Hildebrand
Everything posted by Hildebrand
  1. The problem here is you have to have your snap location exactly where you want it before you glue the liner in. I just use a plastic screw head insert from the cabinet screw section of the big box hardware stores.
  2. Not local but spent 3 years with a Boss. What kind of issues are you having? Todd
  3. I just had the same thing happen with Strapworks. I needed some 3" plastic slides and they were the only ones that had them, it cost $7.50 for the slides and $8.00 for postage. Like above I just ordered more to drop the per item postage a bit. Todd
  4. I am going to offer a different perspective. As stated above you really don't know yet if the cheaper tools won't get the job done for you. My personal opinion is there is a small percentage of people who tool leather that will actually notice the difference in the tools or people will notice a difference in the quality of their work based on the tools used. I would buy the cheaper tools learn the craft then decide if a more expensive tool will make the project better or would the money be better spent on additional tools, for me its been the money is better spent on more tools so I can accomplish more things. Maybe at some point in the future my carving/stamping skills will reach a level that the tool matters but not yet. Todd
  5. I have watched a ton of utube videos and they are really hit and miss for leather. Stock and Barrel has some good ones but also some real clunkers. The sewing machine "review" videos I have came across are pretty lame no matter who the star is. I second reading the various threads here, if a machine is good you will see it and if it is not good you will see it. Todd
  6. Just worked on 3 tonight. I use 4-5 oz for the loops. Todd
  7. Looks good. What part of WY are you in? Welcome to the forum, there is a ton of great information here. Todd
  8. Congratulations, no tips or tricks I have found yet. I just enjoy the heck out of mine.
  9. Kbarker not sure where in MT you are but I would look to come to the Sheridan, WY leather show in May. There will be a lot of leather people and venders there so you could look at a lot of things first hand.
  10. Not sure where you are at but I have had good luck using the disposable stain applicators from the big box home improvement stores they are about 3X5 inches and come in packs of about 6. I can get a much more even coat with them than I can with daubers.
  11. If you are going to try this with the Dremel you will need to have a shaft supported at both ends, that will eliminate the lateral pressure on the bearings provided the Dremel itself is supported or the shaft attachment is used.
  12. From reading and research on here I think most that mold first hand sew. If you are making holsters I would really look to the powered machines. I started with a Tippman Boss and yes I made some decent holsters and one belt, but since I moved up to a CB 4500 and have both hands to control the object being sewn I have been able to tackle some projects that I never would have with the Boss. Todd
  13. I appreciate the time you all put in. I was just thinking it was my machines since I hadn't seen a topic like this pop up. Todd
  14. Yintx, I will try to get a different picture tonight. Tugadude your right its a sandwich, I did burnish the edges of the small pieces where they go across the larger pieces but it just looks odd. I thought maybe there is something else people do different in this situation. Todd
  15. I have a question, how do you guys finish edges that are different lengths? I am building a cartridge holder that will strap to the arm, the current version is 3 layers, front, back and the middle layer makes up the wrap around strap. On this version I burnished the edges of the top and bottom where they pass over the middle, it looks ok but a little off. I was wondering if someone had a different idea. I may look at making the back and the wrap around one piece on the next one. Thanks Todd
  16. JLS, I lost the quote I wanted but I think the video you posted from Sam with the deep voice is the best information on making the "Flat Back" style of pancake holster. He shows how he uses a piece of leather to go over the gun at several points marking it at each one then uses those marks to lay out his sticking lines. Todd
  17. There is a write up on here about the adjustments that have to be made going from the regular pressor foot to the inline one. I am pretty sure it’s not a cowboy vs Juki thing it’s the regular vs inline differences.
  18. I think this has been discussed here before and the general consensus was that by the time you get all the measurements and spend the time printing the gun and tweaking it to make sure its exactly right it is just cheaper and easier to buy the blue guns. Todd
  19. I am no expert but I have found that really slowing down and making sure the stamp placement is exactly where I want it helps. Also I try to stamp at a repeatable angle to a reference line, for example I have basket stamped a couple of holsters and I do 45 degrees from the vertical line at the front edge of the holster. I use a plastic triangle and lightly scribe lines to line the stamps on, sometimes each row sometimes every couple of rows. Also I have started using one of the round combination magnifying glass and light, this really helps with stamp placement. I have found both slowing down and using scribed lines when there is any doubt about where to put the stamp really helps. Todd
  20. Thank you Jeff, that is exactly the one I was remembering.
  21. I know this has been covered before but I cannot find the thread with the search function. There was a thread which showed step by step the order to sew a IWB holster with a stiffener around the opening. If someone remembers that thread and can point me to it I would greatly appreciate it. Thanks, Todd
  22. I will take them for the $230. I will pm when I get to work to get payment details. Todd
  23. Unfortunately that logo means a lot. I have seen women lose their ever loving mind over a name brand wallet or purse. Usually not that well made.
  24. There are a few things that I have found to help get a pattern right the first time, the first holster I made I couldn't even get the gun in after I sewed it up. First I try to draw up a pattern over a few days. It always seems like when I walk away for awhile and come back I see something I want to change just a little. Seems like if I do it in stages the overall finished product comes out better. Then when I have it where I think it is right, including the stitch lines I make a copy and cut it out and spray glue it to a piece of corrugated cardboard(pretty much mimics the thickness of leather)(I can't take credit for that tip I found it on here). Now wrap the cardboard with your pattern around your object and see if the stitch lines fall where they should, you can tweak it a little if they are off. This step can save a lot of leather, especially with holsters. I am only a little over a year back into this addiction called leather work. I have learned more on this forum than anywhere else. All I can say is there are some real masters of the craft here both the carving side and the holster/case side. Todd
  25. Any chance of seeing the back? I would like to see how you made and attach that wing on the back that your straps attach to. Great work. Thank you, Todd
