You mainly need to lube the thread For 3 reasons I can think of is when your sewing real fast,it helps cool the needle so you don't burn the thread,#2 if your sewing dry & or old leather & #3 is when the leather is real thick or if your thickness close to the max for your machine it prevents skipped stitches.
I just sold a CB4500 yesterday to a customer that bought a 3200 a year or so ago & he got into heavier sewing than what the CB3200 could handle & he wants to sell it,He's in VA by DC.If your interested give me a call or message me for his ph#,I don't want to post it here.
Hey Jeff,
Thanks for the kind words,glad you got it so quick.
We do as hard as we try not to make a mistake once in a while like anyone can BUT we work on them & TRY not to do it again.
Thanks, for your order.
Bob
It's a Rex 26-188 a copy of the Singer 16-188 on the Rex has reverse.Yes it's good for upholstery,canvas & thin leather.Most parts & feet are still available for it.I guess the price $3-450.00 BUT you'll probably have to buy a servo motor so you can control the speed approx $135.00
Ok,so the only cam to adjust for the hook is the one on the left that takes a 6mm.IF it isn't correct you turn it one way & will notice it'll get closer or further away from the way it's supposed to be.
I hope you can understand this,i'll try to explain this the best I can.The cam on the top shaft for the shuttle timing needs to be adjusted so that when you turn the machine & the needle bar is all the way down the shuttle is all the way back & coming forward just as the needle bar is coming up.Now when you do this you need to run the needle bar all the way down & watch it come up & then turn it backwards so that when the needle bar is all the way down & you turn the handwheel 2" either way it stars to come forward a the same position when the bar is all the way down.It helps to put the stitch length on 0.
Looping is almost always upper tension.Double check that you have the thread wrapped around the second tension 1&1/2x.
It's looping because the upper thread tension is too loose.
Yes,it is a nice looking machine BUT the price is about 2x what it should be & the biggest problem for this machine like a lot of the older ones is getting parts,we do stock needles & awls but that's all you can buy for it.
If you want to sew over a 1" you better get a 97-10.The Singer 7 head needs to be cut under where the needle comes out & a longer than standard needle is used.For the reverse we took all the stitch length parts out & had a special bracket made that goes out the back & also had to heat & bend the feed back to make it go back in the same holes,which was hit or miss because the feed dogs might not get a good grip causing the length to vary.That is the advantage of a walking foot needlefeed.
