The leather is probably being pulled up with the needle, lifting the presser foot. Tighten down the spring on the presser foot. Tom
Something wrong in your browser setup. I use Win 7, Win XP, and the iPad. No trouble using copy and paste, or the quote function. I usually use Firefox as the Windows browser. Tom
Best Feet For Top Stitching On Cylinder Arm.
Northmount replied to SonderingSusan's topic in How Do I Do That?
Just used a fine tooth file. Carefully, and lightly. Rounded all edges that could contact the leather or snag a thread. Tom -
2Nd Project, Carry-On Luggage V2.0
Northmount replied to Magnus a's topic in Satchels, Luggage and Briefcases
Flickr link works fine. Must be something about permissions messing up my view in the original post. VERY nice case! Tom -
Photo has disappeared, not available. Tom -
Here is another thread about printing on leather. Tom
The inside layer has to get shorter when curved around your bod, so it wrinkles. One method to reduce the wrinkling is to glue up while curved, not flat. Higher quality leather may help also. Stay away from leather closer to the belly. Many belts are cut from along the backbone. Tom
A picture of how it looks now would help. Remember to allow for the different radius of the fold from the inside and the outside. The inside piece needs to be shorter. You might be able to rip it apart and depending on how the inside is built, trim it shorter and re-sew or re-lace the wallet. Tom
Not sure if you are confusing a cylinder arm machine with a post bed machine. I would go for a cylinder arm machine with an adapter table attachment. With the cylinder arm, you can reach inside a purse or other object. Depends on the size of the object and the cylinder arm. Then add the table for flat stitching. Don't have to have two separate machines then for the same thread size, etc. Make sure it is a walking foot style. If you haven't read Wiz's pinned post on leather sewing machines, I recommend you do so now. Tom
Getting A Feel For Clicker Services Needed.
Northmount replied to DoubleC's topic in Leatherwork Conversation
This clicker (hydraulic shop press), assuming I picked the right one, is not a fast operating clicker. It will take 2 to 5 minutes for repeated cuts using the same die. You have to position the leather and the die, close the bleed valve on the hydraulic jack, pump the handle 20 times or so (depending on how much clearance you left when positioning the die and leather, then release the bleed valve, move/reposition, and repeat. It is heavy duty, and will make very nice repeatable cuts. Still faster than you or I can cut by hand, just slower than the clickers that run $5k to $10k or more, monster swing arm types like this. I have a 20 ton shop press that is nearly ready for clicking. Need to get a couple steel plates, then I'm ready to go. I bought a replacement pneumatic bottle jack to replace the typical hydraulic bottle jack. Will help speed things up a little, I just won't have to wear out my arm pumping the jack. You are on the right track to be able to click out repeatable items saving a lot of time, just not at the speed you have estimated. Neither you or I can afford the big swing arm type, so we use what we can afford and make do. Tom -
I'm curious. Which clicker are you getting? Tom -
The Howard press is very similar to the Kingsley we used to have. This one came with more accessories. Has a type box about 2.5" x 3.5". Also has a self centering type box that holds 2 lines of type. It is handier for quick setups. Link I'm happy with it. Need to practice some more with various leathers. I was trying to stamp gold on black pigskin. Wasn't as clear as I wanted and was dropping foil bits near the type that had to be brushed off. Ran out of time and patience, so left it for another time. The leather is stiff and hard with lots of character. Supposedly, you hold the leather where you want to stamp it (guide, etc.) and press the hot type into it for several seconds with no foil to give a good bed for the foil. Then stick a piece of foil in and give it a fairly quick press, very little dwell time. I think my temperature may have been too low so need to try a again, see what dwell time, temperature, and pre-stamp treatment work the best. I used if on 3-4 oz veg tan with no problems. A separate point of discussion, you can have photoengravers or CNC people make plates mounted on a block so you can repeat the same setup later without having to reset all your type. Handy for stamps that you will be using over and over. Usually not too expensive. Tom
- 12 replies
- foil stamping
- heat embossing
(and 2 more)
