my JACK servos have a magnetic accelerator unit. You can tweak them a little bit but I only needed a hex keys to move the magnet lever a bit back. Agree - adding a speed reducer is the best you can do.
Does not surprise me the Singer is the better one. Yet I have not found any good recommendations of Chinese patchers. The few posts I have read were not really positive. Well there are for sure some that work well but personally I´d rather buy and old Singer than a new Chinese patcher. Have fun with your 29K. Post some pictures when you have time.
So true - I have the same problem c´mon - let the voices get you - you need it - you need it!!!
Machine/foot for padded belts and other tricky edges
Constabulary replied to HVLW's topic in Leather Sewing Machines
....and again an excellent UWE-Video !!!- 10 replies
- recommendation
- uneven leather
(and 2 more)
could be possible that your hook tip is shredding the thread. You probably have to adjust the needle bar a bit. I would guess you have to lower it a bit. Or have to adjust the hook saddle towards the needle. Just guessing...
132k / 133K are not as heavy duty as they appear to be. One reason for that is for sure the quite light weight hand wheel. I recently have restore a Singer 45D91 (pre 1945 German made 45K so to say) and it has a much larger and heavier hand wheel. The 133K is much heavier weight wise but to me it seems the 45K has more punching power. Mechanically a bit different but needle bar and foot bar mechanism are identical. Needle and needle stroke are the same on both machines. 441 machines are for sure way ahead!
What thread size are you using? You can probably shorten the tension spring a little bit.
try a needle 1 or 2 sizes up!
New to industrial sewing machines Juki LU-562
Constabulary replied to jshep's topic in Leather Sewing Machines
You most likely need a compete new hook saddle, hook, bobbin case opener and the casting needs some machining AFAIK. A new used large hook machine would be cheaper I think. EDIT: was just writing when TT answered -
Sewing Machine For Beginner
Constabulary replied to firstcapitalfirearms's topic in Leather Sewing Machines
Wiz linked to the Video. Hope that cures you from the sailrite LSZ-1 If I had space problems and need a heavy leather machine for holsters I´d check with the mentioned dealer f.i. and ask for options - maybe they can somehow set up a CB3200 for limited space. Keep in mind that the machine performance is one of the keys for successful leather sewing. It does not help you when you have a machine that fits your space but has not enough performance to sew heavy leather. You know what I mean? LW member UWE once showed a mobile / space saving solution with a Adler 69 (I think) cylinder arm sewing machine and a servo motor but I can´t find the thread. So that setup but with a CB 3200 instead could be an option or at least a part of a solution. I´m sure UWE will read this and find the link to his thread. -
The sailrite LSZ-1 is a joke for sewing holsters - not sure if you have seen the "funny" Youtube Video already. Putt 200 bucks on top and you can go for a proper Cowboy CB3200 with walking, Servo Motor and speed reducer f.i from Toledo Sewing Machines: http://www.tolindsewmach.com/cb3200.html EDIT: sorry - have not noticed the word "portable" earlier - however you should consider the CB3200 anyway. Maybe build your own space saving stand. Well - depends on how portable you need your machine. -
Compared with your 211 / 111 It can handle much thicker thread and has a HUGE rotary hook. It is gear shaft driven so no need to replace a timing belt one day. Thats what comes to my mind within a few seconds
You may have seen this video already
I have no source for the 508309 lever but I once have updated my Singer 111G156 with the 508309 lever of a Singer 211 so I think you can use the standard Singer 111 lever as well they are just shorter. I may have one of the shorter levers if it works for you.
Looks like an updated clone of the Singer 132K6 - somehow. So the adjuster on the Singer 132K´s is where the red arrow points to but since the manual says "REMOVE COVER" I would guess it under the cover plate where where white arrow points to. Take some pictures of your machine and of what under the "covers".
Check with Keystone Sewing Machine Co.
- 2 replies
- restoration
- 7-33
(and 2 more)
Have you checked your manual how to thread the machine? If you don´t have one download it HERE When you reinstall the needle plate make sure the small squared tab of the bobbin case sits inside the small notch on the underside of the needle plate. You cannot operate the machine w/o the needle plate installed!!!Thats very important. Otherwise you could damage hook parts when starting to sew or probably disengage the safety clutch (if your machine has one).
