CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. Yes,it was a spring loaded foot that walks back with the feed dog & then the spring piushed it forward as the needle pulls out of the material. It should sew over 20 oz of leather 5/16" depending on the leather. Yes,you can put a servo on it. We do stock a lot of parts for it too.
  2. I did similar to what Dwight.I built a 30x56 building w/large rollup door on leftside,small 36"door on right w/one window on the front & 2-on the sides & built a 14x40 shop inside of it w/6"insulation on top & 4"sidewalls,I have a gas furnace(50,000 btu) in it,but this winter I put a small electric(look like a radiator heater) set it on low & it keeps the chill off & prevents condensation.What's nice is the storage on the top of the room.Oh,and I put a sliding door on the side 7'x8' in case I want to work on a car.
  3. Some leathers do this more than others & a smaller needle & thread would make it look better since it will slice through with less force.
  4. Wiz,I hate to hijack this thread but since needles came up I been meaning to ask how you like those 135x16 S points I sent you? I think the stich would look real nice on wallets?
  5. You can loosen the pressure on the foot & buff(sand) the feed dog,a smaller pulley will help slow it down.Here's a needle & thread charthttp://www.tolindsewmach.com/thread-chart.html
  6. Are you sure your going around the 2nd tension on the side 1& 1/2x?
  7. Maybe I should of added to just put it in the bearing or bearings that might be gummed up as it will dissolve the old oil.
  8. Some WD40 or some other type of penetrate will or should cut through the old oil,then use regular sewing machine oil after that.
  9. Oil all the way around the groove the bobbincase sets in,then you should be able to turn it counter-clockwise to get the thread out,once in a while you can use a screwdriver & tap on the tab lightly to break it loose,(counter-clockwise only).
  10. Here's a manual for a Singer 29K70 which operates the same,we do stock all the needles,bobbins,parts & thread for this machine. http://parts.singerco.com/IPinstManuals/29K70.pdf
  11. To adjust the foot timing adjust the cam on the top shaft behind the slotted adjuster.You have to loosen the 2-screws(leave one snug so it doesn't spin) rotate until it's feeding correctly with the inside foot coming down & touch the leather as the needle goes in it.
  12. People don't seem to be collecting them like they used to & I would estimate if the cabinet is real nice you MIGHT be lucky to get $150.00 usually $50-75.00 for average condition.
  13. The wick your talking about is for thread lube,which you probably don't need unless your sewing real fast & or heavy material. Here's a operators manual for your machine. Singer 211 Operators Guide-Small.pdf
  14. There's locknut(ring) for when you adjust the foot pressure,loosen that & see what happens.Also have you ever taken the side cover off & oil everything in there including the top & lower part of this bar?
  15. It should bring around $1,000.00,there's not much to go wrong other than getting broken in shipment.The blade will need to be sharpened ,oil it up & split away!
  16. Hey Ken,I'm glad that you didn't have to make the trip too!
  17. @bikermutt07Your Welcome, do you want to be the first guy in LA that bought one?
  18. Your Welcome & if your ever in the neighborhood stop in we have a lot of New & Old machines,thread & etc to look at.
  19. Ok,the sizes they have are 3/32,1/8,5/32,3/16,1/4,5/16 & 3/8
  20. What size do you need? On Superior's page#434 is all the different gauges sizes you can get w/o going to get it custom made.You or we order plate & matching feed then order the needlebar & foot from the 112w page. I don't know of any other machine parts that will fit.
  21. Supposed to be some coming in June.
  22. If she buys that set,she'll need to get a needlebar as that needlebar chuck won't work on her Singer.
  23. Marko, You might want to edit your title line on the ad to read Model # 4500. Sorry to hear your selling it ,but good luck with the sale. Bob Kovar
  24. The end of the bracket is supposed to push on the rod,it's probably broken off it the rod doesn't move when you lift the foot.It isn't the easiest part to replace because you have to pull the pressure bar up past where the spring is.
  25. Is the feed dog coming above the needle plate as the needle & inside foot move back?
