, I have never used them on an edge, so I can't tell you how they would hold up for that.
  4. That is lovely work (even though I don't really care for the traditional Western floral style)! A nicely balanced design that flows with the boot, with solid tooling work, and the great idea of the heart-shaped pull-on holes! The matching belt is a wonderful addition to the ensemble.
  5. Were you able to locate the part? (If you did find it, what is it actually called?)
  6. Holy smokes! At that price?! I hope it goes to some working leather person rather than just an antique collector.
  7. Well, that's a nice use of an old couch! It's certainly a quirky piece! Yes, you really do seem to love those copper rivets! That bag won't be passing silently through any metal detectors! ;-) (did you know those rivets come in brass, too? and other colors of metal?)
  8. That doesn't look like a domed (i.e. half dome) rivet. There seems to be 3/4 of a circle there, almost like the top of a stud. It seems to be in the middle of a rectangular plate of some sort, which is raised up. That also says, to me, that it is not a domed rivet. Maybe a query to Ohio Travel Bag? Ask the hardware retailers (NOTE-- I do not work for them, but I have bought hardware from them before): Ohio Travel Bag 6481 Davis Industrial Parkway Solon, Ohio 44139-3547 Phone: 800-800-1941 / 440-498-1955 Fax: 800-989-5559 / 440-498-9811info@ohiotravelbag.com Normal hours of operation: 8:00am - 5:00pm Eastern Monday - Friday
  9. The stem (or stems) are too thick for this design. If you are going for a naturalistic look, they are way too thick. If you are going for a more abstract look, then the flowers and leaves are wrong for that (since they are trying to be naturalistic.) So what you have there is two clashing design philosophies. Also, I think you tried to do flower buds, but they look like leaves unless you look at them very carefully. Again, it's a question of abstract or realistic. Your composition isn't bad here, but I think you have a lot more open space (especially on the left side) than most floral carving tends to have, so it looks "unfinished." Flowers are surprisingly difficult to do! That must be why I myself don't really do floral designs. (I've tried it only once, as a panel for a pair of decorated fencing gloves.)
  10. Wow, that is stellar work. Those are lovely!
  11. Wonderful story! And a nice bag, too. Love the "retro" design!
  12. Ooh...purty. Is that some walnut I see there? What an interesting design. I'm sure you'll keep us posted about how much fun you're having working it all out!
  13. DJole
    Single-stick guard
    Beautiful work! Too lovely to smack with a stick!
  14. Welcome! If you're making bags, you should go spend some time viewing the video instructions at Leodis Leather, provided by Ian Atkinson over in the UK. He walks you through some of the processes and planning, and you might find it helpful! Here is his website: http://ianatkinson.net/leather/videos.htm (Make sure you look at the whole page, not just the top. His longer videos are near the bottom).
  15. Oh, I am sorry -- I didn't realize you were not in the USA. Hopefully some of the European forum members can see your posting and have some answers for you.
  16. Try asking Ohio Travel Bag; they have a LOT of hardware of this type. I have no connection with them other than buying some of their products a few times. Contact them here: Ohio Travel Bag6481 Davis Industrial ParkwaySolon, Ohio 44139 Phone: 800-800-1941 / 440-498-1955 Fax: 800-989-5559 / 440-498-9811 E-mail: info@ohiotravelbag.com Open: 8:00am-5:00pm Eastern Mon-Fri
  17. Never seen that before. I look forward to finding out who has the scoop on this.
  18. The secret to this might be leather articulation. Take a look at this article discussing a historical gorget (throat armor) and look at the picture noting the leather straps which link up the articulating plates: <http://www.ageofarmour.com/education/gorget.html> The plates are riveted to the straps in such a way that the plates can move, but not too far. This might be the solution. I have a back-of-the head protection piece on a fencing mask (used for nylon sword play, HEMA variety) which is made of leather, with lower lames articulated this way. They hang extended, suspended from the leather articulation straps, but they can also compress into nested lames, which is similar to what you want these to do here. Then again, it might be a LOT more simple to just make a coat of plates, using leather as the plates. Just Google search for "coat of Plates" or "corrazina armor" and see if that would work. I love the looks of the corrazina armors, myself.
  19. Making your own baseball glove --- now that's an unusual project! I know nothing about them, so unfortunately I can't contribute anything to the conversation. It would certainly be interesting to see, though! Imagine the custom leather, the tooling, and so on. It would be quite the showpiece.
  20. How exciting! Don't you love the smell and feel of those new tools? You just pick them up and immediately start looking around for a piece of leather to stick them into... ;-)
  21. Try an image search for Holly with berries clipart, if you didn't already do that.
  22. Showed up in my Facebook feed, for some reason-- From the Website (https://www.estatesales.net/TX/Schertz/78154/1729887): Lot of photos of walls and racks of tools inside those barns. I saw some metal shoe-repair lasts, a bunch of anvils, stirrups, bits (for reins). No smaller leather tools are clearly visible in the photos (like photo 17 of 36). For non-leather stuff: lots of saws and block planes, hammers, axes and mallets, ice tongs, ice saws, and who knows what else is there for antique tools.
  23. Yes, they'll be beautiful for the wrist straps. My stitching chisels were a lovely Christmas gift.
  24. I wonder if these angled chisels will do what you want them to. They lay stitches out in the traditional slanted stitch for two pieces of leather on top of each other. Does the baseball or exterior X stitch, which are basically edge to edge, work okay with those slanted stitch holes, or will it look strange?
  25. Very good tips up there, Zuludog. I just wanted to add that it is possible to get 3 prong chisels. My Leathercraft.JP set (http://goodsjapan.com/pricking-irons--stitch-punches-30-c.asp) in 3 mm pitch contains a 3 prong chisel (among others).