Here is a link with some valuable info if you are going to buy a hot foil press. http://www.ebay.com/gds/BUYING-A-HOT-STAMP-MACHINE-/10000000000751965/g.html I picked up a "Goldmark" press a few months ago for about $250. Had only been demonstrated. Came with several rolls of foil, several sets of type, all accessories, box full of pencils, napkins, business cards. Turns out it is a Howard press, just re-labeled. Youngest son had a Kingsley press and printed business cards and such while in jr and sr high school. Gave it away because no one was using it, then last year decided to get one again to be able to print my makers mark on chrome tanned leather. So check all your local sources of second hand goods to see what is out there. Some good deals. Note that Kingsley is no longer in this business, so be cautious, make sure it is in good working order before you pay. Tom
- 12 replies
- foil stamping
- heat embossing
(and 2 more)
Man's Cuff, Goat, Veg Tanned And Roo Lace
Northmount replied to DoubleC's topic in Collars, Cuffs, Leashes and Leads
On the third picture, you can see both the inside and outside views of the lace. Notice how the inside view is so much neater and lays really nice. Double loop has a nice side and a rough looking side. Normally the nice side should be on the show side, so you can show it off, and hide the opposite side. But I'm not sure in this case, the rough side could be more irritating to the wrist. So maybe you have made the best choice for the user's comfort. Lacing instruction diagrams are usually shown from the good side of the leather. So if you automatically pick it up and work from the good side ... The good side of the lacing will be on the good side of the leather article. (The other option is of course round braid because it looks great from both sides. I agree with you keeping your costs under control as a reason to skip it this time. I've done double loop for years, now need to practise with round braid to become proficient with it and use it where it fits.) Your spacing and tension look quite good. That part is hard for a lot of people to get right. Keep it up, you have come a long way in the past couple years. Tom -
Roper Wallet
Northmount replied to LoneWolf1973's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
You can re-size pictures to reduce the file size. If you are using MS Outlook, right click on your photo in windows explorer, pick "send to", "mail recipient" follow the prompts for the size you want, and email it to yourself. Another option is "Irfanview" free-ware software with tons of options and capabilities. http://www.irfanview.com/. There are also online services that will do it to. Do a Google search for "resize photos". Tom -
Your decorative cuts look pretty good compared to mine! Very nice. Tom
Are you holding the threads tails while you start, until you have sewn a couple stitches? Tom
A picture of the stains might help get an answer. Try wetting the whole surface with the same quality water, wipe off after a moment or two, then let dry. Works if it is just water spots. If it si something else, it may not make any difference. Tom
Excessive Lubrication? Is There Such A Thing?
Northmount replied to saturnmorning's topic in Leather Sewing Machines
There may not be manual oil holes in all the locations where it needs to be oiled. Take a look at this thread and it may help explain some of the issues. When the machine is not in use, place a wadded up piece of paper towel under the presser foot to pickup oil that drips down from that area. It will help you get started with less oil on the parts that contact the leather. I wipe the oil off the exposed needle bar and presser feet shafts (and feet) too before I start. Tom- 4 replies
- cobra 18
- leather stitching
(and 1 more)
There are several threads about "vacuum forming" here on LW. I did a search and got 58 results. One of them is by Dwight with lots of instructions. There are others with sources of suppliers. One lists a source for a hand operated vacuum pump if you are unsure of how much you want to spend and how often you will be using it. http://leatherworker.net/forum/index.php?app=core&module=search&do=search&fromMainBar=1 Tom
- 9 replies
- wet forming
- mould
(and 1 more)
PM Johanna with your request. Tom
You can grind/file out a gap in the toe of the foot. Round the edges nicely and polish up any rough spots. Tom -
Request: Us Mail Bag Pattern
Northmount replied to AndersenLeather's topic in Patterns and Templates
40" x 52.5". Depending on your settings, you can have your pdf viewer show the original size in the bottom status bar. Tom -
Help- Opinions On Fortuna Skiving Machine
Northmount replied to E L's topic in Leather Sewing Machines
Found this info on another forum ask Fortuna-Service Austria http://www.fortuna-service.com if you do not use email you could drop a note their. Send Type of machine, Machine-Nb if availabe (sometimes there are differences) a foto which shows the machine, maybe a pc of the problem? and a description of your problem to office@fortuna-service.com 35 years of experience should do it ;-) Tom
