Everything posted by DJole
That's a nice "soft" impression on the design. It almost makes me want to touch it to check if the texture matches what my eyes are seeing.
Yes, there's the big takeaway -- there's so many puzzles to solve that teach us how to work with the material. The finished piece is very attractive -- a unique bag that should last for years!
- 10 replies
- duffle bag
- finish project
(and 1 more)
Heh! I got a nice piece of polished granite countertop (13X9X1") the same way! It has a projecting bit where it was broken, but I can use that kind of like an anvil horn. Yours is all nice and smooth and square...but mine was free just like yours! I'm still holding out for some lovely white marble..
That's a really eye-catching piece of work! I like the personalized touch of the antler buttons,an
Is that the Klingon empire symbol on that axe sheath? You have some nice smooth quality work here.
First (posted) Project
DJole replied to mikesherman's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Would an antique style stain help pop the tooling visually?- 12 replies
Wallet and watch strap
DJole replied to Petewon's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Lovely work -- so clean and crisp! Is that the color of the leather or did you dye it? (If you dyed it, what was the brand and color?)- 19 replies
- watchstrap
- strap
(and 2 more)
If I were young and single, able to pack up and move to a more expensive area, and didn't have a family to support, I'd take a serious look at that apprentice offer. I guess it's difficult to find that young rootless person who is also a leatherworker, or not going to college instead! Paging Mike Rowe... Mike Rowe, to the courtesy desk please...
- 19 replies
- leather workshop
- workshop
(and 2 more)
That's a nice little corner back there, with some spiffy machines!
- 19 replies
- leather workshop
- workshop
(and 2 more)
Are you looking at learning decorative tooling, specifically? You can make wallets without that kind of tooling, so it's unclear exactly what you are looking for. There will be some overlap in the tool set, but if you aren't interested in learning tooling then there are many tools you don't need to get. If you are just starting, you might find Ian Atkinson's YouTube channel is like having a personal teacher right there in your home. Look here for a list (including wallet making videos):https://www.youtube.com/results?search_query=leodis+leather+wallet
Hey, a personalized gift from her dad -- that's a nice touch regardless of your critical eye! Good on you for not feeling intimidated by some of the amazing craftspeople on this site and posting your work.
Linen and Leather
DJole replied to Grey Drakkon's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
That looks like a nice beginner project, if they tool the base. -
Recommended figure carving tools? (and color question)
DJole replied to caitobrien519's topic in How Do I Do That?
Yes, you are right -- your leather may indeed have been too wet when you tried to use the beveller on it. There are a lot of threads on this forum about casing leather and figuring out when it's right for tooling. You should experiment with different cut depths, depending on the thickness (the weight) of the leather and the design, to see what works best. Cova color is an acrylic paint, which is water based. What you were talking about earlier is a water based dye (the Eco-Flo yellow). A dye permeates the material underneath its surface. The water or alcohol or oil (depending on the dye type) seeps into the leather, and then the liquid evaporates, leaving the pigment behind, below the surface of the leather, where it can't rub off. Paint merely adheres to the surface of the leather. When acrylic paint is applied, the water evaporates, leaving the plastic pigment on the surface of the leather, where it can be rubbed off over time. So to answer your question, acrylic paint is water based, and coats the surface of your leather. You put a few coats of paint on the leather (letting them dry in between) until you get the color strength you want, and then you use some sort of finish to protect the paint. Cova acrylic should work just fine. And if it rubs off over time, you can re-paint it.- 20 replies
- paint over dye
- figure carving
(and 2 more)
Looking at the bottom right star, I think you are holding your bevel at too sharp of an angle. It looks like you are just widening the cut line, with not much of a bevel. Instead, the beveling tool should be flatter, so it creates a more gradual slope away from the cut, giving the star a "raised" appearance. If you have a modeling spoon, you can smooth those cut edges, and you can use it to smooth the beveled surface as well.- 20 replies
- paint over dye
- figure carving
(and 2 more)
Very many people on this board dislike the Eco-flo (water-based) dyes. Those water-based dyes don't hold their color like the spirit dyes do. You should definitely use your tooling test scraps to also test dyes. I wonder if perhaps you wouldn't rather use yellow acrylic paint instead of yellow dye, to get a brighter yellow?- 20 replies
- paint over dye
- figure carving
(and 2 more)
That needs a HazMat team for disposal... Poor cowhide...;-(
I used an xacto blade when I was first starting. It worked okay, but the swivel knife is the right tool for the job. It makes better curves since it's easier to control (it's short and built to swivel, whereas my xacto knife is long and doesn't pivot the same way). Line depth is a lot more problematic with the xacto, also. The swivel knife does make wider lines, which certainly makes some modeling techniques work better, as others have mentioned here. So,yeah, you can "get by" with the xacto, but if you really want to see improvement, get a good swivel knife, learn to sharpen and strop it, case your leather properly, and then learn to cut those swoopy, curvy lines they are so good for. Some day I might even decide to spend the money to get a really nice one. A modeling tool is a good idea, too, as fredk mentioned above. The one I have used for years mostly is a "spoon" on one end and a pointy stick on the other. I rarely use a ball end, although I have one. Here is what mine looks like-- it's the top one of the three pictured below. :
That's looking so much better! You're getting the idea of the tools and how they work. It's too bad that you started out with the wrong kind of leather. It must have been incredibly frustrating trying to figure out why it wasn't working right. Now it's just the "easy" matter of mastering the knife to create the smooth curved lines you want. That takes time, and a good knife with a sharp blade. It can be frustrating to know what you want, but not be able to get that look yet.
Welcome, Jools! I see that another person has succumbed to the siren call of leatherwork -- today, a swivel knife...tomorrow....400 tools all over the workshop and 4 different hides, and a stitching machine! Don't give in! Be strong!
That is spectacular work! Only one problem -- WE NEED CLOSEUPS of the awesomeness! ;-) A great design with a high level of skill in execution, nice colors-- masterful work.
First Project in a while
DJole replied to 65frank's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nice work! The floral style isn't my thing, but that's a pretty good job there. -
You say that like it's a bad thing! ;-)
- 2 replies
- watch strap
- hardware
(and 1 more)
I had a watch strap spring pin disappear this past weekend, so I need to replace it. I discovered that Amazon had a humongous assortment, about 500 times more pins than I actually needed, for about the same price I could actually purchase the needed pins: https://www.amazon.com/gp/product/B01CFVUASS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 With that many pins in hand, I might have to start making a bunch of watch straps! I can have a new strap for every day of the month! Maybe others will find this information timely and useful.
- 2 replies
- watch strap
- hardware
(and 1 more)
First post
DJole replied to churchjw's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
That's a very clever design, working the straps in like that! I think that if you did another one of these, you might consider changing the design a bit. In the gears which have cut-outs, you beveled the edges of the cut-out spaces. I took your original graphic and marked the areas I mean with gray circles (since a picture's worth 1000 words, in this case) in the graphic below. I think you should flatten the whole space, rather than merely bevel the edges. That would "sell" the 3-D gears a bit more.
