Goldshot Ron
Everything posted by Goldshot Ron
  1. The spring snap you posted looks like a number 200, but the buckle isn't anything I can find. Montana Leather has the snaps, and the only center bar buckles that they show are a number 121 or a 150 (roller bar). I use them for leather and they are responsive to questions. I recommend them.
  2. Tom, Beautiful work, as always.
  3. Very inventive Tom. I bought a stirrup plate for my machine to try to sew the rounded throatlatches, but I haven't tried it yet to see if it works. Continue with your good work.
  4. Tom, The bridle looks great. All hand sewn is impressive. Are you using a pricking iron or awl?
  5. I am reluctant to comment, because I may stir up a hornets nest. Your post appears that you are looking at a new saddle, or at least a factory made saddle. The saddles to look at, in my opinion, are: Circle Y, Colorado Saddlery, Martin, Crates, and Billy Cook. These are factory made, and can be repaired fairly easily. You should be able to pick up a fairly decent used saddle for $2200, but have a reliable saddle repair shop check it for you. There are many good used custom made saddles out there, but that requires time to check them out. Another good company to consider is McCall Saddlery. They are a small shop, but their saddles are well put together (A plus in my book). In Montana, there are so many good saddle makers, you couldn't help but hit one by swinging a dead cat over you head and letting it fly. My humble opinion, for what it is worth.
  6. Could you stamp some leather images with these stamps so we can better see their pattern? Thanks
  7. Since you are using a metal seat strainer, the best tutorial that I have found is Jeremiah Watt's DVD on saddle making. There are a couple of videos on You Tube that may be helpful: one is David Mills video. The one problem with buying a strainer from Weaver is that their strainers may be too short for a seat over 15 inches. A good source for strainers is Montana Leather. There, you can talk with someone that can measure the strainer to make sure it will fit your saddle before you purchase it. I have taken to making my own strainers from 22 ga. stock that you can find in a hardware store (i.e. True Value). This way you can cut it to fit the length, width, and stirrup slots to match your tree bars and your purpose. Ron
  8. This is for Klara's sake: draw with a pencil on paper your designs to feel the flow. You are able to erase and save leather at the same time. A sharp blade in a swivel knife is always a given, so I do not give advise expecting that people are still in kindergarten. If you are trying to tool leather, you should know how to case it; and, Bob Parks example above is worthless. Everyone has an opinion, and my advise above is from a class that I had with Al Gould, a Master Saddle Maker and Leather Artist. When practicing with the swivel knife (ON LEATHER, Klara) I have seen people use a damp sponge, a spray bottle (with H2O), and a number of other methods that worked for them to case or moisten the leather. Greg, you need to obtain a good instructional book or video to show you some examples of using the swivel knife. Also, if you can't draw a pattern on your own, copy from someone you respect. And, Practice, practice, practice.
  9. Greg, I like your lacing, and it appears that you have holster design down. An instructor in a class told us to work on making "s"s and "c"s. Start by burying the tip of the blade, and make an "s" as you gradually lighten up on the pressure and feather out you cut. It looks like you are applying too much pressure with your blade, thus your wrist and hand locks up. Also, are you practicing on paper first to save on leather? Good luck, Ron
  10. Dahhhh, correction on contact cement from above post. It is not Lyon's contact cement, but Master's Contact Cement (with a lion on the label).
  11. Mike, I use Elmore's Rubber cement for temporary bonding. Removes from grain side easily. I do not recommend Tandy's Tanner's Bond; it doesn't perform like they say. I have been using Lyon's contact cement, and it works well. The original Weldwood contact cement was good, but we can no longer get that in the Nanny State of California.
  12. Tom, That is one of Al Stohlman's books I do not have. My rounding method is basically self-taught. And, because I do not make rounded pieces very often, it is "hit and miss" when I do. One question, and I apologize if you mentioned and I didn't read your article well enough, but what is the finished diameter of your throatlatch when finished? My rounder's largest hole is 1/2 inch. Thanks, Ron
  13. Tom, I looked at your instructions for the rounded throatlatch, and find your method very helpful. Your halter looks very professional, and I will certainly use your tutorial. I cannot tell you how many attempts of rounded throatlatches have found their way into my trash. Thank you, Ron
  14. Hil, I hear your concern, but it is difficult to mark on a saddle everything that you are describing. When I make a saddle for a customer, most of them get bored listening to my tree speech, and care less about who made the tree. As Bruce mentioned, once a saddle is made, one is hard pressed to figure out the tree measurements. So, when looking at a saddle with no identification pertaining to the maker or tree, (and even if it has a maker's stamp) it is still buyer beware. Ron
  15. Joel, I was wondering just the other day if you had finished that case. It looks really good. It shows that you took a lot of time in your design and pattern work. Great job. Ron
  16. Looks real good for only your second saddle. I don't like cross over rope straps, and they don't fit a swell fork like they do a slick fork. But hey, it can be changed. Keep up the good work.
  17. My 3000 has it's electric cord in a box on the (facing the machine) right/back corner. I have been clumsy on occasion to hit this against my tool cabinet, thus breaking the box and pulling the cord loss from its connection within the box. It may be worth your time to check this if your machine is similar to mine.
  18. I have a small crock pot, approximately 1/2 quart size (found at a garage sale for a buck). I put the oil in a jar and warm it as you would a baby bottle in the crock pot. Just remember to unplug when you finish (experience speaking).
  19. Joel, Are these for Blevins Buckles? If they are, I'll take them off of your hands. Ron
  20. Around here, horn wraps are decorative, so I use latigo. However, the last piece of mule hide I purchased was just long enough for one decent wrap. Luckily, I didn't screw up on it, because I don't believe I would have had a longer section to cover a mistake. Your story about hay haulers is similar to farriers around here. They are few and far between. Good luck on your saddle, Ron
  21. Did you try Montana Leather. I know Weaver do not have them in stock. I even bought some last Fall from Springfield Leather.
  22. Rob, The saddle looks good, and well thought out. I agree with Toot that your seat for the center of gravity may be a little too far back because of the higher position in the hand hole area. That maybe the photo position though. I think you have too much of the front of the skirts visible, and lowering your front jockey would take care of that. The placement of your breast collar dees seems a little high. The catcher and rosette could have been lower to be located in a meatier part of your bars. Do you strings go through the bars? I like your inskirt design, and will save this photo for reference for the next inskirt that I do. Thanks for sharing. Looking good. Ron
  23. Well, I guess I did see it. It's even looks more impressive the second time around. You did a lot of tooling, that looks real uniform. Really neat saddle Randy. Ron
  24. Randy, Whatever happened to this saddle? Did you post the finished saddle in a different section? I would like to see the finished product. Ron
  25. Once the leather has developed those cracks, all you can do is put a conditioner on the leather. You said you have oiled the fenders, so there is not much else I could recommend. Also, I would not sand the leather. If the cracks are hard and rub your ankle or shin, you could get some different designed stirrup hobbles the would cover that area. For new fenders and leathers the price will vary, but could easily be around $175.00 for a set. A good usable saddle is always worth a couple hundred to repair.
