Everything posted by Bigfoote
Fredk is right, that is two stamps. Look closely they vary, stamps don't change shape.
There are three topics that are best avoided on leather working forums, Sharpening, Oiling, and Gluing! Best to find out what works best for you and use it. There are no right or wrong in these topics, just differing opinions.
I use Rhynowet sand paper to sharpen my tools all the time. 800 grit is great to start with but way too coarse to finish. I use 2500 to finish my tools with. when you get your tools real sharp, strop them every use and then you won't have to sharpen ever.
try some JB weld, any hardware carries it.
I gave up on Barge, too many fumes. I use a bunch of different latex based ones, they all work great!
I use 3-4oz for exterior, 1oz for interiors, 4oz for interiors is way too thick.
First attempt at a Ranger Belt
Bigfoote replied to Alamo's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Nicely done! -
Single Six Holster
Bigfoote replied to JWheeler331's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I'm sure he will like it! Looks great! -
Perfect chisel holes and stitching lines ?
Bigfoote replied to Wisdomsleather's topic in How Do I Do That?
You have to make sure your holding your chisel straight up and down, don't lean it or the back will be out of line. The backing isn't that important. Cut a small wood block, and use it to hold your chisel 90 degrees to your leather until you get used to holding it properly. -
Fiebings pro dye solved all these problems for me. The USMC black bleeds a lot so stay away from it.
Yes open a Canadian site, would be awesome!
Wow, nice job! What more can you say???
I'm confused about the purpose of some of these products
Bigfoote replied to Chris623's topic in Getting Started
Everyone has a slightly different technique, and method of antiquing and use of other products. You have to do a little experimenting and find out what works for you, then stick with your process. I use gel antique for dye, have for years because it works for me. I also use resolene for a resist, and top coat, but others use different products. Whatever works for you is the proper method, and you won't find that process unless you mess around a bit. That is what that big pile of scrap leather is for, and if you don't have any, most leather shops sell small chunks of leather cheap. -
How to do stitch on side of ring holder for strength
Bigfoote replied to JeannieH's topic in How Do I Do That?
Start in the middle, between the two layers, leave a tag end about two inches, go through one layer to come out one side, two or three rounds through both layers, end up coming out in the middle between the layers, then continue over to the opposite side, come out one side or the other, go around two or three times through both layers, and end up coming out in the middle between both layers. Take the end of your thread and make a reef knot with the tag you left when you started. The knot will be hidden between the two layers and as long as you tie a good knot will never come undone or be seen. Done with one needle, hope this helps. -
It's 8 Oz leather, don't think it will be a problem. It's also glued.
Resolene.
Thanks guys!
Bond Arms Driving Holster
Bigfoote replied to Rohn's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Wow Rohn, that is a beauty, really like the lace on that, cute little gun! -
Finished this up the other day, WC 8oz, medium brown Eco Flo gel antique, sewn with tiger thread. I think it turned out great!
Passport holders
Bigfoote replied to ABR's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Punch a row of holes in a piece of Tyvek and try to rip it, bet you won't be able to. It's pretty tough. I really don't trust just the tape either, but lots of makers do and it seems to work. I sew mine with a 5 SPI chisel, not so many holes, and quick! -
I have a set the same. The black paint doesn't help them slide out, actually seems to make them stick. I sanded mine with 600 grit, then 800 grit till they were bare metal, then use beeswax on them fairly often. I also strop them every once in a while. They work fine now.
I'm not a carver, I'm a stamper! Haven't done any carving at all, but did watch Don's videos and thought I'm bored, hey why not give it a try? I don't have half the tools he recommends, don't even have a flower center, lol. I have been doing leather for many years and consider myself fairly good. Any way just for a laugh here is my take on this pattern. I'm not going to buy any more carving tools because I don't really enjoy carving. Not looking for corrective criticism because I won't be doing this again for a while. That all said Don's a pretty good teacher.
- 23 replies
- floral carving
- tooling
- (and 8 more)
Cold coffee as a measure of concentration
Bigfoote replied to bermudahwin's topic in All About Us and Off Topic
