Everything posted by fredk
Another adhesive we have forgotten about; the sheets of heat activated adhesive. It needs using carefully as too much heat can destroy the leather eg; https://www.ebay.co.uk/itm/Adhesive-Iron-On-Sheet-by-Sizzix-by-Sizzix-663009-/113709155177?hash=item1a79980369 If you just need a fabric lining you can get materials with iron-on heat activated adhesive on it eg; ebay.co.uk/itm/Iron-On-Fusible-Non-Woven-White-Black-Interfacing-Lightweight-Medium-0-9M-Wide/262845535860?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
A difference in materials; here those square nails are soft iron. Look at it too hard and it'll fold up.
My #1 son got his business support grant about 3 days after it was introduced. He's been told he'll get the wages grant at the end of this month. He has two workers on 'furlough' who will get 80% wages, which he pays then the wages grant pays him. afaik he has to prove their wages.
Tandy also has hat patterns in their on-line Library. The patterns are free Have a look here; https://www.leathercraftlibrary.com/product/1210/2662-leather-hat-pattern-pak if you can't find one PM me, I might have a copy saved.
True. But they should be entitled to the grants available. For some it might be enough to keep them from closing up. I only order from Le Prevo and a couple of other places. I have orders from those odd places but they might be closed up as my orders are now 5 weeks overdue, one is outstanding from 16th February.
Do let us know how you get on.
I should add; use your liquid adhesive sparingly. Too much wet glue can squeeze through the weave. You just need enough to keep the fabric in place. Generally its not going to be getting pulled away from the leather
Mouse purse
fredk replied to ironwrx's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thats nice -
1. your initial fraying will be on that excess beyond what is needed. If it frays badly just have a wide margin 2. If you pay attention to the edges of the leather, ie have good glue coverage, when you cut the excess fabric off the edge, the new edge, the fibres will be stuck together by the glue 3. If you do have a bit of fraying, just wipe a very, very small amount of glue along the new edge
I use one or two coats of 'Pledge with Future Shine' * floor polish which is actually a water thin acrylic varnish * It keeps changing its name. I'm not sure just what its called in the US anymore. Also there are cheaper but just as good alternative versions out there. Here in N.I. I use a version called 'Astonish' As long as the paint is dry I brush on one coat of the acrylic varnish. It needs put on softly as it can lift the paint off leather. Brush lightly or even spray it on. I find dipping is not so good as it will make colours run. When that first coat is dry I put on a second and thats it for normal things, but to really water proof something I put on a 3rd coat. As its an acrylic vanish too many coats* will make the item stiff and the coats may even crack when the item flexes. * I'm meaning 7 or more unthinned coats
How I do fabric linings 1. Cut the fabric larger than needed for the leather 2. Stretch the fabric tight and pin or staple to a board. 3. Apply a thin coat of contact adhesive to the leather only, with attention to edges 4. When the adhesive is still slightly tacky, almost dry, slap the leather down on the fabric 5. Use a brayer to press the leather down, working from centre outwards in a star pattern 6. Release fabric from board and turn over, use brayer to lightly press the fabric to the leather 7. Trim fabric to size of leather with scissors, very sharp scalpel or circular knife 8. Sew leather and fabric together as normal in project I've never needed to smooth the inside, the flesh side, of leather for this. Of course the leather needs to be dyed, sealed and edged beforehand.
1. as nice as it is I would have used star shaped rivets. You can get them with fold over tags, rivet-on or screw backs. The rivet-on are in two types. a ready-rivet type or a nail type. The stars can also be got in silver, gold, black, copper, bronze, gun-metal colours. I think if you could remake this with the star rivets your pal will like it that much more 1a. If I was doing this, not only would I use star rivets, I would deepen and widen the flag lines, use different coloured dyes, or paints, for the flag's coloured areas and use a white or silver paint pen in the wider flag lines Polite remark: If the flag is important to you take extra time and care representing it. 2. a great-grandfather on my paternal side fought against people carrying this flag. Here in N.I. people only associate this flag with the tv show 'Dukes of Hazzard'! 3. I might just make a wallet as in 1a above just for the heck of it.
