Obviously the answer depends on what you are sewing including the thickness and temper of the leather, and how slow you want to go. Without those facts, there is no real answer.
@ColoradoGirl in case you didn't get automatic notification.
Yes, IP address locations aren't always correct. VPNs, Starlink, cell phone networks, etc. can be really misleading. What is interesting is that the source LW uses yields a different location than IPAddress.com which says Walker, Louisiana, 70785, United States. Only part LW got right was the country and that is helpful when looking for info that is more useful to users that are searching for help or suppliers.
@Aven Add your location to your profile. According to your IP address you are in the Chicago, Illinois, 60666 area.
@WalterF Merged your posts so related information stays together and members can see the whole sequence.
As others have said, need to know where you are to provide the most help. According to your IP address, you appear to be in the Calgary, Alberta, Canada area. You might consider adding your location to your profile, after all this is a world wide forum.
@serhu Moved your post to leather sewing machines. This is where the sewing machine guys hang out and where you will get the most help.
Moved your post to sewing machines used. While you were in the announcement area, did you read the rules for posting in the marketplace? In either case, go back and read them. Post photos, etc.
Perfectly folding leather at 90 degrees
Northmount replied to VinceOuel's topic in How Do I Do That?
Use 3 layers of leather, the middle layer to hide the magnets. -
What is the pill? I tried one prescription propranolol and in 3 days, anything that was red in colour would move around and even disappear. Side effect is eye damage. Stopped taking it, and in 3 more days my eyesight returned to normal. Would sure like to find something safe that works for me.
I see Chump is on the campaign trail early!
Northmount replied to toxo's topic in All About Us and Off Topic
Political posts are to be in the political forum that was setup for this purpose. This thread is locked. -
Tag the user or quote part or all of a post so the user is more likely to get an email notification. Type the symbol @ followed by the username. Pick the username from the popup list. @AtomicLeathers you have some one interested in your skiver.
Adler 30-7 or Techsew Post Bed 85017
Northmount replied to Cali514's topic in Leather Sewing Machines
The Adler patcher has aggressive feet that will leave marks on your leather. The feed is only from the presser foot, no bottom feed or needle feed. Nor recommended for wallets or purses. Primary purpose is patching shoes, boots, and sewing patches on jackets or caps. Also may be hard to sew straight lines. -
@mcguyver42 I'm a little late to this discussion. If your leather curls too much for your comfort when laying out and cutting, moisten the leather enough that it doesn't curl. Lay it out so the curl is facing down. You might need to place something on top to help flatten. Let it dry flat. Leather will tend to curl while drying. Be careful what is against the grain side of the leather as it may transfer a pattern to the leather. Even paper towel will leave a pattern, so your surface needs to be really smooth. I use a pencil or pen to lay out my cutting lines. Make sure the lines are not going to be seen in the finished product. Moistening or oiling before applying dye helps to get a more even coat of dye. To me, it is better to have the dye absorbed more slowly so you don't have dark patches where your sponge or sheep wool touched down. Then it is much easier to get a more even dye job. It may take a couple additional dye applications to get it completely even. If you want the finished dye job to be light, dilute it a lot first. Each time you add dye, the leather gets darker. Hard to make it lighter when it's already too dark. It is also wise to dye all pieces (of the same batch of leather) at the same time to reduce the variance between parts when assembled. I like to dip dye. But it is hard to get a light dye job when doing that. Another option for applying dye is to use an air brush. There are cheap ones around that do adequately for applying dye to a large area, not trying to do fine detail like some fellows do. My skills are just for broad coverage. Don't have the coordination for detail. Make sure your cutting blade is really sharp. The angle of the blade edge needs to be quite shallow so it doesn't act like a thick wedge. It's not like cutting meat where the meat is soft and deforms easily letting the knife through. There are lots of posts about sharpening knives. Pay attention to "scary sharp"!
- 17 replies
- when to oil
- dry leather
- (and 5 more)
You have good eyes! I did see this ad, but missed the small text somehow. I'll go back and fix my comment. Appreciate your comments and followup.
Just refreshed the link about 100 times and didn't see their ad. Saw a few other leather sellers. Still I could have missed it. We'll see what comes of it.
If you want to advertise here, buy a banner ad or at least become a contributing member. Contact Johanna for information. EDIT: My apologies. I've missed seeing your banner ad. Thank you for supporting this site.
Even when looking for reasonable offers, you still need to post a price $xxx or best offer (OBO).
You can post it here in the Marketplace forum. See the Marketplace rules.
Quality of Blanchard Pricking Irons and Beginner Purchase List
Northmount replied to frankly's topic in Leather Tools
Download Singer 132K6 / Seiko SK-8 Manual
Northmount replied to Northmount's topic in Leather Sewing Machines
Check your browser and other settings. Both manuals downloaded just fine this morning.- 7 replies
- singer 132k6
- seiko sk-8
(and 1 more)
I had some terribly smelly leather too a few years ago. Smelled like urine. I used liquid saddle soap, literally soaked it, followed by rinsing the surface with water and let it dry. It helped some. Finally bleached it with oxalic acid followed by another rinse. The combination worked. Might work for yours too. Then it needs some NFO.
Does car upholstery count as light or medium?
Northmount replied to JessH's topic in Getting Started
@JessH hasn't been around since 2021. When you want to get someone's attention, either quote some part or all of their post or tag them using the @ symbol followed by their username and pick the username from the pop up list. You may have to scroll down some to see the list. When you properly tag a person, the tag shows up like this post. If they aren't tagged or quoted, they may not receive a notice email.- 11 replies
- light leatherwork
- medium leatherwork
(and 1 more)
Water based is a better description than acrylic. The resist is able to block water based dyes (and of course acrylic paints). The solvents in pro dyes and other alcohol based dissolve the resist. I have found they even penetrate lacquer based finishes to some extent. From Tandy's site: Eco-Flo Leather Dye is a water based, low V.O.C., penetrating leather dye for use on natural veg-tanned tooling leather. It's great for overall solid color dyeing or background dyeing.
