Everything posted by cradom
Been thinking about getting one of those machines myself. They sell manuals separate on the Bay too.. Ought to work ok for lined belts and stuff.
- 39 replies
- able290
- chinese shoe patcher
(and 1 more)
Hello from the Beaumont/Port Arthur area Firewalker! Glad to have you with us, and Happy New Year!
Interesting, I might make some. Are you using the hook snaps on the belt loops? Think hard about the brass ring. Lying down on the floor or against a wall might be painful. Or is that the point? Oh wrong forum for that...
My "shop" in what was going to be a nursery for the previous owners. Need to repaint. The metal is a little noisy but should last forever, it's stainless. Neat tip, that yellow jar is a Bayer lo-dose aspirin bottle. Works great for a glue bottle. Drill a hole for a metal parts brush in the top. What you cant see under the top is a Harbor Freight arbor press and LOTS of rags.
cowboy holster belt not just a 1 1/2 belt
cradom replied to OLDNSLOW's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Best Finish for Belts
cradom replied to steelhawk's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I use Mop&Glo cut 50/50 with water, then neutral shoe polish. -
From the top of the slotted plate to the part which holds the ram (the ram can go higher) is 4 3/4 inches. The plate is roughly 5/8in thick, not including the pin on the bottom that holds it in place. If you drill a hole deep enough in the ram, tool length shouldn't be much of a problem, unless it's a really long tool.
Hair-on Belt
cradom replied to Rolandranch's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I think it looks fantastic. Good job.- 16 replies
Filligree blade is used to cut completely through the leather so the piece under it can show through. https://www.google.com/search?q=filigree+leather&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwjEvL_5qMbXAhXGxlQKHc74Dv8QsAQIMQ&biw=1920&bih=919 Hollow ground is pretty much a normal blade. Hollow ground refers to the way it's ground into it's final shape. (scroll down) http://www.raphaelstoday.com/Pages/RightToolsForTheJob.aspx Angle blade is used for fine detail work. It's usually smaller and ground to a sharper angle than a regular blade, which is flat. https://www.google.com/search?biw=1920&bih=919&tbm=isch&sa=1&ei=2jUPWu3CBuvBjwTa4KmQBQ&q=angle+blade+swivel+knife+blade&oq=angle+blade+swivel+knife+blade&gs_l=psy-ab.3...11700.22025.0.22528.13.13.0.0.0.0.135.1452.1j12.13.0....0...1.1.64.psy-ab..0.1.134...0i30k1j0i8i30k1.0.J28siySFPFM There used to be what I called a hair blade, which was wide and made little lines in a row so it looked like hair. Don't know if they still make this. (I guess they do) http://goodsjapan.com/leather-craft-slanted-22mm-filigree-hair-blade-for-tandy-swivel-knife-narrow-450-p.asp
- 1 reply
- swivel knife blades
- blades
(and 1 more)
Guitar Strap 'How to' and Free Pattern
cradom replied to JimDavies's topic in Patterns and Templates
Thanks for the pattern. However, Firefox throws up a warning about phishing and malware being redirected to a Youtube site? -
Unless the stones have a pin incorporated (glued to the back) you'll be better off using some kind of bezel. Check jeweler suppliers and craft places. These can be riveted or sewn to the leather after the gem is set into it.
Does it still have the original cover on? If yes, make a pattern. Or go to walmart and get the cheapest cover you can find and deconstruct it.
What to use to seal leather after stamping & dying
cradom replied to Curlywolf's topic in Leatherwork Conversation
Just an FYI: click Submit and wait. This forum is fairly slow. You have 3 posts in a row of the same thing. -
Grainger has 90lb load snaps: https://www.grainger.com/product/GRAINGER-APPROVED-Round-Eye-Swivel-Snap-WP43830/_/N-mfi?breadcrumbCatId=4492&s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/4PB86_AS01?$smthumb$
Always worth a try...
Is French chalk the same as soapstone? I got some with a holder. Looking for new uses.
Nice! Those boots look exactly like mine: Ariat, made in China? Comfortable as heck but I wish I'd seen the label first. They were a gift. Is that dragonfly a stamp? or carved?
In search of Baroque Bridle hardware and adornments
cradom replied to BaroqueLeatherGal's topic in Hardware and Accessories
The cabochon settings, maybe someplace like: https://www.pandahall.com/wholesale-cabochon-settings/701.html Also try these: https://www.google.com/search?q=cabochon+mounts&oq=caboc+mounts&gs_l=psy-ab.1.0.0i7i30k1l2j0i8i7i30k1l2j0i7i5i30k1.9681.9681.0.12154.1.1.0.0.0.0.138.138.0j1.1.0....0...1.1.64.psy-ab..0.1.137....0.Uy7bxMu0y8A Might have some luck with some jewelry suppliers. -
Just a question out of curiosity: those scalloped pieces under the conchos, are those edges burnished and if so, how difficult is that? Excellent work by the way!
And I just bought a 6 slot pattern last week Thanks a lot for the share!
Vegetable tanned watch strap lining and sweat?
cradom replied to doingmahresearch's topic in How Do I Do That?
In case anyone was wondering, 真京底 translates at Google to "Really Jing off the end". I got nothing... -
Not to take away from all the cut punches (good idea by the way) but wouldn't something like that be done with a clicker die?
Here's one I built last year. Nothing fancy but I can sit in my desk chair without being hunched over. It's 31in high, the jaws are about 5in wide. https://photos.app.goo.gl/c1LLbIgOBWbA4GRs1
