CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. I sure WISHED we could but there's no way to know what belt to send,they need to install the reducer,measure the length needed & buy them locally @ an auto parts or lawnmower shop.
  2. The parts are crazy high $$ the above parts are $728.00
  3. From what I have found is the longer "horn" is for thinner thread when sewing lightweight materials,size # 69 & larger works better without it.If you look & Juki 563,Singer 111w hooks some have a finger on the gib that releases the thread later & the "heavy duty" hook does not & it will release the thread sooner which helps to pull up the needle thread for a better looking tension.
  4. On the front there's 3 oil holes marked red,the 2nd one down on the rightside has a tube with an oil wick in it that wraps around the top of a bushing,somehow it got unwrapped & fell down.Try to follow it to the other end & you'll see where it comes out of the tube.
  5. Our chart also shows you what size needle to use for the thread size.https://tolindsewmach.com/thread-chart.html
  6. Should sew a good 20oz,5/16" or 8mm,using up to size 138 thread.
  7. Hopping foot with needlefeed.
  8. Nice find,I've never seen an early tension like that,did all the older ones have the higher mounted bobbin winders too?
  9. Lookup Vais Sewing Machine,he's in Brooklyn 1129 McDonald Av,that Pfaff is a better machine that has a higher lift .Some of the screws & other parts have been discontinued for the 211 & it has a small handwheel on it that makes it hard to slow down.
  10. I used to work for an ex-Singer salesman & he told me when they demonstrated them they would sew through a wooden yardstick to impress people with the power.They were such a good machine that when they started selling the newer Touch & Sews (with plastic gears that break) they took them in on trade, then out in the alley & busted them up w/a sledge to get them off the market.
  11. It's not an easy lob & the bigger problem is finding a replacement shaft.Parts for these old Singers have been discontinued yrs ago.The best thing to try is to straighten it.Turn it so the high side is @ the top,take the wheel off,get a piece of thickwall pipe 2-3' long & put it on the shaft & push down,reinstall the wheel &see how it looks,it might take a few times.
  12. Ok,I see what it is now & we have the bobbin cases in stock.Give me a call if you still need one.
  13. When we used to sell these little machines we tried getting these to lift higher & found out it can't be done.
  14. We have found the best way to fix it is put some bronze on the on the tongue using a torch(Brazing it) that fits in the ring & file it off so it's a tight fit.
  15. Ferdco's are usually good machines BUT they would buy them from a manufacture & take off the model# & makeup their own which is ok until now they closed up,their website is down & there's no way to know what you have unless you can post a pic.Or unless someone else chimes in that just happens to have the same model.
  16. Here's a manual. class_7_one_needle_lock_stitch.pdf
  17. Not because we are a Juki dealer but I will have to concur with Wiz the Juki is a way better built machine than the Sailrite & will sew thicker & hold up better to the stress of heavier leather,it should sew an easy 5/16" or 20 oz.
  18. You didn't post the bobbin size,but if it's a large bobbin it would be a 287RB the B stand for large bobbin,the older 287's with a small bobbin & reverse were 287R.This looks like triple feed to me.
  19. Glad to hear you got it going!They are a great machine for smaller thread & thinner leather.
  20. This is a home machine.You might be able to sew some thin leather like for wallets a couple of layers of 2-3 oz. using size #46 or 69 thread.,I'm guessing 13 & 3/4" might work but measure around the pulleys with some string to be sure.There is some adjustment on the bolt that holds the motor on to tighten the belt.
  21. You might try decreasing the travel of the check spring(raise the bracket up) & like Wiz said the timing could be alittle slow causing it to drag.
  22. @michaelcbarr So what size & type of thread is this?
  23. Have you tried increasing the foot pressure?
  24. @miker It looks like this manual should work for you. CB8810_oper_man.pdf
  25. This is the problem,you need to move the collar ( has an arrow on it & one set screw) by the bearing on the rightside so you have close to 0 movement east & west.
