Everything posted by garypl
I’ll give it a try!
But doesn’t the moisture bead up on the sealed leather, causing it to drip off the glass when you pick it up? That’s why I thought an unsealed top surface would absorb the moisture and prevent drips. Gary
A friend of mine has a Dake - I think it is a 5 or 10 ton - stands about 2.5 feet tall! Gary
Yes, I use a wood slicker by hand to burnish... Did you let the first coat dry completely after the first coat? I have never had any paint peel off. I dilute the paint about 20% with distilled water.
First try at a full flap holster
garypl replied to Jake907's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Jake, that’s one big holster! Nice job - looks like it should last a long long time! Gary- 32 replies
- rough out
- .44 redhawk
(and 1 more)
My 1st bag
garypl replied to the gafer's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thanks Gafer! -
Rattlesnake Knife Sheath
garypl replied to Rolandranch's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Didn’t realize it was so thick! Do you have a side view? Gary -
Help repurpose thrift store leather :D
garypl replied to Nekomimimaid23's topic in How Do I Do That?
1. Only thing I can think of to remove something like Barge cement is lacquer thinner or acetone - both very flammable and nasty fumes, so use care when handling them. If it is water based glue, l am not certain what solvent will work - never tried to remove it. 2. Apply NFO to dry leather. If you wet the leather, let it dry completely and then apply NFO to the grain (smooth) side and don’t overdo it - you can always apply more but once you put too much on it can make the leather mushy. If you are going to dye the leather, let the dye dry completely and then apply NFO. Good luck! Gary -
Welcome! Removing old glue can be a problem. Try a solvent and see if it softens the glue, but realistically you might be better off covering it with a lining leather. To bend the leather and minimize cracking, try wetting it thoroughly. You will know pretty quickly if this will eliminate the cracking. I would give it a treatment with neatsfoot oil once you are through wetting and bending it and allowing the leather to dry completely. Looking forward to seeing the end result! Gary -
No idea what I'm doing, but happy to be here!
garypl replied to JiffyJones's topic in Member Gallery
Looking good! I like the darker color shades. That tongue is nasty! -
Thanks UpDn! I like the steel table - looks like it works much better than the small tables that come with the Chinese models. I bought a piece of 1/4” steel plate to use as a table on my press. Gary
My 1st bag
Nice looking bag! Please share details as to type and weight of leather, thread type, finish, etc. Inside view would also be nice! Gary -
I think your painted edges look very good! I have been using Giardini to edge paint for about 9 months now and I think it does a great job. I normally burnish my edges and then paint them using the roller paint tool from Tandy. Normally two coats of paint with sanding in between coats, then burnish the painted edge and follow up with wax. I painted the edge on an eyeglass case that I carry in my back pocket constantly and it looks about the same as the day I finished it - no cracking or peeling! Gary
I sometimes hear a slight clicking in my CB4500 - might be coming from the small takeup spring located right after the lower tensioner - it seems to quickly pop up while sewing. Everything seems to be sewing nicely, so I havent paid it any attention. If anyone knows differently I will be interested in learning more! Gary
That looks like a really high quality arbor press! Who makes it? Gary
gilded LotR style sheath for nephew
garypl replied to robs456's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I used knives and guns when I was very young - from about the age of 11 - and I started my kids shooting when they were around 8 years old. Too many people around now days that are horrified at the thought of an 8 year old touching a knife or gun, even under adult supervision. Most of these types are in the bigger cities.... -
Hey Ryan - how did you do the inlaid rattlesnake skin? Is it sandwiched between two layers of leather? I think it’s a bit fragile so you wouldn’t want the knife rubbing directly against the snake skin - correct? What weight and type leather and thread did you use? Gary -
Well said Mike - I have a few scrap projects in the bin as a result of my machine sewing education! Only takes a second to hit the wrong pedal and see your project go south with stitches where they are not supposed to be! By the way, I received the black leather scraps I bought from you and I am pleased with my purchase! Gary
I think it's looking good! I think maybe the colors in the eye are a little too washed out - maybe more vibrant colors would make the eyes pop a bit more? Gary -
I like the vibrant colors. Nice Job!
The last time I hunted with my flintlock was about 35 years ago. When I did go into the woods, I normally used heavy grease around the frizzen and pan to keep the moisture out. Also used 3F instead of 4F powder for priming.
Hey Ryan - nice work! I see your work steadily improving with each project you post! Gary -
I use alcohol with Fiebings oil dyes with no problems
I have used denatured alcohol for years - works well....
