tsunkasapa
CFM
Everything posted by tsunkasapa
  1. Almost ANY ferrous metal will be magnetic. Mild steel, plain iron, are just a couple that are, but totally worthless as far as knives go. The magnet has absolutely nothing to do with the quality of the knife.
  2. I just roll them grain in so they don't get scratches, and stack on the shelf under my bench.
  3. Just because Tandy's WEBSITE says they are out, does not mean a local store doesn't have a bottle sitting on the shelf.
  4. Sounds like they want someone to teach them how to do it.
  5. Fast Orange works too, but I don't usually worry about it either.
  6. I use old porcelain electrical insulators. Different companies had different sizes of grooves for the wire. They work great.
  7. Look for "Bag Feet", as in handbags and luggage feet. 9mm Double Hexagonal Feet (pacifictrimming.com)
  8. I frequently WASH deer and elk skins in the washing machine. Cold water, and laundry SOAP, not detergent. White King is one brand, Ivory Snow flakes is another. It may take 2-3 cycles to remove all of that, but at this point it is a cheaper option than buying more leather. I usually hang them till mostly dry, then tumble in the dryer with no heat. A couple of baseballs helps "beat" them soft as they finish drying. For the record, deer and elk can be dyed with Rit dye. Blend different colors, experiment on scrap until you find the color you want.
  9. Nice project! The only change I would offer would be to match the angles of all the basketweave.
  10. As to #1; skive a bit off the back to get it to fit the tip. There usually set screws that hold the tip on. Some tips are pinned on, but the hole goes through both front and back. #2; Usually the various pieces are held in place with snaps or Chicago Screws. Al Stohlman's Belts Galore has all the information you need to make a Ranger belt. I thought it was available through Tandy's Leathercraft Library, but it seems it is not. But there are several Youtube videos on them.
  11. How do the UPC numbers compare? Are they the same? Is it just a new label for the same product?
  12. I think I would have wet it and formed BEFORE all of the coloring and finish. I can't think of anything to get rid of the stain at this point.
  13. You, sir, have NAILED IT! It is so easy to go down the rabbit hole and get lost. Just make one and learn. No bigger than that project seems to be, it won't be a huge expense if the first one doesn't turn out as expected. Odds are it will still be usable for something, give it to a young person to keep "treasures" in. The thing is to jump in and DO it, and learn from what you have done.
  14. Things you never think of......I made myself a new belt a couple weeks ago. Nothing real fancy, a 1 3/4" ranger belt for everyday wear. But I decided to try "gunslinger" stitching on it. Got everything assembled, handstitched 32" of "gunslinger", not even thinking that each stich takes up just a TINY BIT when tightened. Got it all done and the belt was 3/4" too short! It is stretching back out after wearing it, but I hadn't even considered that tiny bit for each stitch at the time.
  15. This stuff from Bee Natural is great! Does not change the color or stiffen the leather. I've used it on my buckskins with excellent results. I also used it on a leather canteen cover and have had no complaints from my customer. It is spendy, but very effective. Natural Leather Protector - 16oz (beenaturalleathercare.com)
  16. In all the years I have done this, I have never used those plastic finishes, or had dye transfer, with the exception of black. And even that has been minimal.
  17. No, my tobacco came in tins and I just put in enough for a couple of days.
  18. Unless you can have one made in the colors you want, I see no way to alter the color that would turn out well. I'll wager that the color goes all the way through and every scuff will bring out the base color. It would be easier to change the color of your horse than the color of the saddle.
  19. As a former smoker that has made a couple of tobacco pouches through the years, I can tell you that if you do not have a plastic liner in it, the leather will suck ALL of the moisture out of the tobacco. But your workmanship is very nice.
  20. A Dremel with a fine grind stone may be an option.
  21. Pretty nice! I just bought an Uberti "El Patron" .357 that I will be making something similar for. A Win/Win, a new firearm and the need for a new leather project. Life is good.
  22. Tie down, wrapping just keeps it out of the way.
  23. If it has pull up it is probably oil tan and there isn't much you can do for a finish. It is the oils and waxes that give the pull up effect.
