Northmount
Moderator
  1. @Vladinard Moved your post to Leather Sewing Machines. Have you done a search for info here? Try a google search "site:leatherworker.net Junker & Ruh SD28" without the quotes and you will find several posts that reference them. Tom
  2. Presser foot pressure too low so the leather lifts a bit at times, loosing the loop so the hook can't grab it? How thick is the leather, hard or soft, thread and needle size? Tom
  3. Ed hasn't visited the site since July 13, 2017. @esantoro Tom
  4. @LeatherinCornwall Moved your post to Leather Sewing Machines! Tom
  5. @Jzamora21 Moved your post to Leather Sewing Machines. As Rocky says, you are more likely to get answers in this section. Tom
  6. URL / Link is fixed Tom
  7. Hack into it and set the throttle full bore max speed! Watch the operator with a built-in camera when the machine takes off. Tom
  8. I've seen some comments here about using deglaser to remove at least the surface oils and waxes. Another experiment for you? Tom
  9. Yay! Works for me! Tom
  10. If you set a permanent security cert exception, then all logins go right through with no warning. I'm still seeing it this morning. This is all part of the same problem. Tom
  11. Still being worked on to resolve. Tom
  12. I use a couple that sit on my table with the large holes. I group my tools and put like tools together. Tom
  13. It is being worked on. The hosting site was supposed to automatically update the security certificate, but it didn't, and of course it happens on the weekend when there is even less support. Tom
  14. Don't try using in a powered portable drill! Can wrap things up in a hurry! For powered use, use it in a drill press, and what ever material you are cutting should be clamped down securely. Tom
  15. The hosting service was supposed to automatically replace the certificate, but failed to. And it's a weekend with little or no support! Always the way it goes, right? Tom
  16. Have you tried a search? Found a few threads that should interest you. Do a google search "site:leatherworker.net baseball glove" without the quotes. Tom
  17. You are replying to a post that is from 2013. Doubt it is applicable anymore. If you are looking for contract work, maybe you should begin a new post with all the particulars. If you join the forum, you can use other areas to post in and not have to wait for moderator's approval. All posts in Help Wanted require approval. Tom
  18. There are several posts about burnishers using induction motors. Do a google search "site:leatherworker.net burnisher motor" without the quotes. Tom
  19. Moved your post from Help Wanted (which requires every post to be approved by a moderator) to Wanted (under marketplace). Tom
  20. @ScrapMonkey Moved your post to leather sewing machines. More sewing machine activity here. You may even find your answers in this forum as there have been many discussions about servo motor settings. Tom
  21. Try a google search like this "site:leatherworker.net video making holsters" without the quotes. You can modify the search string "video making holsters" to any parameters you wish. Google has huge search engines with billions of pages indexed. Faster and better searches than LW can do. Tom
  22. @guntechholsters have you read this thread? It will answer many of your questions. Tom
  23. Great job, both the lion and the video. Can't have too many examples to demonstrate real talent. Something for us to aspire to someday! Tom
  24. This chart might answer some of your questions relating needle size to thread size. Different thickness and temper of leather may require larger diameter needles. https://www.tolindsewmach.com/thread-chart.html Tom
  25. That specific pattern, or just looking for any? https://www.tandyleather.ca/en/product/craftool-embossing-wheels https://www.springfieldleather.com/tools/Hand-Tools/Embossing-Wheels These are just a couple results from a google search. Tom
