billybopp
Everything posted by billybopp
  1. Nigel Armitage on box stitching.
  2. Springfield Leather has shearling on sale right now for black Friday / cyber Monday at &10 and up. Be sure to give LWN a little love and go there through one of the links at the top of the page! Bill
  3. I used to maintain data processing equipment for a living - things like check reader/sorters that read the print on the bottom of a check at about 1600 items per minute, and sort them out into various pockets. One day, when I was still relatively new at it, my boss told me to bend a little lever arm a bit to correct a problem. I expressed my concern at bending such a finely engineered piece of gear, and will never forget his reply "We don't call that bending, son. We call it adjusting". Bill
  4. I wonder if it would be a worthwhile and relatively cheap experiment to put in a Cowboy beehive spring and see what it does? Bill
  5. Well done and it may be a good time to look that guilty one in the eye and tell him its time we made a doggy bag whilst stropping your knife of course ......... Reminds me of the other day at work, when a co-worker asked me if I could make a Boston Terrier bag. I said "sure!" and asked if she knew where I could get Boston Terrier leather. She was not amused. That bag looks amazing, Motocouture! Well done. Bill
  6. There's an episode of Dirty Jobs where they go to a tannery, and show a mechanical measuring machine. They said they have a laser machine, but mostly used it to calibrate the mechanical one, if I remember right. Bill
  7. While you would not want to cut through leather on a hard surface, skiving is not problem. The blade meets the surface at an extreme angle, pretty close to the angle on the blade - much like it would when sharpening. You may need to just stop and strop frequently if the blade is dulling quickly! Bill
  8. You can't go wrong with Barry King mauls. Look for his ad at the top of the page here.
  9. You can try wetting the leather then place something smooth and heavy on top.
  10. Awesome to see this restoration in progress - It's a fascinating machine, but I have a favor to ask! As you put the shuttle and hook back together, take some pics. I'm having a hard time visualizing how the thread passes behind the shuttle! It seems like the shuttle would have to almost float free for the thread to pass, and just can't quite see it in my mind. Bill
  11. While used footballs are probably somewhat plentiful for you, they're still a limited supply. Try tracing the shape of the leather on paper, or better cardboard and cut 'em out. Use those to experiment with your layout to find something that works and when you've figured it out use the real deal. Bill
  12. It's not uncommon even for modern dyes to "take" differently from one piece of tooling veg tan leather to another - even on the same hide at times from one part to another. Most ancient dyes will not have the coloring power that modern ones do, so your results aren't all that surprising. You may find that some will need to really soak the leather - possibly even by submersion for a period of time. HO or W&C tooling leather are probably as close as you'll find to fully natural veg tan leather unless you tan it yourself. We know that they both use vegetable matter to tan - but not their exact formula - they're just not going to tell anybody exactly what they use. Bill
  13. Pine would probably work OK, but it can be a bit resinous and as a soft wood, would likely wear down more with use. Oak will also likely work but it is porous and might be a bit more abrasive than you want. Maple is hard and tight grained, so that would be my choice in this case. Bill
  14. Great looking work as always, Chief! I've gotta say, I especially like that last one - Great use of a veiner and swivel knife for a really different, simple, and good looking pattern! Who'da thunkit! The other designs look great too, but it's nice to see what can be done with minimal tools too. Bill
  15. Three Days of the Condor, 1975, Robert Redford, Faye Runaway. I think they did a piece on ice and meat bullets on Mythbusters and they sadly didn't work so well in the real world.
  16. If you think it's unfortunate for a sewing machine, they made airplanes at one time. Bill
  17. Mattsbagger is right in my experience. But if there IS some over-riding reason to put paint atop resolene, it works fine. Bill
  18. Lets see if we can figure this out. Given the makers identity it's some sort of shoe machine, so most likely is for some sort of leather work. Looking at the picture, it's motor driven - there's a drive belt and pulley at the right and no handcrank in sight. The center post part tells us that it's meant to either operate inside something or with some bulk on either side, and the top is a 90deg. angle. The drive pulley on the right looks like it's in line with the back roller arm, and probably designed to pull something through. Just in from the main drive pulley there looks to be a transfer pulley or gear to what looks like an upper shaft. On the left side there looks to be a gearbox, I'd guess to transfer drive down to the front roller arm. The levers on the front look to control pressure or thickness for the two roller arms. The profile of the cams/levers at the top probably release tension on the roller arms to allow insertion/removal of material. The front roller looks to conform to the post / anvil, so probably meant to bend something at 90 deg. The back roller looks to be ridged as though meant to pull material through. It looks like the upper part of the post / anvil might be replaceable, as does the front roller at least. Wonder if there are other profiles available? So, in short - it's a motorized shoe machine that pulls material through (probably leather but maybe not!) with two types of tension-able rollers which might be used together or individually (we don't know for sure). The post/anvil may be changeable. Given that, it may be a single purpose machine or possibly multi-purpose. What other clues are we missing?? Constabulary's first stab at a folder/bender seems right, but I don't know enough about shoe making to have any idea where that would be needed. It's obviously a pretty expensive piece of equipment, so it would be needed for something that is either difficult or time consuming by hand in order to justify the price of a machine.
  19. Dang! Wish I could've been there, but I think you're on the other end o' the state. Bill
  20. I'm not sure what that is, but is that a flux capacitor on the right side? Maybe Doc Brown will chime in and help us identify it. Bill
  21. Zip material is pretty sturdy. I use the awl. Bill
  22. Take a look at this Video by ian Atkinson about putting in zips. bill
  23. I'll second what alpha2 said - search motorcycle line art - stick with something simple and you don't really need to overdo the detail in something as small as a checkbook cover. But I've gotta chime in - it's an awesome gesture for you to do this! Gotta love a two wheelin' granny!!! That's awesome! Bill
  24. Do they look like stretch marks, maybe? Bill
  25. I'm experimenting with this lately. Once I get back to 8hour days and 5day weeks I'll be able to work with it some more. Bill
