RockyAussie
Contributing Member
Everything posted by RockyAussie
  1. Have a look in here and you will find all sorts of stuff like those roller presser feet and feed rollers etc - https://www.campbell-randall.com/shop/fav-fratelli-alberti?page=8 As to the vacuum...... the machine has to have an end covering to get the vacuum to work properly. You can see a plastic end cover in the pictures on this page which is along the lines I am talking about - https://www.techsew.com/en/catalog/category/view/s/cutting-skiving-machines/id/566/ That said having good backup and someone you can trust from a supplier is also important.
  2. Keep in mind that most dealers do not use these machines every day and would have little idea of the differences between the different models. Most of the cheaper clones are running a set up similar to what Fortuna stopped making around 50 years ago. The bell knife cutting only starts when the feed stone starts and that means also that when you want to feed the material through slowly then the bell knife also turns slowly and that does not work so well. It is common for people to solve this by putting in a second motor to have the bell run fast and the feed run independently. The FAV AV 2 you mention above already has a clutch motor similar to the Fortuna (I have one of each) and at the back there is a knob which can be set to have the feed run at whatever speed you want if you ever want it to run at a set speed continuously. IF you expect to use a skiver a LOT spend the extra $ early or learn the hard way as I did. Last note.....the rubber feed wheels do not go well if you mistakenly allow it to contact the bell knife while adjusting. It slices it and kaput. With a feed stone you can make a light contact and get rid a any coarse burring when you are doing a heavy sharpening process. Having a vacuum also takes a lot of waste away to the side without any need for it to drop down at your feet or the need to try and position a catching bucket etc. Personally I would be looking for a good condition 2nd hand Fortuna.
  3. Some close up pictures of the set up would help. In your picture above it may be that your feed stone is not close enough to the bell cutting edge but that may be just the picture. The feed stone for most work should be parallel and all but touching the bell knife inside edge. IF doing heavy weight leather a little bit of a gap at the back can help sometimes. Parallel to the bell is set by the knob at the bottom left and if you pull that toward you you will see the feed stone tilt down at the back. The feed stone closeness to the bell is set by the knob at the back just before the spring tension adjustment. The bell should be set into the proper place before any adjustments are made and that should be done by moving the bell forward so that it is around .5mm (1/2mm) away from the presser foot edge. For fine leathers a little closer and thicker harder leathers a bit further away. Once the blade is in position sharpen until there are no nicks in the blade and then dress the bell inside with the dressing stone and then recheck the measurements look right. As I said before ...some close up pictures would help here.
  4. Most leathers except greasy/waxy saddlery type leathers will stick a little to the stone or feed wheel that the presser foot pushes it down into aqnd that very often leads to the waste piece coming back up and ruining the leather you are skiving. Some of these machines use a wiper piece to try and stop that happening but the pressure it puts on the part often destroys and because the part that holds it is also on a spring pressure control it then upsets preciseness of the skive as well. The vacuum assist greatly in taking the waste away and avoiding this problem. I have had both with and without vacuums and I would NEVER have another one without vacuum. Other than the video above that is mostly doing leather pieces not long enough to come back up and around I ask you if you can find any other videos where you don't see the leather coming up and around at times that is not a vacuum type. This is even on dealers videos selling these machines. Believe it or not. Techsew and Campbell Randall both sell skivers with vacuum assist and Campbell Randall have a good range of feet and other stuff which can go on most of these model skivers. Most of it is in the FAV machine section but they are interchangeable with most others.
  5. I agree fully
  6. Excellent looking work @Danneand a nice design touch with the attachment method as well.
  7. A little bit yes. Bit like a 4 wheel drive compared to a 2 wheel drive. For heavy leathers and rubber and such then yeah go for the top/bottom but for most leather work except perhaps saddlery work I would not have one if you gave it to me. They are a pain and slow to alter the settings and get right but if you are doing a LOT of the same setting and its heavy stuff the go that way. (1to 2mm would be very easy on a bottom feed) If I wanted to skive 4/5mm of firm temper I would do a double pass if it were a wide and thin skive required. At near to the end of this video I did awhile ago you can see me skiving some pretty firm temper leather on a bottom feed but note I am using a roller foot which I use always on anything as can be seen in other skiving videos I have done. I hope to get another vid up soon showing some belt skiving stuff on it as well.
  8. A close up picture of the needle just entering the leather might help here. What type of needle is it and have you tried replacing the needle yet with a new one?
  9. Thanks @sainte that looks interesting and I do look forward to seeing it all come together.
  10. Have you checked how the machine operates after you did the steps in Uwe's video of setting the needle height and adjusting the needle to shuttle relationship up to 4.2 minutes in on the video? This is shown in the manual you linked to on page 11 step 14. The same step Bob has shown. If you have this correct then you should not be getting any missed stitching at this stage. The rest of the steps can be difficult to get right and may not be necessary to do anyway. I have done this whole process following Uwe's video and it can help but as I said generally you should not need to go beyond any steps shown up to getting the timing position of needle to shuttle relationship.
  11. Been thinking .......If the screw is so bloody tight are you absolutely sure that the timing has shifted there and not that the needle bar has been knocked upward????
