chrisash
Everything posted by chrisash
  1. Never used them , but assume you would need to mix them with other colors or white to get lighter colours using acrylic dye Dure i have seen that somewhere
  2. Restoration is a funny thing, some are happy to repair the original , but the repair must stand out as a eyesaw so people know its not original, often on old buildings. They take a 500 plus year old cathedral and insit the new blocks of stone stand out a gleaming new colour whilst the surrounding blocks are covered in 500 years of grime Some others want to retain the grubby worn out patena with all the faults remaining and value it highly even if it looks a mess Others make it back to a serviceable object that can be used and looks great maybe 95% of its original look Depending on your most modern point of view you either hate whatever was done or love it Me i think what you have done is great and its now a practical object that can be used for its original function
  3. For about £125 you can buy a 3D printer "Ender 3" and print your own lettering for embossing as either positive or negative using all available font styles with proportional spacing so they look great, a typical name print will cost less than about £0.50 in filament. You can use a free online software package named "Tinkercad" to get started which whilst basic will do all you require for making stamps with a Arbor press (1-2 ton)
  4. I doubt there is much difference in the awl blades themselves apart from the very low cost ones, But if your inclined to be impressed by a wooden handle, you can spend a small fortune on exotic wood and shape
  5. Are you using the water thickener Carrageenan and painting the leather with Alum before starting. That seems to be the best way so i understand
  6. Don't bring him to the England though, Our patron saint St George kills Dragons with his mighty sword Very nice skilled work, looks great
  7. Hi Please can you explain fully what the problem is and if possible enclose pictures of the problem area
  8. Please can you advice what dye or paint you used and found best
  9. I find if i force it off with the blade it takes force and can make it unlevel, but i guess different machines act different, mine is only a cheap Ender 3, but if I let it cool itself it seems to keep level for a month or two
  10. Wow aggressive on the presser foot
  11. My wish list would include a SLA printer but the low cost ones at present have very small print limitations, but the detail of print is superb but also limited on mixtures at present Have a great Christmas all
  12. I would guess the room temperature will make a big difference in plate cooling time and also the size of the print on the bed
  13. Hi Aussies Understand things are tough with the heat and fires, just hope all is well with you and you keep safe and it does not effect you to much Wishing you a happy Christmas and a prosperous new year Chris Same to all readers Sorry i could not think of a forum so picked this one
  14. Resolene etc, most leather shops have a assortment of sealers
  15. I just use 5 times and a bit, what the hell the thread is cheap enough
  16. No experience of laser print on leather,but could you just leave alone and spray a sealant over it, od maybe a vacuum cleaner to remove the loose particles and then a spray sealant
  17. I found this conversion file that seems to do the conversion stl to other formats at $60 which might work, have no need myself so have not tried it https://3d-viewers.com/index.html
  18. Lateral thinking at its best once again Brian, well done
  19. Makes me ask if anyone in the UK has imported a machine into the UK from China and associated costs
  20. Easy job to copy for a 3D printer if they have the original Dimensions
  21. Have a look here https://buyleatheronline.com/en/27-laminated-metallic-leather
  22. Did it have a sew off with it?
  23. you have done a first class job, but not sure about the fastening, maybe the more traditional frame like here would be a improvement https://www.etsy.com/uk/listing/745748018/brushed-brass-metal-closure-purse-frame?ga_order=most_relevant&ga_search_type=all&ga_view_type=gallery&ga_search_query=doctors+bag+frame&ref=sc_gallery-1-2&plkey=5630470cb71637f939ec42f871f348c77e23789f%3A745748018
  24. Why not just dissect old briefcases or handbags, so you start with the real thing
  25. Depending on the strength required and or the cosmetic look, you can buy say tiger thread in 0.6, 0.8 as well as 1mm, so mayb e the 2nd punch with thinner thread would give a nicer finish
