Everything posted by TomE
I'm gonna take a WAG that it's the tannins or saponins in Salicornia that are useful for a leather dye, as a vehicle to improve solubility and penetration of pigments. Short answer: I dunno. "Salicornia plants have been screened for phytochemical profile and presence of a range of carbohydrates, proteins, oils, phenolic compounds, flavonoids, sterols, saponins, alkaloids, and tannins have been reported. Water and alcohol extraction followed by component profiling has indexed many potentially bioactive compounds. Studies have reported the presence of dietary fibers, bioactive polysaccharides, proteins, lipids, sterols, flavonoids, and minerals (Mg, Ca, Fe, K) in S. herbacea (Essaidi et al. 2013)." https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4835422/
I enjoy using all types of knives for different tasks. My latest addition is this baby round knife (68 mm) that is handy for cutting and skiving in tight spots.
The BT639 is an adhesive that penetrates the flesh side and glues the fibers together. Burnishing with tokonole or gum trag is a surface treatment. I have also used PVA glue (Elmers white glue) mixed with stain to seal the flesh side (worked in with a glass slicker), but this stiffens the leather and I suspect it will break down with flexing the strap. You can find threads here about using stain/glue mixtures for sealing edges.
That's a beautiful case with sharp looking handles. Well done. Is that Sedgwick bridle leather? Totally agree with Chuck that air rifles rock, and yours is way better than mine. Nonetheless, they are my weapons of choice for hunting pigeons around the horse barns.
That's a tidy piece of work with lots of detail. Very nice.
This product is a synthetic rubber (butadiene) for sealing the flesh side of leather. I use it mixed 50:50 with water and work the first coat into the leather with a glass slicker then apply a thin second coat. However, it dries as a smooth nontacky finish (like the label says). It seals out moisture and seems to be durable. I use it on bridle pieces that are split thickness as a replacement for the mossback finish of full thickness bridle leather. The BT639 might not suit your purposes. What about sewing on a liner of rough out chaps leather? https://www.hidehouse.com/Leather/Pearl-Split-Cow-Split-Grain-Suede-Finish-PE10-P.asp
I'm no expert, but I know what I like. Beautiful workmanship. Thank you for posting.
Hatchet sheath—any helpful advice
TomE replied to Jaxx1024's topic in Gun Holsters, Rifle Slings and Knife Sheathes
This video includes adding a welt to an axe cover that might be helpful. I would encourage you to sew instead of using rivets. -
If you're interested in other water-based dyes, Fenice makes a Colorfast Dye that produces a glossy finish with minimal rub off. It's sold by Campbell Randall. I use the dark brown Colorfast dye to match existing when repairing tack. Springfield Leather has another Fenice water-based dye named Diamond Waterstain that looks similar based on this video.
Making an edge dye/burnishing mix from aniline dye powder, water, and glue is a thing. The glue sets the color and helps stick the fibers down. Most common is PVA glue (Elmers white glue) or pearl glue in the mix. I haven't seen the use of an aniline dye fixative like Retayne on leather. The Retyne MSDS doesn't list the chemical composition. I use Fiebings Pro Dye and have good luck just buffing the dyed leather to eliminate dye rub off.
I put a 2-sided bevel on one of my Vergez-Blanchard plough gauge knives. The front of this new knife had a curved surface that I flattened to a 15-20 deg. bevel. I put a steeper (~25-30 deg.)/shorter bevel on the backside. It cuts 10 oz bridle leather really well with the knife fully inserted in the frame. I'll be stropping it more and trying it on other weights and types of leather once I get a project off my bench. As of today I am a fan of the 2-sided bevel on a plough knife.
- 15 replies
- plough gauge
- strap cutter
(and 1 more)
Might contact Campbell Randall since they are the (only?) supplier of Barbour linen thread in the USA. They carry Bulldog brand nylon and polyester threads in a variety of weights and can probably explain how the Bulldog thread compares to Barbour. They've provided good service and advice to me.
Does the 2-sided bevel work well for you? There's a newer thread from @krummark in Leather Tools about a plough gauge with a 2-sided bevel. He talked with @bruce johnson and learned that Bruce sees many plough gauge knives with the 2-sided bevel. I am thinking about putting a 2-sided bevel on one of my Vergez-Blanchard less-than-stellar-quality knives.