  12. Here are a couple of pics of the screw extractors I got last weekend. Big for this job I think but a specialist bolt and nut place should have something along this line that would do the job.
  13. That is a shame. I will have to think more about the problem then. I same as you have no idea how to get that screw out without major surgery of some sort. Drilling it out would seem to be the only solution. In the hardware store last week I picked up a set of 3 screw extractors that are like a drill bit that cut in reverse that were fairly cheap but I have not had a chance to try them yet.($6.00 au ...I couldn't resist) A reverse drill bit a little smaller than the thread would be best I think.
  14. How bad is this timing issue? I presume you are getting some missed stitching happening when you go into reverse? Or are you getting the needle not going back into the same holes?
  15. No No No croc ones. I dont think they would wash that well my friend. Here is a link to a video I made showing a bit on us making them and cutting them out with pla patterns I printed up for the job. The lovely models at the start are my Granddaughters.
  16. Not sure if this will get you off ya but Bert. I found doing the drawings and with these type of machines that work away by themselves you tend to be ON your but a bit more. Mate if I can ever stop making these dam face masks I might just look into that idea. Every time we get some packaged up to send there goes another ting. Seems more people see my website than I ever thought. Now if only I could get my handbags to sell like that but I cant see them being mandatory any time soon.
  17. Just an observation......Your top tension looks to be too tight. When either the bobbin or top tension is too tight on supple type leathers you will often get a stitch length variation which can be worse when the machine does a reverse stitch. Firstly I would check that you can stitch through this leather in a continuous run and get the tensions showing up in a similar way, meaning no going up and down on and off. If you have it right there will be no shortening of the leather length from what it was to start with.(alittle longer perhaps) Back your foot pressure off until you can raise it by lifting the foot with your hand. I generally set my foot pressure back until the job wants to lift with the needle then screw it down a couple of turns. (you may have to consider taking out the small spring inside if you have not already) The needle size you are using is too large a size for this leather with this thread. Also that thread looks a bit like a slippery type thread and it may be worth trying another type to help rule that out as 1 potential problem. (they can be difficult to get the tension right sometimes on slippery threads). Try a firmer leather and see if that works and if the stitch does not return back into the same holes THEN start looking into under machine adjustments.
  18. Thanks guys. Bert ....Get a printer mate. Once you get the hang of doing the drawing stuff in a cad program the possibilities are almost endless. I think if I were starting off today into manufacturing leather goods I would have to put the 3d printer near to the top followed closely behind with a small watt laser (2.5). Not only do I save a lot of time and money on knives by printing out some of the cutting templates many of the components now get cut out on the little laser. That has cut my knifing costs in half. Just the other day I decided to try cutting the material we use in our wallets and purses with the laser and wow its fast (1100mm per minute) and sealed up edges as well. For doing up prototypes and small numbers they are truly a God send. Here the cardboard is cut first with the laser to give me a way of positioning the magnets needed to hold the fabric while the laser cuts the fabric. Once I have the magnets positioned I remove the cardboard template and hit the go button. Beautiful clean sealed edges in 4 minutes. All of the leather pattern parts were cut out in cardboard in a few minutes as well. Way nicer than having to carefully cut out each piece sooooo carefully with a knife by hand. With some luck I will get this prototype model done today.
  19. Very very nice work and your wooden form looks like it is working brilliantly. With regards to the snaps....I have only had this happen when I tried putting some leather down on the anvil piece to avoid scratches and that I found distorted the outer cap piece. Perhaps the antique ones with a design on may work better for you.
  20. Recently I agreed to supply some of our bags and bangles and some other stuff into a shop and in order to maximise the usable space and make it easy for people and shop staff to access these articles I came up with this idea. Now instead of taking a whole heap off to look at the one they want, they can just take it of the hanger. The first picture shows the problem when trying to rack up a heap of bags in a small area. This shows the bag hangers on a stand I came up with for the shop This one shows the bangle hangers We now store them in cupboards at work this way as well now Here are some stl files if you want to print them - Note between them you should be able to get a lot more by just altering the scale in your slicer program. BAG HNGR PLA.stl BAG HNGR 4.stl BAG HNGR 5.stl If you don't have a printer but still want them let me know and we can work something out. Stay safe and stay well Brian
  21. There are all sorts of leather varieties as to the quality and strength and from my experience with most chrome tanned leathers I would suggest the width would need to be 32mm to 35mm wide at that thickness. Doubled up it may be too thick but you could drop back the width to 20mm if you wanted. I would fully stitch the length to reduce any stretch either way you do it.
  22. Good looking video showing the machine in use. Thanks for sharing.
  23. No problems..... but you need to take the caster wheels off. You keep sliding around when you sew otherwise and they do get the thread tangled around them and then only slide around badly and getting the thread out of them is a time wasting bitch.
  24. Thanks Bert, lets just hope some buying customers see it that way. It can be if the gussets go into place after but it is very difficult not to push the gussets out of place when pushing in and around the bottom curve. My 331 has the needle 7mm in from the edge and some 335s are even 11 from the edge. In production it is better to make the job for the operator as easy to do as possible and to achieve that I make the gussets fold over the lining with an attached stiffener before the outer cover piece is attached. Here are a couple of pictures to show better what I mean - Different bag but same gusset technique.
