RockyAussie
Contributing Member
Everything posted by RockyAussie
  1. Bags, belts/straps, shoes uppers,wallets purses up to 10mm (3/8") thick and just about anything you can see on my web site. (Not the linesman's pouch) If I were starting all over again this would be my first machine. It can do anything that you can do on a flat bed and most things that you can on a post machine as well. Main limitations are the thread size at max #138 and the thickness it can sew. A larger cylinder gives you more difficulty getting into tight gusset areas and if you look at my wallets I sew all the way around which to me is quicker and neater.
  2. Very nicely done contrast colouring and the thread swapping adds a very nice detail.
  3. Normally I buy 3x20 litres at a time along with a drum of the thinners for it as we need to thin it for the glue machines and for spraying as well. I ran short of the thinners once and found that I could use general purpose thinners (GP Thinners) be that it was not as good as the proper thinners. Your paint shop will be able to help.
  4. They both have 1 advantage in that they can sew in any direction (360 degrees) but the feed is only achieved by the top foot grabbing and pulling the job along. This can be a problem for getting uneven length stitches and foot teeth marks and sometimes when sewing up the arm keeping the thread to the left or the right of where the needle goes into. It is worth having one but the money would be better saved and put toward a cylinder. In my experience looping tension problems can be hard to avoid as well. I have many years of experience using them and can get a pretty good result but that only comes with years of practice that you get from sewing inside shoes and following the same holes etc.
  5. I have a wide range of machines but the one I use most is a small cylinder arm machine. They can do a wider range of operations than other machines and give professional results. This one here from Techsew called the 2600 is along the type I would start with. http://www.techsew.com/machinery/industrial-sewing-machines/cylinder-machines/techsew-2600-narrow-cylinder-leather-industrial-sewing-machine.html For just over $2000 I would consider their finance options.
  6. For bags and backpacs and wallets etc I would try and find a cylinder machine to start with like a Pfaff 335 or Adler 69 or there are a lot of clone copies of these that some of the sponsors on this site could help you out with. The 2 I mention here have a small cylinder diameter around 46mm there abouts and come in handy when you have tight areas to get into. Many use a table top attachment with these to give them in affect a flat surface to work on.
  7. Hey Gary if the problem you are having is along the lines in this picture below you could try using the slotted needle plate or if you have not seen it yet here is a post I did awhile back might be of interest. Problem below shows what happens when trying to sew close to the edge with the standard dog foot/needle plate.
  8. At that thickness I would make sure the 2 pieces are sanded rough to help good adhesion but make sure that the outside piece is a good 2" or so longer. Without gluing wrap one piece around your waist and then the other on top and you will see that there is a huge difference. If there is too much difference when they are put together the glue will have a hard time holding it together. I would split the difference between out straight and curved all the way around and I'm thinking that's about 2". Getting it stitched would be a good idea.
  9. What you are suggesting sound about right to me. Before you start though ALWAYS make sure that what you are about to fix is worth fixing. There is no point throwing good money into a thing that is no good any longer. If you find that a with little pressure that the rip opens up more then show this to your customer because whatever stitching you do wont last very long and then you look at fault. If it is only sheep skin ...don't bother you are wasting your lifetime.
  10. Very nice ...that will be one very proud uncle I reckon.
  11. Yes I have in the past milled leather in a drum which is like a large tumble dryer or front loading washing machine. The time it takes varies on the skin or skins being milled. Often pieces of carpet and even old sandshoes get thrown in to help it happen faster. The falling action helps it to soften. There are a lot faster machines for normal leather which use a series of pegs on one drum with a series of holes in alignment on the other drum. These turn and pull the leather through and can be a very aggressive method. Either method if overdone will wreck the fibres eventually and the softening process should ideally employ some oils if possible along with or instead of. If the skin you have is glazed then I would not look at milling it as it would craze crack everywhere. Not knowing the skin and how it is tanned I can only suggest applying several coats of Nivea cream(the one without any alcohol in it) and letting it soak in between applications. If it is a glazed skin a bit of quick rough sanding on the rough/flesh side can break the tension and make it a lot better to work with. This must be done so as to not let the sanding get hot in any one position or the skin can end up burned and harder. I think I may have shown a bit of this earlier in this post on some glazed skin cut for bangles. A dremel wont be of any help on this.
  12. The answer really depends on whether you want it for hobby use or regular work use. Many of the cheaper products use bushes instead of bearings and I found out the hard way that going with the quality products is often in the end cheaper. A bigger factor also is the dust extraction as that fine leather dust aside from going everywhere also can build up in your lungs. If your thinking of long term production let me know and I'll load some pictures of a few different machines I use that do this type of work.
  13. Small world isn't it. I still miss him a lot, as you say... he was a real good bloke. Loaned me $10,000 when I got into ostrich products manufacturing many years back but of course I then had to give his work priority at least until I paid him back. You never seen someone so unhappy to get his money back.. It didn't really change though as I still did my best when I could for him. You know ...he never told me he won all those years in a row or that he ever won anything at all. I only found that out at at his funeral where of all things they had a big screen showing all of his knives and awards. I had to leave a bit early
  14. That was done to start with 2 pieces of wood routed out to receive the blade nicely then attached together. After that I sanded down until I liked the shape in relation to the knife and the thickness of croc that covers it. The tip and the other end were left short in the covering and from there Morrie made his silver pieces and trimmed the excess croc to the shape. The silver parts are then araldited and pinned onto the wooden section just covering slightly a little of the croc skin. Best as I can remember on that one. Some of them were really quite detailed in the making.