- 20 replies
Not sure when they have introduced the excenter for adjusting the timing but I think that came in the 30´s subclasses but not sure. The parts of the sewing head "almost" remained the same since the introduction of the helical presser spring (51 sub class) but there are some minor differences since there are very few subclasses that have a longer stitch length (like 29K52 / 29K54) than the "standard" 29K´s but they are rare as the hens teeth I´d say. I never have seen one. And I never read somewhere how much longer the stitch length is. The advantage of the later sub classes form 51 onward (51-56 if I´m right) is the helical presser spring instead of the blade spring on the back side plus the foot lift hight during the sewing operation can be adjusted by a "slide piece" secured with a wing nut on the backside of the head and you can adjust the presser foot hight the way that the presser foot does not touch the plate - maybe that's useful for thicker works - I´m not sure but that's at least one of the inventions in this subclass range. They also had a "drop out" gear box, whereas the earlier had a fix gear box in the lower arm. The gears in this range are critical as they have very fine teeth and spares are no longer available - or you have luck and find some old stock. From the 58 subclass onward (58-62) the machines have a "quick release" for the hand wheel. You can pull and turn a plunger then only the hand wheel spins when you wind the bobbin. The predecessors had a fixed hand wheel and the the whole machine mechanics runs when you wind the bobbins. You also have one big screw that holds the hand wheel on the shafts. Predecessors had two set screws. But you have an adapter the hand wheel sits on and when you want to switch the hand wheel from front to side you also have to remove the adapter which also is secured with 2 set screws. From the 58 onward the machines no longer had the plain screw and nut as thread adjuster on the arm lever. Instead they had an adjuster unit with thumbscrew dial. They also have a fully replaceable lower arm horn which includes the gear box. And as far as I remember there is a screw post with thumb screw on the upper arm for regulating the spring for the thread lever. That formally was just a plain screw. Not sure what the update on the 70´s subclass was but I remember there no longer it s screw that holds the needle plate instead there is a "mushroom pin" secured with a set screw from the front. Basically - the higher the subclass number the more technically advanced the machine is and the better is the chance for finding spare parts. So if I was looking for a used 29K patcher machine that I want to use for a long time and parts have be available I´d look for a machine from the 58 subclass onward since most of the parts from the "up to date" 71 / 72 / 73 subclass fit these machine. Or in best case find one for the 71 onward. I looked for a long time until I found a 29K71 short arm but it was in quite bad shape so I have restored it and I´m more than pleased with it. I only wish it had a large hook. I know there was a 29K short arm model with large hook. Glenn mentioned it a while ago but I have never seen one of them. I hope I have not mixed up something... Too many details on these machines have changed over the years. I´m sure Glenn / Shoepatcher knows more details.
29K are sometimes a bit confusing because the difference between 2 subclasses sometimes is just the presence of a wax pot (or not) or a side wheel (or not) or if the machine has a small or large bobbin... The 29K parts list sometimes tell the differences. They write "Same machine as 29K.... but with the following differences..." - or the like. 29K70 short arm, small bobbin, no side wheel - 29K71 short arm, small bobbin, with side wheel, 29K72 long arm, large bobbin, with side wheel, With side wheel they mean the detachable hand wheel on the front side.The machines with just an end wheel sometimes are lacking the wooden crank knob. Not sure on the 70´s subclass but the early 29K´s with just end wheel often do not have the crank knob.
Eric - I`m not sewing at high speed and don´t use the mentioned oil or lubricant but when the Lilly White Oil does not stain can´t you use it as thread lubricant as well?
Getting a Landis #1 going
Constabulary replied to magneticanomaly's topic in Leather Sewing Machines
WOW - what a nice massive machine. I don´t know the Landis but you can contact LW member SINGERMANIA, He lives in Australia and has A LOT of nice heavy machinery. or check with Campbell-Randall. -
I have an older photo copy of the dismantling instruction + parts list for the Pfaff 145 in English language - if you are interested I can scan it and post it in the days to come. Or send it by email if the file will be too big.
I have restored a couple of barn finds over the time. Fortunately most where Singer "based" machines and never had bigger parts issues. Pfaff parts (even after market parts) are a bit more expensive as you for sure know but as long as you don´t meed a new hook it´s most likely worth restoring it. Good thing is the 145 has no timing belt so you you will not have headache with that. Looking forward to some pictures
Question about the singer 111w
Constabulary replied to ScottyBallz's topic in Leather Sewing Machines
1/4" without problem! with mine I can sew 10mm cotton webbing w/o problems - but 10mm not veg tan leather
