I have a Mazda car - are parts available? How can we know without knowing what kind of Dürkopp machine you are talking about - at least one good picture would help (maybe). The ability to sew leather means nothing - all sewing machines can sew leather. Without any further information no one can help you.
Carpal Tunnel And Leatherwork
Constabulary replied to Leatherbyelaine's topic in Leatherwork Conversation
I´m not hand sewing but have CT issues in both wrists. What helped me are cortisone in injections directly into the writs every 3 - 6 month depending on if I have issues or not. So it was not a therapy but the injections last for at least 3 month (in my case) I know sometime cortisone is considered as "bad" but as alway it depends on the dose. For some reasons it became better the last few month but I still feel it when I do a lot of handwork (in general). I haven't´s had injections at least for 10 month. The "stuff" is called DIPROSONE DEPOT and comes in 1ml ampules. Don´t know if you have the same stuff in the US but I´m sure you have something similar. And believe it or not even my pollinosis became better during the season. -
Show & Tell: Table-Top Portable Setup For Adler 69
Constabulary replied to Uwe's topic in Leather Sewing Machines
or put a smaller pulley on the winder -
Nice idea again but how do you wind the bobbins? Does the winder fit on the small board? -
Well, not really "the" holy grale but when setup well these are rock solid machiens that will last for decades. The 111W155 has no reverse by the way
Do I Have A "complete" Busm / Pearson #6 - Or What?
Constabulary replied to Constabulary's topic in Leather Sewing Machines
Disassembled the head yesterday now I need a freekin squared wrench for removing the shaft and cam - some pictures -
agree - I guess the Consew 206 is about the same machine - just for comparison. $350 sounds quite good if just the timing is off.
I´d buy the Juki and install a servo motor because of the availability of accessories and parts for the 563. You can use the Singer 111 feet which are quite cheap and a lot of other Singer 111 parts fit this machine as well. Pfaff accessories are more expensive. I´d also rather buy the Juki 563 than the consew 206 because I like the drop in bobbin of the 563. Just my 2 cents
Just for the case someone is interested. They are not mine I just stumbled over the auction. http://www.ebay.de/itm/205-alte-Leder-Werkzeuge-30-3-Kg-Schuhmacher-Schuster-Sattler-Riemer-Taschner-/331666394860?
Singer 111W155 Arm Shaft Bushing Will Not Come Out
Constabulary replied to tammythefactory's topic in Leather Sewing Machines
- 23 replies
I once was in the same situation. The bearing was so unbelievable tight. I have used a heavy screw driver first and and then a boasting chisel. Left some ugly marks but at least it worked.- 23 replies
You want to remove just the bobbin not the whole shuttle, right? Put a screw driver between the shuttle housing and the small tab left of the housing then push the screw driver carefully to the left.
Tinkering Uwe - cool idea again! Now everybody is waiting for the parts list / shopping list. I´m not an electronic buff but maybe with the Version 2.0 you can add a filler tab that pops back when the bobbin is full and a micro switch to stop the motor Just an idea I have no clue if and how it could work but since you are doing a lot of tinkering why not.
Original Pearson / Busmc #6 Shuttle + Bobbin
Constabulary replied to Constabulary's topic in Old/Sold
Need some $ for new projects - Price reduced: shuttle + bobbin as described above $180 + shipping -
Presser Feet + Needle Guides For Busmc 6 Hm / Pearson #6
Need some $ for new projects - Prices reduced: all presser feet $40 each all needles guide $60 each shuttle box cover $40 all prices w/o shipping - I take Paypal - shipping will be by registered Airmail trackabel through the USPS website (for shipping to the USA) or all parts together (4 feet + 2 Guides + shuttle box cover) $300 including fully insured worldwide Airmail. -
Pfaff 345 Stitching Length Problem
Constabulary replied to Oakley's topic in Leather Sewing Machines
maybe it is factory set to this stitch length - I´d try to disassemble the adjustment knob maybe there is just something clogged up. I´d also remove the plate left of the knob and check if something blocks the knob. -
I underestimated the weight - I just put them all in a carton and on a scale and it weights 17.5 Kg / approx. 39 pounds. So DHL shipping for the whole lot would be $110 to the US and Canada, approx 45€ inside the EU, approx 60€ Europe (non EU countries). I have checked what a pair of heels costs on Ebay and they range between $3 for small and up to $8 for larger heel pairs. Most of them are larger size and can be cut or grind down if too large (I guess). I estimate 250 - 300 heels / 125 - 150 pairs - maybe more. So how about $60 for the entire lot + shipping? Could be a good deal if one can use them or probably resell them when you assume a price of $4 for a pair. A stack is about 15 heels so when you guesstimate then there are more than 300 heels I´d say - check the 1st picture - this shows the entire lot + I have some loose I will trow in.
I don´t know for what shoe size they are for but the cabinet compartments have number and most heels have matching number (see pictures). The larger the number the larger the heel size. Hope that helps. I just took the heels of the cabinet and taped the stack together. I will weight them later today but I think it is approx 10 - 15 pounds of heels.
I think it is called heat shrink tubing or heat shrink wrap in the US
- 5 replies
- sewing machine
- singer 29-4
(and 1 more)
will do - when ever I see an interesting or strange patcher on Ebay or elsewhere.
I had the chance to purchase a vintage CONTINENTAL wall cabinet incl. huge a lot of rubber heels. Approx. 250 - 300 pieces, various sizes. Most are made by NORA / Continental . They are still pliable and still have the rubber smell. I have no use for the heels I just wanted the cabinet so I wonder if someone would be interested in them. I´d like to sell them all at once - I open for offers.
The teeth are quite important for feeding the material. I´d try some shrinking hose before you file down the foot
- 5 replies
- sewing machine
- singer 29-4
(and 1 more)
I would not say a hell of a time but you have to drill 2 holes and tap 2 threads - thats it. I have flip down guide on my 111G156 which is the same as your but mine has reverse. You just need the correct adapter for the machine I bought this one, it comes with a roller and straight guide and and it works well: https://www.college-sewing.co.uk/KG1245-DROP-GUIDE-PFAFF-1245%2c1246%2c1525%2c1526%2c335%2c591 Some pictures:
- 10 replies
- 111w155
- stitching guide
(and 3 more)
The Jack manuals are a pain in TA - poor English and the pictures are not correct but anyway I can help you out. Please send me your Email address by PN and I will send you a PDF. It´s too big to attach.
