Everything posted by RockyAussie
Here you go I think the pictures should cover it ... After doing the first one on the top left and tapping the hole for the small threaded ones I got a bit smarter and did the 2nd one one the right so that it could receive the larger threaded one below it or the ones without thread as on the far right.
Hey @dikman if you can be patient enough for a few hours I will take some pictures of a set up I've done here. Basically it allows me to do a quick change over for whatever the thread type of the die required or even in some cases some with no thread at all.
It may be just something optical but is the feed dog angled to the right? If it is rubbing the edges perhaps on the needle plate may cause some noise. I generally put a couple of drops of oil down into the hook bobbin case area between every 2 or 3 bobbin changes. You will note a quieter change every time you do this.
Very nice work there paloma
I have seen this statement before but nothing that comes even close to backing it up when it comes to the landed cost. Sending it back and getting any further satisfaction would also be I suspect another pie in the sky.
Men's belt wallet combo
RockyAussie replied to Albob's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Sorry we call them keepers and some call them belt retainers. The loop that holds down the tongue after the belt tip goes through the buckle is what I call a belt keeper normally. -
Thanks for sharing your efforts with us all. Have you made one up yet and have you got any pictures to show?
Dedicated wallet machine advice
RockyAussie replied to guntechholsters's topic in Leather Sewing Machines
Ha Ha...... best she doesn't see that link down the bottom here to my "Wild Harry" web site then A? -
Nice looking work there @Albob.The stitching on the belt looks very good but the keeper....not so much. When I do keepers I always back off the top tension at least a half turn compared to the belt. They can still look good when they are out flat but when they get pulled around into shape the bottom thread gets loosened and the top gets tightened and ......bugga. I believe it is best to set the knot as close to the bottom as possible on keepers. Regards Brian -
I am more than glad for you to pick my brain for whatever there is there left to be picked. You can do that here or through pm on here if you like but I don't do the Facebook stuff myself. Maybe FB one day but most of my spare time and interest gets put into this LW site at present. I like that it gives help to many others all over the world and allows for other perspective and useful ideas to be considered at the same time as is shown above. -
Most of my wallets are not flat and I like to stitch them fully around....Same with most of my purses ...therefore my reason for preferring the small cylinder arms. -
I would recommend to look for a pfaff 335 or clone of or a 69 Adler. The small cylinder cap size come in very handy for the type of tight manoeuvring steps. The Adler 669 is very popular but a little high $$$$$ perhaps - https://www.weaverleathersupply.com/catalog/item-detail/669-180010/adler-669-cylinder-arm-sewing/pr_34772 The Techsew may suit as well - https://www.techsew.com/us/techsew-2600-narrow-cylinder-leather-industrial-sewing-machine.html and there is one in the Cowboy range as well called the 7335 -
Thanks jimi
I would have to say that for the job your describing here the 18 needle and 69 thread would be fine and the available thread size colours a bigger range as well. If you are doing more thicker and uneven leather layers than going with a bigger needle and thread is recommended as the needle will not deflect as much and give uneven looking back stitching as well as less missed stitches. Congrats on the new machine and I suggest spending a day on practising and getting to know it.
Hard to get details for certain but for holster work I think you'll need the class 3 but as the leather point needles go up from size 23 your threads would need to go 138 or larger. for some wallet work that probably won't work. Class 3 =7/8" thickness possible,threads up to 415. Class 26= 1/2" thickness possible, threads go from 45 to 210. (Should cover most of your stuff I think) I cant swear by these details but lets see if I got it wrong.
Hey @jimi can I ask if you ever got any price for the Frobana presser foot wear piece from them or anywhere? I got something like 4 Frobana's here and every one of them needs one.
All I am trying to say is that an attached lining piece will stiffen the lid front and help to stop it from going all curly in use. I don't myself generally get to design for plain leather products (non exotics) and therefore generally have to do full leather linings but that does not escape the need to stiffen the lid section anyway. I will put a few pics below showing how I do the lid flap stiffening normally if that helps. I picked this bag as it has a single magnetic closure in under the brand fitting- Note that the lid in this case must be able to stay stiff enough to take the constant opening and closing over a wide area - Inside showing the closure - Showing the stiffener and foam lining that gets attached to the croc- This one shows on the far right the leather lining that is oversized to start with. It gets glued and attached after the handle is stitched on and then trimmed down afterwards and edge coated. I am only suggesting to attach a liner to the inside of the lid flap on yours. I recommend that this liner be attached so that it is a little tight going across to keep the flap pulling inward very slightly. This can also be done as an inner lid pocket if you prefer.
Set up CB 3500 for light work or buy dedicated flat bed?
RockyAussie replied to cpirtle's topic in Leather Sewing Machines
Very well done show piece of both the machines and the operator's quality I believe. I think using a cylinder machine for getting around those rounded corners is a lot easier than using a flat bed but I just hate using flatbeds myself for almost anything except long lines of fabric credit card pockets bottoms and stuff like that. -
Singer 29K60 Walking Foot Not Lifting
RockyAussie replied to Superduty's topic in Leather Sewing Machines
Probably nothing to do with it but I don't recall ever seeing the screws that hold the head on sticking out like that except for once. That once was where this complete novice believed that this was how you should adjust the needle to be closer to the hook. Amazingly he would not let me show him where the needle should be adjusted from..... -
My first purse
So very well put. -
Looking for a 3/4” binder for leather binding tape
RockyAussie replied to JeannieH's topic in Old/Sold
It does work better if the leather has been split or run through a skiver as that tends to make it a little more slippery smooth and less friction going through. I have found that the leather can actually go through and stitch better than a lot of the tapes they make and can accept the inward curves better due to the leather being able to stretch more. JeannieH has a skiver If I remember so that should not be much of an issue. -
My first purse
Can I assume that the gusset is done in one piece? I suspect so by the rounding at the corners at the base. There is an easy design change that can make that work a lot easier if you are interested, I can put in a couple of pictures with some description if you like. The other thing is what foot and needle plate combination did you use? I am guessing that you don't have a narrow feed dog /needle plate set and that you may have used the narrow slotted needle plate without feed dog and perhaps a left back foot.....or? A picture would be great if possible. -
My first purse
Do you mean 2500 or 3200 Cowboy? Very nice tooling and colour but as you said the stitching is not so good. I am curious as to whether you had no guide or just what gave you this problem. I do very much like the tooling as I said but if I can help with the sewing part with any tips I would if I knew which machine you are using. P.S> I am only 62 yr as well though.