- 15 replies
- plough gauge
- strap cutter
(and 1 more)
Nice job on the seat and accoutrements. The only thing I might suggest would be to use a veg tan for the pouch and watch case so that you can slick the edges. Bridle or harness leather would weather well. Perhaps use black leather for these pieces to build on the black and brown theme. A bucking strap?
@krummark if you buy the plough gauge, please let us know how the knife with a 2-sided bevel works for you.
Thanks once again, @jcuk. Very helpful to have expert advice as I learn the craft.
- 9 replies
- bridle leather
- equine tack
(and 1 more)
Thanks, @jcuk. These grips are 3/4" x 30" but I learned they are a bit too wide for our petite trainer. I'll be ordering some 5/8" x 30" grips, and trying the large pips as well as the small. She really liked the small pips, which are very grippy, but I'm uncertain about how they will wear. I didn't use a leather cuff at the ends of the grips because these have a molded rubber cuff that makes it hard to fit the leather cuff snugly around the ends. I suppose I could cut off the rubber cuff and cover with leather. What do you think about it?
- 9 replies
- bridle leather
- equine tack
(and 1 more)
Thanks, @Mulesaw. I'm still experimenting with the creasing. I use heat to crease after beveling the edge and again after staining/drying and before sewing. The bridle leather doesn't hold a crease quite as well as regular veg tan. Stohlman recommends creasing cased leather (no heat) but I find the outside blade of my screw crease indents the beveled edge if the leather is cased. Thanks, @tsunkasapa. The reiny days only happen in my workshop. Today is a rainy day and I'm hoping the horse flies are about done for this year.
- 9 replies
- bridle leather
- equine tack
(and 1 more)
Made some rubber reins using Equus grips from Abbey England and HO bridle leather. These grippy reins are used for jumping and cross country courses. Had fun sealing the edges with beeswax using an old Dixon edge iron from @PeterMain. Shout out to @jcuk for the tip about locating the fixed loop closer to the bar of the buckle.
- 9 replies
- bridle leather
- equine tack
(and 1 more)
That's really interesting. I struggled with a new Vergez-Blanchard plough gauge that pinches the strap against the guide. There's a post about it in the Sharpening forum. I tried adding a very small bevel to the backside with no change in performance. I was advised to get a new knife (which I am on a waiting list for) and to get better at sharpening (which I have done.). The plough gauge works reasonably well now, but it still has a tendency to hang up because of the pinching especially for straps less than 1 inch wide. Maybe I should try adding a bevel to the back of the blade.
Lots of good advice in the comments. I'll add that as you use and sharpen your awls they will become narrower and suitable for fine work. I start using an awl for heavier projects and as it wears down with sharpening I put it on a smaller haft for the lighter projects with 9-10 stitches per inch. In addition to only sharpening the point, I like to shape the point of Osborne awls to a longer/more gradual taper. They are stubby when new. Your #17 harness needles are hefty. I am typically using #18-19 for sewing with #277 bonded nylon, and #19-20 needles for #207 thread. The Osborne harness needles have a smaller eye than the John James needles which suits me. I aim for the smallest needle that I can thread. If you wax the thread with beeswax and smooth it between your fingers before sewing then your grip on the needles will improve. I guess another way to avoid piercing the thread is to withdraw the thread from the backside as the needle is pushed through from the front.
You're correct that the knife blade should have a single bevel facing the guide and a flat backside. This setup pushes the leather strap against the guide. The knife might be repaired by taking the edge back to where the backside of the knife is flat and the front has a gradual taper of less than 20 deg. It depends on how much bevel has to be removed and how much blade is left. The tip of the blade should be positioned at or near the trailing side of the ruled bar that the strap slides across. If the plough gauge is an old Blanchard or Dixon in working condition, I think the frame alone is worth $200. They are hard to find and you could have a knife made for the frame.
Beautiful craftsmanship!
Thanks, @jcuk. So the sole purpose of this stitch is to gather the turn tightly around the buckle? I normally place the fixed loop 2-3 stitches away from the buckle end of the stitch line. Is it better to place it closer to the buckle as in your description? Always interested in refinements. @sbrownn, I've read that stitching across a strap may cause it to tear along the perforations. Perhaps more of an issue with horse tack than for a belt. The bridle cheek piece in the picture is a replacement for one that was torn by a naughty horse. Are you jumping from one edge to the other or continuously sewing across the width of the strap?
First leather belt
TomE replied to hickok55's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
It’s a look! Nice work.- 14 replies
- brass
- veg tanned leather
(and 2 more)
