Everything posted by terrymac
What is sad is there used to be a number of people on this site that when they gave advice or a suggestion, you could take it to the bank. For whatever reasons they no longer participate. I can only guess the reasons. I am sure Hidepounder got tired of trying to explain what Sheridan style carving truly is. He could go thru a complete explanation of why flowers and circles do not automatically translate to Sheridan and he might as well have been talking to a wall. Charlie from Equs Leather used to be a regular contributor, but I will bet he got tired of arguing with people. Oh well, nothing stays the same and life goes on.
Trying My Hand at an F.O. Baird Pattern
terrymac replied to YinTx's topic in Floral and Sheridan Carving
Sheilajeanne, your instructor was wrong. Pear shaders (thumbprints)can be utilized either way. If you would look at the cover of the latest "Leather Crafters" journal, you will see a piece tooled Bobby Park (Hidepounder) on which every flower is treated the way Yin Tx did. It just all depends on the effect you want Terry -
Get some wool ,, if you are using rags or paper towels, I'll will guarantee you are not getting all of the residue. Tandy sells some synthetic wool that works great. At this time on your project, use the wool and reapply the Tankote, and work into the leather. I'm afraid the oil you applied may hinder the excess residue. I always apply oil before the paste and I personally will use only Bees Natural Oil. I threw the underfoot oil away a long time ago. Bees will not darken your leather. Hope this helps, Terry
Try Bee 's Natural Saddle Oil. Has no smell and does not darken leather. Hop e this helps Terry
I could tell it was split as the thickness was uniform on the entire side. Ain't going to happen without splitting. Terry
Sent you PM Terry
- 12 replies
- ks blade
- pricking iron
(and 1 more)
TanKnote is no way, no how ever intended to be a resist. In fact, it can be added to antique paste if it starts drying, or to lighten up the antique color . It also works great when you have splotchy areas from the antique, and it will remove most of the "splotch". The only product that really works is Clearlac or Wyosheen sold by Barry King ( both the same product). Must say I have not used Bee's new product so can't comment on it although their saddle oil is the best on the market. You get into Tandy's antiques, and you can take everything I have said and throw it out the window. Resolene does not work very well either. Terry
Use wool pads to remove excess antique paste. It is the only way I have found to get the paste out cuts and tooling marks. My resist is Clearlac, same thing Bob is using. Terry
Barry King sells a packet of belt patterns done by Bill Gardner, one of the godfathers of the Sheridan style carving. Well worth the money. They were are tooled by Clinton Fay, and include a complete list of the Barry King tools used. Good luck Terry
- 27 replies
- don gonzalez
- sheridan belt pattern
(and 1 more)
Great improvement!! Small suggestion is to continue veiner work around complete scroll. Do this prior to beveling and then when you bevel the border, most of it disappears, yet appears that these marks were part of the complete scroll. Keep it up Terry
- 27 replies
- don gonzalez
(and 1 more)
Whole lot better. Next order of business is smoothing out your beveling. You don't want to see individual tool marks as around the top of your petals. Someone will tell you to use a modeling spoon to smooth, but that doesn't work when you use a checked beveler, as I do 90 percent of the time. Just keep practicing, and you will get it. The other area to work is uniform spacing of the veiner marks around the scroll. I cheat, I got some old prickng wheels and use those to mark individual tool marks placement. Hope this helps, Terry
Biggest problem I can see your swivel cuts are not deep enough to show any relief after beveling. Your cut depths should be at least thirty percent of the thickness of the leather, preferably more. Hope this helps, Terry
Sharpening A Splitter Blade - Am I Doing This Right?
terrymac replied to rhinez0r's topic in Sharpen it!
Bruce, Have you tried this thing, and if you have, what is your impression? Would it work on a Heritage with a straight bevel? Thanks, Terry -
Try some 3M bi-directional filament tape, and if you get it stuck well, you can tool some pretty thin leather with no stretching. Home Depot is handling it now, used to have to get from Amazon. I double it on the leather, and the stuff really sticks. Apply before you do any casing. This tape isn't cheap, but well worth the cost. Hope this help, Terry
Not sure what you are calling a stitching Chinese. If you are referring to a stitching iron, you can punch numerous holes at once and they will be in a straight line and it is easier to maintain a straight vertical hole Keeping a straight line on the front is easy, the real skill comes is keeping that straight line on the backside. If you are referring to a pricking iron, then an awl is still needed to go all the way through the leather, the pricking iron gives you the hole placement. If you watch the good guys, they are using an awl and are stitching as each hole is punched, thus the reason for a stitching pony or horse. If you have punched the holes prior to stitching, the pony or horse holds the leather, leaving your two hands free to use the needles. It just makes the sewing a lot faster and efficient. I've tried just using my hands, and there is no way you can do it as fast without using a clamp of some kind. Watch the Nigel Armitage videos, you will learn a lot on correct saddle stitching and how to make the front and back of the stitch look the same. Terry
tooling Tooling Detail Guidance Needed
terrymac replied to ColoradoGirl's topic in How Do I Do That?
Barry King would be my source. He makes his bevelers in some awfully small sizes which is what you need. They are also steeper angled which means you will not be affecting surrounding areas. Look at his round bevelers, I can see several areas, especially in the mane, where they would really work well. I would also look at making it a inverse figure, that is beveling to the inside of the figures. Would make dying a whole lot easier. Hope this helps, Terry -
Get hold of Bob Park (Hidepounder). He is handling some edge markers that you put your own dye, and he is also handling a product called Edge Magic that you treat the edges with before burnish. You can contact him at Hidepounder@gmail.com Hope this helps, Terry
Need to pull trigger on Swivel Knife Opinion plz
terrymac replied to Rlaing's topic in Floral and Sheridan Carving
IMHO, finest knife on the market. -
Has anyone ever tried cutting a Poundo board?
terrymac replied to epiphanist1248's topic in Leather Tools
The poundo board will grab your knife or whatever you are cutting with. You want something slick so your knife will just glide over. Poundo boards are great for using punches on. Hope this helps, Terry -
One additional source for Sedgewick in USA is Booth and Co located in Boston (I think) Top of the line and good service. Quite the leather. I had a scrap piece that I just threw out on a table outside and left for six weeks and left fully exposed to the summer elements and full sun. I then put a little of Booth's bridle leather conditioner on it, and was dang near like out of the box. I can't imagine what a different leather would have looked like. It isn't cheap but well worth the cost. Ken at Booth is a check of a nice guy and easy s y to work with. Terry
