Grease dries up overtime & there's rollers in the cams which the grease can pile up on & stop a roller from turning & will eventually wear a flat spot into it..Only grease gears. Also only oil can get into the inside of a roller.
I would recommend only using sewing machine oil on the top part of it as all motor oils have additives in them that will stain your leather if it splatters on it.Standard sewing machine oil is a clear mineral oil w/o any additives & doesn't stain.You could lube the rollers & cams underneath with motor oil or a mixture it won't hurt, BUT don't ever use grease anywhere in this machine.
It comes with great sadness.I wanted to let everyone know that Greg O'Neill of Keystone Sewing Machine passed away last Monday.
He just lost both of his parents last year to covid.He sure will be missed.They say he was in great shape but had a massive heart attack.
https://www.legacy.com/obituaries/courierpostonline/obituary.aspx?n=gregg-j-oneill&pid=198075328&fhid=9325
With the outside foot resting on the needle plate & the inside foot raised loosen the 2-screws that hold this assembly on the back pressure bar & drop it down 3/16" & then re-adjust the shaft on top in the back.
When sewing leather most people want as small of a needle hole as possible,that is what our chart is for.Your 42-5 has the barrel shuttle & you shouldn't have a problem sewing 207 w/a#23 as long as your bobbin tension is loose enough.As others have pointed out some times you might need a larger than recommended needle for stiffer leathers which also may require more foot pressure to hold on also.We do stock the 135x16 up to size#25.
One more thing are you sure you wrap your thread around the second tension 1 & 1/2 x?
We've done quite a few of them back in the day the 563 hook is taller so that is why you need to mill the upper part ,I forgot how much it was,but there's no grinding or anything underneath,as Grag said using a 563 saddle is the easiest way.
Loosen the small slotted screw & turn the hex-headed bolt that is like a worm gear.It's been a while since I worked on one & forgot which way is longer .
They had a couple of different models & of course the adjustment is different between them so show a pic of the lower area below & to the right of the shuttle.
The 42-5 has a lifting cam that lifts the feet underneath the end cover,the 31K47 has a cam on the top shaft(and rod on back) that makes both feet lift as they walk.So yes the both are spring loaded walking aka hopping feet.They both need the feedog to pull the outside foot back.The feet don't interchange between this 2-models the 42 & 16 class use the same feet.
You need more foot pressure to hold the leather down or try to hold with your hand as all machine won't sew correctly if the material is lifted while your sewing,if it's an old dried out piece of leather you need to oil or wet it to soften it up.
The group on FB is China Leather Shoe Patcher
