Everything posted by chuck123wapati
Leather for dog leash
chuck123wapati replied to Epplers's topic in Collars, Cuffs, Leashes and Leads
that should easily work for your dog. I make mine 3/4" and 4mm for American Bullies they weigh about a 130 lbs. and pull like the dickens. I've owned a husky also and they don't pull near as hard. -
i would charge $225 and sell it to the next guy. Custom leather isn't for cheap thinking folks and you will never change their minds so don't underprice your self on their account or you will go broke.
I'm glad your a show off, you make some nice stuff and i like to see it.
dish soap and water, wash, rinse until clean and then shape with your spit, let dry.
spring flowers and good food
chuck123wapati replied to chuck123wapati's topic in All About Us and Off Topic
bout shot coffee out my nose. -
That will last about two years, I don't drink as much as i use cooking but i had to have a glass, a good cook always tastes their work you know. Cooked out doors for the first time of the year yesterday, hamburgers over an open fire and fresh homemade buns you just cant beat that smoky flavor lol. I'll be firing up the tiller today, mama wants a big garden this year so its time to get to work no more of the easy leather work for a week or so. Then i have to fix the front end on my truck, i busted two u joints on the front axles ruining both inner axles in the process so there is some money out the window i couldn't afford to lose and a lot of work to totally rebuild of the front differential. I built the pistol form a kit many years ago, basically just did the fitting and wood work but it shoots well and I'm deciding on how to carry it in my possibles bag or not, I usually just stick it in my belt like the pirates did. -
oh ok i get it thanks.
Spring is sprung the huge drifts have been replaced with light skiffs in the morning lol. Took the day off today to rack up last falls wine 5 gallons, It is Chokecherry, Service berry, two local native fruit trees. They make an awesome dark red semi sweet wine that is just fruity and good we go pick them in late summer. then i freeze them until i can make it in the fall. Makes an awesome Sangria and Damn good when used in my marinara sauce and Italian cooking too. lol. -
Stain, resist, different stain, resolene?
chuck123wapati replied to Frodo's topic in How Do I Do That?
very cool Frodo !! I cant wait to see what you come up with. -
I would lose the rivets too, deeper and one piece for sure if possible. But ask your stepson first how he would like it, he's been carrying it and knows what it needs and where it needs to be. I'm no electrician but i have carried a lot of tools on belts, they need to be where they always are so you can find them way up on your ladder with one hand, he may not want to re learn that. But make it purdy so his friends'll want one too.
what tools ? knives , mauls, stamps? are you going to sell them or just use them for bling on your channel?
Red Wing Black Bird Buckle
chuck123wapati replied to Stewart's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
wowzers man that is nice! -
YOUR iron will totally rust away long before you would ever need to fill that bottle 9 more times. your math is great no doubt but what about the other 95% of the liquid in the bottle called water ? the another variable for you to figure out as the water is also acting to dissolve the iron and it is also holding the iron in suspension also. Your making this way to hard, The vinegar is only used to hasten the iron oxidizing away if it mixes that doesn't matter. its the quantity of iron to the tannic acid that makes the leather black. Vinegar has nothing to do with that process so it doesnt matter about how the iron and vinegar attach to each other because thats not what makes leather black.. The reaction between the iron and the tannic acid in the leather is what makes leather black not vinegar Here is how i would get the info you want. you would need several samples (10 at least in glass jars with lids) all weighed exactly and large enough to get a measurable variance of numbers, each day or time period you designate take one sample weigh it, subtract from the original weight to find loss from evap and gassing off , take out the steel wool dry it and then weigh it. from that you can find out how much iron you have left, you can also find out how much liquid you have left, percentage of steel wool in suspension etc. you can also test the solution ( timed dip test test and total immersion) at the same time on leather that has been tested for PH to see and verify actual visual results. you could also test different leathers with varying ph levels during your study.
So in essence you wont know any more than when you started. you would need several samples (10 at least in glass jars with lids) all weighed exactly and large enough to get a measurable variance of numbers, each day or time period you designate take one sample weigh it, subtract from the original weight to find loss from evap and gassing off , take out the steel wool dry it and then weigh it. from that you can find out how much iron you have left, you can also find out how much liquid you have left, percentage of steel wool in suspension etc. you can also test the solution ( timed dip test test and total immersion) at the same time on leather that has been tested for PH to see and verify actual visual results. you could also test different leathers with varying ph levels during your study. FUN FACT ==== when drying your steel wool, to find out if it is indeed 100 % dry lay a small scrap of paper on top of it, if the paper curls up the steel wool is still wet and is giving off vapors that affect the paper. Don't know your age or education level or any of that but speriments like this was about 5th grade level science when i was in school. I also spent a year or so doing testing for the highway department, testing compaction , asphalt, concrete and so on. back then it was all old school basic science no special meters or anything. a lot of grading, washing, drying, weighing and a calculator lol.. not nearly as interesting as the science involved in drilling an oil well. Now that is some sciency stuff there my friend ever see actual oil shale from 10,000 feet down?
Ax sheath
chuck123wapati replied to Bawarrior's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I like it!! And the hatchet. -
even doing it with machines is labor intensive and wet, very cool videos Fred, do you notice how big the drums are comparative to the load they put in it. You would need a cement truck i think lol.
An arm guard just in time for turkey season!
chuck123wapati replied to dhaverstick's topic in Archery Quivers and Bow Cases
Carp is the first thing thing i ever hunted with a bow, Taking one with the first shot first shot got me hooked for life that was in 78. I still have the same bow, spool and arrow lol. Sweet little Browning Wasp 50#. Good luck to you as well my friend. -
they do tumble hides to break them but the size of drum you need makes it all but impossible for a hobbyist type tanning setup. they have to be huge.so the hides don't ball up.
i'll be bow hunting them in about three weeks lol. No turkeys around here for me so Carp will have to do lol. -
oh yea, that's cool indeed! Tanned carp is interesting might have to try that. -
Why do people think leather hasn't been studied to death???? Humans have been using it longer than science itself. lol so much for " people with more of a technical background" knowing shit about anything i guess none of those Brainiac's prolly know about these. https://archive.org/details/pub_american-leather-chemists-association-journal We've done a half dozen hides since this post. Some things are as easy as they are ever going to get on a small scale project and there's a time when you just have to accept that, roll up your sleeves and work hard. Don't worry though its actually good for you. Thank you i appreciate that information but NO, I'll pass i couldn't find any info anywhere on that product. I'm not chancing ruining a hide I've got so much work into already.