  15. Yes the top ones are Australian saltwater crocodile, the top one is from a large elbow section and the bottom one is near to the tail tip. As for the sheaths in the last picture ....I made them along with a jeweller friend whose hobby was making the knives. I only made the exotic leather working parts and he made the silver attached parts. He won awards with his knives for so many years they actually have an award named after him today. Maurice (Morrie) McCarthy Here is a link that shows better some of his work - https://www.australianbladeforums.com/vb4/knife-show-pictures/787-melbourne-2011-maurice-mccarthy.html Thanks mate... I am going to have to find another knife maker so I can try out a few more of these I reckon.
  16. Thank you. These are what motivated me to get a 441 style cylinder machine. All the above was done at the time on a little 335 phaff cylinder machine.
  17. Hi Tor, long time no see. I myself have only tried working with the ABS a couple of times and did not get great results. I did try the acetone on it and it seemed to work some. Mostly I use this pla+ which claims to be stronger than the abs and a few other alternatives. So far I can't fault it.
  18. I don't work with caiman skins so I cant say what size they use normally. The size of the salwater crocodile (porosus) skins we use varies a lot but an average would be around the 40cm. The sanding is from the back when sanding the bones. A couple of pictures of some bags I made show this better perhaps - This one shows that sometimes the skins can be very thick and as I said some good sanding machinery is needed. Note that the bones are very carefully sanded out at the edges as much as possible. These are all, as I said before attached to a fabric to stabilise the skin behaviour Here you see that the inner curve section has to have a zipper sewn to it and the outer edge has to be able to curve over and be sewn into the back of the bag
  19. Small or large it is possible but some good sanding equipment is required. To some degree you need to sand the bones out behind where you want to stitch. They are a fair bit of extra work and time to make. Also we normally don't do folded edges on these ones as in the first pic below. This is the same model without the folded edges This is a coin purse model This one may show the edging process a little better These crown style ones below are very popular but there is only one possible per crocodile of course.
  20. You could be right there depending on the overall size but I have found that if you tripoli polish the knives occasionally you can get away with the 19mm(3/4") for quite a few years. 10 to 12oz is only about 4to 5mm and I have knives that do that no problem. I don't generally do any saddlery type work but if its croc in Australia it often ends up in front of me. This first picture shows some prototypes I designed for a customer that wanted them for some campdraft prizes. They are a brow band, a couple of different spur straps and a single slobber strap all in imitation croc at this stage.Most of these are in the 12 to14oz range. When it came to the real croc stage the customer wanted a more simplified look as shown here
  21. That was an interesting read. Funny how he gets fined 5 billion and he still goes up 30 billion in the same year. I guess the US gov cant really collect that sort of info directly for themselves on their own people and it would seem that he can help them out there. Many other countries would say that he was not a fit person to run such a business and break it up instead of fining him. Taking a leaf out of his book one would just copy the model and add a proper privacy storage system. As usual greed and apathy will prevail.
  22. Your retainer now looks a lot better. I don't usually do a welt on the top of the blade unless it is sharp as well. I make the welt about 10mm or 3/8" if you like and that normally gets sanded back some at the finishing stage. You can make the retainer part of the back if you want to give it a go as shown in the pictures below. Note: that I generally wet mould the front piece and let it dry overnight. If I am attaching an exotic that is done dry with glue at this stage and trimmed up and then attached to be stitched. I Do NOT attach the male part of the clip until the pouch is nearly finished as that allows a good tight fit then. I punch the hole for it with a piece of wood covered in leather and set the snap by using a piece of metal or an anvil tip poked inside the top hole. If the knife is a show piece I then generally make a thin disk of leather and glue it inside to cover the back of the snap. In answer to your question about how much blade space -1/8" loose fit inside should be fine but a little more could be safer until you get more experience.
  23. I was just thinking that this post should be in the "help wanted" section. The "services" section is more for people offering services I think. You could repost it there as well or ask a mod to move it there. The smaller size press opens the door for a lot more people. From the material you mentioned and having checked your profile I am guessing that this is saddlery/horse related and that the quality required is to be a high standard. Press knife cutting does a nice job of rounding in the edges on this material compared to a laser and would be looking in that area. 95% of the work we do is not what you see on my website as it is mostly for other brand names big and small. I would consider contacting companies whose work you think is good and see what they can offer. Get a confidentiality agreement signed first if you are really worried. Google has plenty of versions. Best of luck. Brian
  24. I think there is often an aesthetic reason but I do it often to reduce the stretch in the straps at least for some time. I have never done a scientific type off pull test to verify that but, just pulling by hand 2 straps cut from the same hide there is a noticeable reduction in the stretch of the stitched one. This may depend on the closeness of the stitch spacing and the thread type and how well it is done. If the tensions were loose both sides it probably would not help.
  25. Well done mate. I know you had fun doing those gusset base corners.
