Burkhardt
Everything posted by Burkhardt
They are 5-6 inches wide but anything past a couple inches is a struggle. I tried to split a wallet back and I'll leave it at tried.
I hope you ordered all the obvious wear and tear parts because you can them dirt cheap when getting the machine. Hook, bobbins ect
Thin it with a little water if needed otherwise it's probably fine for edges or burnishing the flesh side. I have some that's a little runny and some that's really thick. Still works fine.
Can you refill the canister with air to re-use or is it one and done?
Transferring tooling patterns onto the leather
Burkhardt replied to TailGunner's topic in How Do I Do That?
One of the cheaper/easiest and good product is parchment paper. Yup, the kind for baking and such. -
@Northmount probably best to move to sewing machines if you would be so kind.
What was the experience with the veg oil that you wouldn't recommend for?
- 193 replies
- saddler recipe
- diy conditioner
- (and 4 more)
https://www.harborfreight.com/compact-bender-38470.html Have you looked at something like this? Type in bender and they have different options that could maybe what you're looking for.
Juki 1541 clone speed reducer issue
Burkhardt replied to bigsig11010's topic in Leather Sewing Machines
Post on youtube then provide the link. -
http://hermannoakleather.com/products-and-pricing/riverbend-latigo-20121231092650 Herman Oak says differently.
- 193 replies
- saddler recipe
- diy conditioner
- (and 4 more)
Is it for solid steel or a pipe?
Would a pipe bender be the same or do these specialize the widths of the bends and what not?
Why Is Woolskin Put On The Underside Of A Western Saddle?
Burkhardt replied to GrampaJoel's topic in Saddle Construction
That post was made over 12 years ago. -
Wallet template making more professional
Burkhardt replied to DieselTech's topic in Patterns and Templates
It's the issue on a lot of wallets where the issue of continuing the stitch becomes a problem. The thicker/bigger thread needs thicker leather to hide the knot when sewing then comes the jump from thicker to thinner will change the stitch length. Hand stitching is the fix but who wants to hand stitch when you got a sewing machine. When I do bill-folds I cut the dollar inside piece with the cc pockets less wide so I can do one continuous stitch all the way around. -
Help Salvage! - Blotchy after NF then Dip Dye
Burkhardt replied to DavidK's topic in How Do I Do That?
Granted, there is no exact way to do anything but I'd bet the majority of people oil first to allow the dye to be evenly applied There was a discussion just a few weeks ago where someone had a issue dip dyeing and several people had the same problem and some said it was the dye. -
Springfield Leather carries a pretty big selections of his stamps.
How could it not? The longer distance between each stitch will affect the top bottom pull because of the distance. A long stitch will be looser than a short one or are we not talking about the same thing? I'm looking at it as you do a long stitch on a curved seam and flip it inside out it's going to look loose where the shorter stitch will be tighter because of the distance.
Best place to buy industrial machines in the NYC area
Burkhardt replied to nycgirl's topic in Leather Sewing Machines
Local is nice but it's also a 2 way street meaning the local guy is going to tell you to bring it in and probably going to give you a bill after. The machines you're talking about are 100t pounds for the head. Someone like @CowboyBob or LMC have great customer service and are willing on here or the phone to help you through which ever issue you have. -
Pictures would be a good start.
