Northmount
Moderator
  1. You should be pushing down the items that are behind the items in front. So if a leaf comes out from under a flower, push the leaf down. (Bevel the items that are behind.) You are trying to do a 3D scene, so need to bring the foreground forward by bevelling (pushing) the background items down to do that. Tom
  2. I just junked a similar Brother machine. Give me the dimensions of the cover and I'll see if the piece I saved matches. Tom
  3. @Devo Moved your post to Leather Sewing Machines. You'll get more answers here. Have you tried any searches on ther web for this information? Have you searched this (Leather Sewing Machines) forum? Deleted your double post. Tom
  4. @LizO Moved your post to Leather Sewing Machines. Tom
  5. @JSage Please add a couple photos showing the front, rear, and presser foot area to help identify your machine. Any model numbers off a plate mounted on the machine, if any, would help too. Tom
  6. @MsChrissi This is a world-wide forum. You should update your profile with your location so members know whether to look at your machine or skip it because your are on Mars. According to your IP address, you appear to be located in the St. Charles, Missouri, USA area. Tom
  7. Really great work. I suppose that careful use of the swivel knife can do much the same as petal lifters, just can't reach as far under the petal. Tom
  8. After applying dye, let it dry 24 hours, buff off the dyed area until no more comes off, your white rag stays white. If you used Tandy's ecoflow stuff, it is water based and many solvents will loosen it up and mix with the solvent (that is in your paint). So as mentioned above, it may need to be sealed before adding the paint. Do some testing on a scrap piece of leather, same type as you are using. Tom
  9. Patchers are built for patching. Shoe uppers, and other light stuff. Main advantage is being able to sew in any direction as you can turn the presser foot 360 degrees. So can sew up a sleeve or boot top, etc. The teeth on the presser foot are aggressive as that is what drags the leather through the machine. No bottom feed dogs. A common usage is to sew badges, emblems, etc. on jackets without having to take half the jacket apart. Tom
  10. @Chrisie Moved your post to Marketplace. More chance of selling in that forum! Should identify if you are willing to ship etc. Read the marketplace rules here https://leatherworker.net/forum/forum/70-announcements/ Tom
  11. @TomSchell I moved your post to Leather Sewing Machines. You are more likely to get the help you want here. Tom
  12. It appears from your IP address that you are located in Golden Grove So Australia. You should add that to your profile so you can get responses that are more suitable for your location. Are you asking for vendors? If so you are probably more interested in an Australian source rather than USA, Europe or Mars. Tom
  13. See the following for info on resizing your photos. Tom
  14. You could put a post under business / estate sales. Tom
  15. Reduce the file size! See the following. This thread has several instructions and suggestions. Tom
  16. As mentioned in your other post, you should be posting for sale items in "marketplace". There is nothing in this post to "show Off". Tom
  17. @ScoobieYou should be posting for sale items in the "marketplace" forum. Pay special attention to the requirement for posting for sale items. Description, model number, photos, price, shipping, condition, etc. Tom
  18. Thick layers of paint or finish crack and flake off with continual flexing. Need to minimize the total thickness to avoid early failures. Tom
  19. Tandy has a suede / nubuck cleaner. https://www.tandyleather.ca/en/product/fiebing-s-suede-nubuck-cleaner?ip_lookup_country_id=CA&loadedFromCookie=1&session_id_token=d8eee6b6122de1c8e3e90b7a3a4c5d7f2e5e1ebf And a google search returns many possibles. https://www.google.com/search?q=cleaning+nubuck&ie=utf-8&oe=utf-8 Don't use something that will stain the skin. Dry type cleaning should be the best if it hasn't been stained with some sort of liquid. If stained with a liquid, you may have to treat the whole surface in order to maintain a consistent color. Tom
  20. @bruce johnson Can you provide some input here? Thanks Tom
  21. Off the main topic: I worked in a electric utility plant. We had 2 steam turbine generators built by Parsons (UK). One was purchased and installed before WWII. The other was purchased and installed post war. Both were the same capacity, but the threads were different for each unit. So had to have 2 sets of common parts, and 2 sets of wrenches. Couldn't even have common British/Imperial units! I inherited a set of taps and dies. Didn't notice at first that they were Witworth threads instead of our common NC of NF Imperial measures. Messed up a number of bolts and threaded rod! Tom
  22. Do a google search "site:leatherworker.net dixon plough gauge" (without the quotes) and pick images. There are lots of photos. You'll see the layout and may be able to estimate overall dimensions based on your plough gauge. Tom
  23. @dramdani @mikesc Just a few posts above, is this post! And by the way, this is not the same bag as in the video linked above. Its source is https://www.etsy.com/ca/listing/582183857/bag-pattern-leather-diy-pdf-download?ref=shop_home_active_28&pro=1 Tom
  24. @archerydude If you type the at '@' symbol followed by a username, click on their username from the popup list and type, they will normally get a email depending on their settings, for the post you are making. Just like I did here. Tom
  25. When you click quote, this (above) is what happens! If you highlight a piece of text a box pops up "Quote Selection". If you click on it, it places that selection in the reply box after the last post in the topic thread. Just like this: There is an envelop icon just to the left of your username at the top of the current window. Click it and see what happens. To contact a particular person you need to start typing the username of that person and pick (click) on the list that pops up. You can also hover the mouse over the username in a post and a box pops up. One of the items at the bottom left of the box is "Message" which takes you directly to the PM System. If you go to the main page https://leatherworker.net/forum/ You can see a list of all the different forums with descriptions here on LW. You will find one that is called "Computer Help". It has "sticky" posts that stay at the top of the forum for common items that people often have questions about. The top 4 threads are 1. How to post pictures on LW, 2. Inserting link into topic, 3. Picture resizing, 4. Tips on backing up your data. All good topics to review. Tom
