Everything posted by RockyAussie
Smart phone holster
RockyAussie replied to Windrider30's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Neat project Windrider30. When gluing in the liner on something that has to come all the way over when finished, it is best to attach with at least a 90 degree or more bend. Attach half then push it down over an edge of a bench or table then flip it over and press out the other half. Normally easiest to have the liner a bit oversize and trim up all the excess after. Note a softer liner would of helped as well. Regards Brian -
Thanks for that Shoepatcher.
Yes I agree my 69 machine has the same looking unit as Constabulary has shown in the top picture. I wonder if some mechanic has installed this unit with the intention of increasing the top tension further without tightening the spring all the way in, as happens at times when using a large bobbin thread through thick material??? At any rate I would take off the tension discs of both and check if they have any roughness or grooves. Periodically I take mine off and polish them with a rag wheel and tripoli polish on a bench grinder. This may help with the top thread fraying problem mentioned. Another problem on some threads is when going very fast, stopping and going fast again. When I stitch full belt lengths at times the heat generated on the needle starts to melt the thread and I have found it best to slow down the machine the last 3 or 4 inches before stopping. Sorry I can't help with the steel bobbins as I am in Australia. Regards Brian
For my team
RockyAussie replied to Hermit's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Keep up the good work and you'll lose your "Hermit" status. They will come and find you. -
Trying to figure out the basics
RockyAussie replied to spectre6000's topic in Leather Sewing Machines
How bout if we cross breed a patcher with a blake and make the horn swivel 60% as well........or would we just end up cross eyeddddd -
The Leather Shop Bags
RockyAussie replied to Jess Jones's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Congratulations Jess Jones Your gear looks great. Don't forget to attach any links or such to how to find you.... Unless your already overloaded. Best Regards Brian- 9 replies
- the leather shop
- bag
(and 1 more)
Amen -
Welcome I think we will be seeing some very interesting art from you. You are off to a flying start.
I watched the video above and was surprised to see the thread at section 1.3mins in being looped behind the thread return tension spring post as I have never done that and have not had any problems that I know of. I checked online and saw this video that is threaded the same as I always have. https://www.youtube.com/watch?v=mHq0N0Umz08 I do not know if the shown example is correct. Can anyone here verify which way it should be or if it matters. The winding through of the thread on the stand at the start going through the 2 holes makes me wonder if the operator really knows what he is doing. The uneven tension on the bobbin mentioned makes me think to look into whether a new bobbin case should be tried to compare with. I always put a drop of oil onto the bobbin holding post and into the back of the bobbin case between most bobbin changes. This makes it quieter and smoother running and helps to keep the tension more reliable. Make sure the bobbins do not have any restrictions when turned in the bobbin case without any thread in. Sometimes the case can have damage from a broken needle and so on. I do prefer steel bobbins as against aluminium as I think they are less likely to pick up rubbish and do any scouring on the bobbin tube or the post. Changing the foot lift to a knee lift is quite easy and would be no problem to do. I think it is possible that you may need a good mechanic to go over it but mostly to get you to understand exactly how and why different adjustments work such as the feet tensions and how this relates to the varying thicknesses and the tightness in materials being sewn. Usually I run them as loose as possible but tight enough not to let the job lift off the table at all when starting off. There are a lot of different things involved in getting a machine to run right and unless your doing the same work all of the time a good knowledge of how to make the machine work the way you want will be true with a new machine in short time as well. Hope that helps some. Regards Brain
Wow such detail. I hope it fits her well
Help designing a folding saw sheath!!!
RockyAussie replied to bushlover's topic in How Do I Do That?
Well done -
No you should be safe mate. Can't talk just now the dingo needs another feed.......... -
If 2 top grains are used the answer is defiantly yes and I would guess by about 50% or more. The type of glue used if any would also add a further factor. If used against where the bar of the buckle comes in contact I would use the top grain to make contact. Making sure the stretch in the hide is cut in the correct way, will have a large bearing on the durability as well.
Yes that should work but make sure to use a thick welt along the stitch side and or at least block and case so as to allow the saw easy access in and out . Have fun and a Merry Christmas. -
I think you may need to make a wooden block allowing a straight relief a bit like you would on a holster for the sights I guess. Might need a better saw though. Regards Brian -
They are just 3k down the road and the Caves pub is a 1/2 k closer and have fantastic counter lunch. I wonder if I can get a discount for that add
Your most welcome. If you come up on a weekend there is a spare couple of beds to spend the night if you want.
That is some real handy information Uwe as always. I like the look a lot of the 205-64 as I am not a big fan of walking foot machines believe it or not. With the use of a and Variostop needle positioner and pneumatic foot lifter I can comfortably work very close to the edge of gussets and such and lift just when I want with the foot. Much of my work is done on an obsolete Pfaff 331-33/1b and although I have a couple of cylinder walking foot Adler and Pfaff they get get used very little in comparison.Check out my homemade foot for it in pic below.The larger size of the 205-64 and Cowboy/Hightex 7205W64 does make me think I will have to go and pay Steve at Singermania a visit sometime soon. Just about a 3 hour drive away I guess. Thanks again for your helpful sharing. Regards Brian. PS. Local paper did a story on our business this week see in link if you like- http://www.themorningbulletin.com.au/news/rocky-leather-factory-launches-high-end-retail-sto/3124263/#/9
Looks not too bad AussieMade and a good share with the pattern as well. Merry Christmas.
SHHHHHHush we been trying to keep quite about them -
Pfaff 335 w/ 135 Thread Having Tension Issues
RockyAussie replied to drawingonblank's topic in Leather Sewing Machines
OK , I have not seen before the curly thread thing on the bobbin case so I dug in around the back of a 40' shipping container and took some somewhat dark pics on one I haven't used in a good while. By the dog foot I mean the foot with the groove in it as I have pictured in the 2nd pic. Just also check your back foot is coming down level with the base as you may not be getting the pressure down right as the needle is lifting out.Your picture looks like it is angled high at the front. -
I reckon yes And isn't the Adelaide hills and a Bonnie one of the best in the world feelings. Was better back when they had a few more bends though.
