Skiving the end of the lace will help, but you may still need to use pliers occasionally. Before you do much work on the purse, recondition the leather so it is a little more pliable. Else you may start getting cracking and even tearing out some holes. Don't pull outward putting strain the lacing holes, pulling through the edge. And when you get all the way around to make the final slice, pull out a few of the starting stitches so you get the slope of the lace consistent across the splice. The first few stitches are usually too vertical, so need to come out. You should do some practise lacing around a piece of leather say about 4x4". It will help you a lot with the purse. Good luck. Tom
You can pull out as much lacing as you wish. If you get into an area where it is holding 2 or more layers together, you can use small zip-ties every 10 or so holes so everything stays aligned. Tom
And you may have trouble matching the lace colour and quality. So yes, replace it all. Tom
When I was a kid, a long time ago, my dad ran a hog farm. We got a whole lot of flax straw for just picking it up and thought it would make good bedding in the hog pens. By the time spring came, and the hogs had been trampling the flax straw for some months, the pens were extremely hard to clean. If you tried picking up the mess with a manure fork, you were literally trying to pick up the whole pen. It was all matted together. Had to use an old silage cutting knife to break it up into pieces that could be thrown into the wheelbarrow. So all the trampling and bacterial action did little to weaken the flax straw, just helped to bind it together. And of course you know that linen comes from flax. So I have little concern that linen thread will deteriorate faster than synthetics. Anyhow, the story would make a good cartoon! Tom
A side cutters / diagonal cutters / wire cutters and a small ball-peen hammer are all that you really need for setting copper rivets. And of course an anvil of some sort under it. Anything beyond that is a nice to have. Just make sure you press the washer down tight and trim the post to fit. A tool for doming the peened end could be nice sometimes. Tom
Really nice job! Tom
Moved to leather sewing machines forum Tom
Calgary Tom
I can put you in contact with my son that does website design and maintenance. He says "I could set up a private phpBB installation if they want to set up a shared hosting account on BlueHost, GoDaddy, or somewhere similar." Send me a PM if you want more info and to make contact. Tom
We got it fixed, thanks Johanna. Welcome to the forum. Tell us a little about yourself. Tom
What should it be? Moderators can change it for you. Tom
These kits by Tandy and Springfield are pre-cut and may be punched for lacing or sewing, but haven't been tooled. The design of the tooling is up to you. Make your own design or use one of theirs.http://www.tandyleatherfactory.com/en-usd/search/searchresults/4179-00.aspx even though this ad looks like it is already tooled, it isn't. They are showing a finished product. Tom
Inside radius and outside radius of the fold are different so something has to give. Usually you notice the bunching up wrinkles on the inside more than the outside. But your outside leather has stretched, so when you open it flat, it wrinkles. If you make your own wallets, there are techniques to minimize the problem. Tom
Needle Types - General Description
Northmount replied to mproberts's topic in Leather Sewing Machines
Here is a brochure from Grozny-Beckert. http://www.groz-beckert.com/home/getFileCh.php?chbid=60&lang=en&file=content&download=true shows various needle points and stitch appearance. Lots of info out there on the web and here on LW. Tom -
Modified Embossing Not Making A Strong Impression
Northmount replied to jimmy eng's topic in How Do I Do That?
Fixed it for you! Tom- 8 replies
- emboss
- drill press
(and 3 more)
Sewing Machine Set Up Problems... At Witts End...
Northmount replied to Cole's topic in Leather Sewing Machines
I assume you mean oz. instead of lbs? Tom -
Best Type Of Metal For Belt Buckle? Where To Buy?
Northmount replied to zaynexpetty's topic in Hardware and Accessories
Quoted: I actually checked that site out. To shop on OTB do you have to have a business ID number or anything? I heard that you dont, but I'm not sure how to order otherwise. End quote. I understand from other threads that OTB requires a fairly large order as your first order. Even if you show a business license. I have no experience with OTB. Tom -
Juki Ls-341 Industrial Walking Foot Cylinder Bed
Northmount replied to buffalobill plus Ed D's topic in Old/Sold
Please see market place rules Tom -
What do you have for a heated stamp or carrier? Tom
- 8 replies
- arbor press
- bench tools
(and 1 more)
Here are a few you can check out. Note that some US suppliers ship to Canada via USPS which is much lower cost than shipping UPS or FedEx due to their brokerage charges. http://www.buckskinleather.com/default.asp http://www.longviewleather.com/ http://tundraleather.ca/index.php?main_page=contact_us So where in the province are you? Tom
Since you list the sewing machine in the title of the thread, I would put up a photo of it as a minimum. Tom
You must have read Tom Sawyer and Huck Finn when they were disguised as girls! Tom
Obviously you read the market place rules as you added to the thread before you posted these items. Please update your for sale postings accordingly. Tom
New Member With Zero Experience: Leather Questions
Northmount replied to Locry's topic in How Do I Do That?
Do a search here for wet molding and you will find lots of threads. Here is a pinned topic http://leatherworker.net/forum/index.php?showtopic=19782 Tom -
Looking good! I've only rinsed off the surface. Had no problems after. It is a fairly weak acid so gets "used up" quickly. I occasionally treat pieces of leather that don't have an even colour. It usually helps. Tom
