Sewing Machine tweaking: Consew 226 and Cobra 16" cylinder arm
Northmount replied to Primosand's topic in How Do I Do That?
Really nice bag! For the Consew, sounds like it its the motor brake. Either remove the brake shoe, or press the peddle just enough to release the brake, but not hard enough to start the motor. For the Cobra, there is (should be) an adjustment for how far the presser feet can drop. I will let someone else describe how to fix as I don't have a Cobra. Tom -
UK to USA power converter using a Power Mallet
Northmount replied to grommit's topic in Leather Machinery
Look for a switch on the power converter. Check its manual. Check for a fuse. Check there is power at your plugin. Try another plugin. Then get your electrician friend to come over if it still doesn't work. Tom -
You are not the only one seeing this problem as you can tell from recent posts. With the recent site upgrade, attachments have become detached. Johanna is working on reattaching all files. PM Anvas (above) and he may be able to send you the file. Tom
Welcome to the addiction er Forum. Show us some photos if you have some, brag about your work or ask for critique and help. Tom
Dried up oil varnish due to not using sewing machine oil? If so there are a couple other threads about cleaning up the mess. Some machines have seized completely. Try a search, should be able to find them. Tom
Go for a 5/8" barrel. Like it a lot better, and I don't have large hands. Tom
Further note to above: Since this was supplied for USA use, it must be a universal motor so can run on AC or DC. And it was apparently running for you. 125 VDC is very unusual, and more dangerous than AC. Coming into contact with DC draws you in, cannot let go. AC tends to bounce or throw you off. Your 300 watt converter should work just fine. Tom -
Your motor label says it is DC, that's direct current. Unless it is a universal series wound motor, it won't run properly on AC, alternating current. Your power converter/supply needs to match voltage and type of current. It also needs to exceed the power or wattage demand of the motor so it won't be overloaded. 1 horsepower = 746 watts, so 1/10 HP = 74.6 watts. Your converter should be 230 VAC input, 125 VDC output, capable of supplying 100 watts, allows some margin so is not running fully loaded. Tom See next post. -
In Tim's post a couple above this, the type of finger saddle makes a huge difference in the feel and comfort using a swivel knife. Note the left 4 swivel knives saddles. Rounded to fit in the curve of your finger instead of a piece of rolled flat stock. Long time ago, I made a leather cover for mine to stop the irritation of the square shape. Also, for me, I like a larger diameter barrel. Easier to hold, easier to twist with better control. The one I like the best has a 5/8" diameter barrel. And I don't have large hands. If you get a chance to try out different saddles and barrel diameter, do it. Will save a few bucks, and you'll be happier with a swivel knife that fits your hand. Tom
Sketch out a rough draft of what you want to see, then take a look at different font and alphabet patterns to see which comes close to what you have in mind. If you are good with a computer graphics program, you can try overlaying images captured from various sources to see what it looks like instead of doing a lot of hand sketching. I have scanned a few alphabet patterns so I can copy single letters at a time, size them, rotate them and overlay on top of the main object. Tom
Belt Leather Cracking At Buckle Fold - How To Eliminate It?
Northmount replied to CustomDoug's topic in How Do I Do That?
Dwight's comment about shaping the fold around a small dowel makes a lot of difference. It's the real secret of the process. If bent back tight with nothing inside the fold, the outside fibers are really being stretched. Had the same thing happen on a wallet a while back. It's important to avoid folding and pressing as if it was a piece of paper. Tom -
The site is just going through a complete upgrade, so have patience with its behavior for a bit. Lots of great information and people here. Thanks for adding your location to your profile. Tom
- 5 replies
- industrial
- juki
(and 5 more)
Still lots of glitches being worked on. These ones have been reported. Tom
Last time the OP was on the site was 8 Dec 2013. Not too likely that this is available or that you will get a response. Tom
- 6 replies
- strap cutter machine
- weaver leather strap cutter
- (and 2 more)
You might like to let people know where you are located. China, Australia, Europe .... including state and city/town would be very helpful. Tom
- 5 replies
- industrial
- juki
(and 5 more)
Wet Moulding And Carving... In What Order And How Much Water?
Northmount replied to shagsj's topic in How Do I Do That?
These photos were taken in a saddle sales shop and show the difference between stamping before and after wet molding. They back up Bob's comments. If you don't want to loose definition, stamping has to be done after molding. Of course you can prove it to yourself by trying both ways. Look at the swells versus the skirts in both saddles. Tom -
Let's keep in mind that there are under 18 year old members of the forum. Keep it family rated unless you want to move it to the adult section. There is nothing wrong with having some light hearted fun. Tom
Take a look at Jim Milan's Bucket List Jazz Band on YouTube. These guys are all over 75. Jim is my father's cousin and if I remember right, over 90. Also on Facebook Not exactly Big Bands, but great music you don't see very often today. Tom
The thread needs to be between the tension disks, else you have no control of the tension. Tom
Patterns and Templates Forum You can do searches here, see upper right of your screen, or do google searches for leather purse or wallet patterns. Some fabric patterns are good too depending on what you want. Tom
Try here Tom
Welcome to the forum. If you post your sewing machine questions in the sewing machine forum, you'll get the experts' attention much sooner. I thought about moving this thread, but then decided after all that it is your introduction, and I should keep it here. Tom
Should post in sewing machines. I'll move it for you. Help wanted is like the newspaper, people hiring or wanting to be hired. Tom
Picture?
Fantastic work. Keep it up. We love to see it. Tom
