chuck123wapati
CFM
Everything posted by chuck123wapati
  1. it looks awesome as other have said its as good or better than the original and heads above the other repro's. other folks have the same pics as you to look at so they wont be able to tell of any difference between the two.
  2. interesting design indeed I may have to make one lol.
  3. when i was a kid my mom had a friend that had love and hate tattooed on her hands just like that. Always wondered what the meaning was to her.
  4. paint it with rustoleum then cover it with leather.
  5. use the square tip as you would a scraper too.
  6. the big contracts may get the best from the tanneries before the vendors get it, car companies for example. and yes it happens every day with all products. They are called called contracts for a reason they guarantee the products.
  7. my opine is that the best quality goes to the best contract customers. and with the shortage of good hides the craftsmen are stuck with what's left over. simple as that.
  8. Interesting i haven't noticed that but maybe they are trying to explain that they are not hole punches, chisels aren't for punching holes they are for cutting slots. hole punches are round and for punching holes. lol Most of what we do on the forum is answer questions about tools that the tool companies don't . in our high tech world there has been a real disconnect with modern man and his understanding of hand tools.
  9. lacing chisel left stitching chisel right. both from Tandy and both work as well as any.
  10. you need a stitching chisel or pricking chisel for use with sewing awls. believe Tsunkasapa. Also consider this, using a one prong stitching chisel wont be any different than just using an awl in the first place except it will take you twice as long.
  11. is this some kind of secret project? short answer yes you can stretch leather. If your doing a seat cover for example it may stay or it may just compress the foam underneath. If you are making something that wont have tension applied then it may stay stretched or it may go back to original. if its for clothing of some such then it will stretch to form and function to a point. No one can tell you if that piece will stretch to do what you want because we don't know what you want to do with it.
  12. your video rocks!!! i finally found it. i think it works on the same logic, its adds some room for the leather to flex instead of compressing against the blade. I'm an old guy with flip phone so I don't do videos lol. maybe i can get my son to help me out. you know i was just thinking if a guy were o cut a piece of 4" pvc in half and slide it under his leather so he was cutting on top of a convex surface it would work pretty good for long straight cuts, i'm gonna try it .
  13. Always have it behind the blade not in front lol. Leather laying on a flat surface compresses the fibers into the blade, my guess is because cows are round not flat, causing drag when one side is lifted or even let hang over a table edge for example abates the issue.
  14. I've found lifting the leather off the work surface makes it very easy to cut, i draw the lines pattern then as much as possible i hold the leather up off the table with one hand and cut.
  15. has the edit button been taken away?
  16. weird the link doesn't open to the buckle and for some reason there is no edit button anymore? but Weaver is having a 10% discount on hardware so have a look.
  17. i use buckles from Weaver leather haven't had one fail.https://www.weaverleathersupply.com/c/product/_z40_buckle_nickel_plated_1__00040_np_1/00040-np-1?cat_id=shop_now&node=roller_buckles
  18. you do beautiful work friend!
  19. the tandy roller buckle. I doubt there is much difference they all come from china now.
  20. leather washers for leather handles for leather tools
  21. something tells me after this weekend you will be making some more!
  22. beautiful work!!! Thems some fancy spenders lol and just in time for October fest.
  23. i agree they need some refining. They look to perfect or computer generated to me maybe its the flat edges lol. Do you or can you do logos? I'm interested in one.
  24. wrap them in leather?
