Burkhardt
Everything posted by Burkhardt
  1. A 26 will do 1/2 inch so easily what you're asking for both hat and harness.
  2. Enlarge the pic and look at the one on the right around the ostrich part.
  3. If you don't put a resist on something that big it will be black before you get the antique removed.
  4. That's a super score.
  5. Gotcha, the picking from the list is what I didn't get. Never noticed it wouldn't pick it up from not using list before. Learned something new.
  6. So you shouldn't do it the way I said too?
  7. You have to use the @ when tagging someone like @Tfhadley or @Ezik then they will get a notice to respond.
  8. You forgot to finish the edge on the one on the right and is the ostrich a veneer or did it cut really bad?
  9. Remove the needle plate and manually check to see if it's out of time before you start guessing if that's the problem. Have you checked if the needles bent, threaded correctly, ect?
  10. I made mine out of oak, cut the diameter out and used like a 1/8th inched sized hole and a little glue and a shingle nail. Perfect diameter for a Dremel and use the piece in the Dremel to sand and shape to size.
  11. For curiosities sake I'm guessing that it's got the HO stamping on it because that color looks more like what we would import veg tan. Your first pic looks like import and the second looks like HO.
  12. It would be cheaper to buy whole sides in the oz. you want then getting a splitter to do anything that wide. You'll be in hundreds just for one that will do belt widths.
  13. Well I have to say that I'm having crow for dinner because when you wrote you ordered on Tuesday and you got them on Wed I thought you were fos. I placed my order at 3:00p.m. on Thursday and said the order should be here on Tue. Fair enough, got up today (Friday) and noticed tracks in driveway and looked on my steps and there sat my order from BK.
  14. A really cheap and easy one to get is if you have somewhere near you that does stone countertops and get the cut outs from the holes for faucet and water handles.
  15. I finally have seen one of the don't ever use stamps part of the 20 you get online used and what a great look. Is that where you got yours from one of the 20 kits?
  16. It so strange when you think of something 5ft long that;s 10 degrees different is noticeable. But, when it's a 1/4in. you wouldn't think it would make much of a difference
  17. Have you ever used any 30 degree bevels before because I almost ordered a set from BK today? The reason, if you've ever watched Don Gonzales video he uses the 30 degree and had said don't get the extra steep ones. So I called him and talked about the pros and cons because I currently have and love a set of 40 degree (extra steep) checkered. I found out I had a 30 degree one (albeit smooth) and did a side by side and the width of the burnish and compression was noticeable. Had a nice gal from BK send me a picture of the 30 and there is such a tiny difference have you ever compared them?
  18. Off topic, whatever became of the stinky leather you had? Did the smell ever leave and were you able to use it?
  19. https://shop.dgsaddlery.com/products/rifle-saddle-scabbard-pattern-pack-printed
  20. Don't be chasing away people from here for Facebook unless you're going to post everything here also.
  21. Those 2 things can't happen at the same time.
  22. Does the tension change on shorter stitch lengths?
  23. Look up about a inch from your last comment and click on the little spot where it says here.
  24. For each person just hit the quote reply and it will show as many as you hit in a comment.