- 8 replies
- confederate
- flag
(and 1 more)
No, I have not made one. On my to-do list. For a pattern with a youtube video to show you how - https://www.etsy.com/uk/listing/628831400/leather-hat-pattern-diy-pattern-indiana?ref=shop_home_active_15&pro=1 or https://www.etsy.com/uk/listing/654458523/leather-hat-pattern-diy-pattern-cosplay?ref=related-1&pro=1
I think I bought the wrong type of leather to practice on? Or....
fredk replied to TestTube's topic in Getting Started
If you're referring to me: I was in the process of complaining, trying to return said waste and get money back when Manchester closed. Texas brushed it off saying it was a branch matter, take it up with them. . . . ! To describe what I got was; you know when you get a hide and cut off an edge so you have a nice straight edge to work on? I got that bit that was cut off. I was assured that what I was going to get was usable even though it was an odd shape, supposed to be one piece as well. afair about £2.50 sqft. = £20. I've never been done badly by Le Prevo. -
Not just in starting out. Last year, just before Tandy Manchester closed, to top up an order, they offered me about 8sq ft of belly leather cheap-ish. I got it, and got taken. It was bits about 6 ft long varying from 1/2 inch wide to 2 inches wide. Covered in clamp marks and scars. 10 strips of useless is what I got. PS: where ya bin LD2? -
Where are good places for beginners to buy leather online?
Tandy keeps retracting. This time last year they had several branches in Europe. Then they dropped to one branch, in Spain. No sooner had they done that then the that one closed and orders had to come from Texas. They've cut back on what they're selling. Last April/May I received a big order. I placed it with Tandy, Manchester but by the time they sorted themselves out it came from Texas. They re-did their website which wiped out my account with them. I had to 'rejoin'. I had been building up an order to place about 8 weeks ago, that was wiped out and now when I try to place anything in the 'basket' I'm being told 'This cannot be shipped to your country' even though I'd bought the item(s) previously by mail-order. Everything looks like a business thats winding down to close-up. -
The ones I linked to are all the same size. They take off about 1/2 mm from the edge. You can get larger sizes which take off about 1mm and there are sets with ones which make a U groove. Superior steel and construction. Fiat or Camaro ? both will get you to the shops, the Fiat will do the job, but its nicer to drive a Camaro and it'll get you there with less fuss or fettling
I'm sure all the tools you've linked too are fine and I have a few of those styles of bevelers, and I've even used my French skiver sometimes, I do now have a preference for these; https://www.ebay.co.uk/itm/5pcs-V-Shaped-Hand-Working-Leather-Stitching-Working-Hand-Leather-Edge-Skiv-M3Y6/303229244553 , with a finger on the finger-divot they fit neatly along the forefinger betwixt finger and thumb.
NB. Le Prevo is currently closed due to the virus & business restrictions. They say their enquiry email address is still being checked and answered, though that may take a bit longer than usual -
That one and its sisters are for sewing. As the OP is in the UK then he/she is using the correct name as far as they know it. Still waiting on the OP to come back and explain their requirement more clearly.
Here: http://www.leprevo.co.uk/photos/pricking iron T134.htm
I searched the number on ebay and it brought up this; https://www.ebay.co.uk/itm/3-D-Stamp-Live-to-Ride-8540-00-WBL/273608362518?hash=item3fb4544a16:g:P1kAAOSwe~lcEcRC ~~ winged 'Live to Ride'
Le Prevo, in Newcastle, just up the road from you.; http://www.leprevo.co.uk/ Abbey is often recommended as well; https://www.abbeyengland.com/ -
When, after I've sewn up the two pieces, they are locked together so cannot get out of alignment. After the first basic shape moulding I'd have trimmed the leather close up to allow for the bulldog clamps, the larger clips can go to out 20mm, the small ones only about 10mm or 12mm, so I've probably got 14 to 15mm from my sewing to the edge. After sewing I then use a wing divider to mark the cutting line. Very carefully running a (blunted) point of one divider arm along the thread and the other arm out where I want to cut, say, 6mm from the sewing. Done slowly and carefully this marks where I'll cut. If necessary I can go over the marked cutting line to deepen it, to fill in missed gaps, to make it more prominent. As the sewing goes through both pieces I do the above on both the front and back When cutting I try (sometimes I fail) to do the cutting as Al Stohlman advises. Cut at an angle. I do the front first, cutting along the marked line but at an angle so the cut is on the outside of the line on the rear. Then I turn the item over and using a new, or newly sharpened, blade I cut straight down along the marked line. This should take only a sliver of leather off. I finish off by taking some grit/sand paper to areas that look a bit askew Then its onto the slicking and burnishing
1. I do a basic wet moulding to get the basic shape, then 2. re-wet the leather and clamp together using shaped bit of sticks and bulldog clips as clamps 3. let dry and sew up with the clamps still in place, but moved as the sewing progresses
