Northmount
Moderator
  1. Added the photos in for Pete and deleted a couple posts that would no longer make sense. Tom
  2. Look for the same stamp numbers on eBay and see what they seem to be selling for. Some are of course worth a little more depending on how rare they are now. Tom
  3. Thicker seams tends to grab the needle and lift the presser foot on the up-stroke, collapsing the loop so the hook can't grab it. Try increasing the spring compression on the presser foot. Tom
  4. Did you check with Silverback above your post? Tom
  5. Really nice and great work, as always! Tom
  6. @toxo Moved your post to leather sewing machines. More likely to get answers here. Tom
  7. Before actually punching the hole, just press the punch down tight to leave a mark, but not cut. Lift the punch away to see if the mark left by the punch is centered on your markings. Tom
  8. Possibly your cutting surface is not perfectly flat as well. How do you keep your jacks in sync so they come down evenly and parallel to the cutting surface? You make have to release and cut multiple times to make up for the added tonnage needed. Tom
  9. @Ferryman Moved your post to Leatherwork Conversation as I think this is a better place for it and will get more exposure and more answers or info. Tom
  10. @MT Flyrod You appear to be in Missoula Montana area according to your IP address. It is a good idea to add your approximate location to your profile so you can get answers that are more appropriate for your area of the Solar System. Tom
  11. Looks really great. I have a couple roses I started a while ago but have been distracted by other things that had to be finished. I'd be interested in seeing how you have attached the stem and leaves. Also what material are you using for the stem? I picked up some florists tape and wire for the stems, but from what I can see, yours looks better than that would. Your comments and illustrations would be very helpful. Tom
  12. Nice job! Tom
  13. Interesting story. Thanks for posting. Tom
  14. Do a google search like this "site:leatherworker.net how much length to add for thicker belt" without the quotes. site:leatherworker.net restricts the search to this site. You can change the search string (words) to refine your search. If a term you don't like keeps popping up in your search, add it to the search string with a dash in front of it (-lazy). One of the posts the above search string found is A refinement to the search string could be remove thicker and add lined. Try different words if necessary to find or narrow the search. Tom
  15. Take the handle off and make sure it is well supported. Cast Iron doesn't do well when dropped! Tom
  16. This topic has been posted about a number of times. Have you tried a search? Mathematically speaking, the increase in outer circumference would be 2 x added thickness x pi (3.14). (back to basic math) Tom
  17. @Jacktheboatguy Moved your post - Even though you aren't sewing leather, you'll get more response in this area - Leather Sewing Machines. Tom
  18. @kimosabi66 Moved your post to Marketplace -items For Sale -Machinery -- Cutting/Leatherworking -Used All items for sale should be in the Marketplace area. Please read the Marketplace rules at https://leatherworker.net/forum/forum/70-announcements/ and comply with them. You need to provide photos, full descriptions, condition, etc. Members may reply here or by PM. Tom
  19. @OldRedMule Moved your post to Saddle Identification, Restoration & Repair. You should get more response here. Have you searched through this area? Tom
  20. Looks to be a heavily built machine compared to many. Try contacting https://www.facebook.com/pages/category/Product-Service/Jason-Systems-391906050959698/ Sees to be quite a few ads on the internet, from about 2016 and up. So doesn't seem to be a big seller. Tom
  21. Do you have a manual for your machine? There have been posts here about balancing the forward and reverse stitch lengths on some machines. Try a google search "site:leatherworker.net balance forward and reverse stitch length" without the quotes. You may need to adjust the search parameters by including your machine mfg and model. Tom
  22. @Jay6040 Have you read this post? Tom
  23. @Vladinard Moved your post to Leather Sewing Machines. Have you done a search for info here? Try a google search "site:leatherworker.net Junker & Ruh SD28" without the quotes and you will find several posts that reference them. Tom
  24. Presser foot pressure too low so the leather lifts a bit at times, loosing the loop so the hook can't grab it? How thick is the leather, hard or soft, thread and needle size? Tom
