Northmount
Moderator
  1. Quoted from a site selling tokenole " Note: Use caution when applying Burnishing Gum on leather that is going to be stained, antiqued, or dyed as it may resist or block penetration." Also take a look at this post. So the best thing is to be careful and avoid contaminating the surface so you don't have to clean it up. You might find that Fiebings Deglazer will work for you where needed to clean up these spots. There are many posts here about burnishing and applying various edge coat treatments here if you want to take a little time to research them. Tom
  2. If you don't get the lemon juice (acid) evenly spread over the leather, you will have blotchy spots where the acid was stronger or left on longer. So are you complaining about the lighter areas, or the dark spot I see in one of the bleached areas? I'm not sure from your description. You can also use oxalic acid to bleach the leather. Mix 1 teaspoon per pint of water. Rinse the surface off after with fresh water. That applies to lemon juice too! Tom
  3. @Choeur Moved your post to Leather Sewing Machines. You'll get more help here than in help wanted. Also every post in Help Wanted has to be approved by a moderator before it can be seen by members. Tom
  4. @ellene Moved your post to leather sewing machines. You'll get more attention from sewing machine guys here. Tom
  5. A servo Motor, but not a digital type. Has brushes to feed the armature. Tom
  6. @Frodo Let's keep false politically biased information out of your posts. This is s leatherworker site, not a political FB page. Tom
  7. Here is a cahrt for sewing machine needles and thread that might help you. https://www.tolindsewmach.com/thread-chart.html Tom
  8. You are fighting the laws of physics. The foot is squeezing the leather out to the side. Cut your projects over-size and trim to required dimensions after sewing. Reduced presser foot pressure may help but if reduced too much, will result in the leather lifting with the needle's up stroke and skipped stitches. Tom
  9. As mentioned, HEPA filters are NOT for gases or vapours, just for dust. Respirators have filters available for organic solvents. If you use the same materials for recirculating air back to your room, you will find that it has to be capped off tight when not in use, otherwise next time you go to use it, its vapour absorbing capability has been used up just on ambient air. Since you are moving more air than what you would with a respirator, it also needs to be much larger than the respirator filter! Activated carbon filters work, but again must be capped off when not in use to save its capabilities. Regardless of what your filter material is, you also need to test the filter to see if it is working. So you put a fume source next to the inlet of the filter, and sniff the air at the outlet. If you can smell the glue/solvent, the filter needs replacement. The best has been mentioned above several times; extract the air and dump it outside. Since you are only doing small jobs from time to time, the heat loss is inconsequential. Not like you are using an auto spray booth with huge volumes of air removal that must be made up with filtered conditioned, heated air. If you want to run something full time for 8 hours per day and are concerned about wasting all that nice warm air, then you should look for a small air to air heat exchanger. Draw fresh air from outside, dump it into the room, exhaust from your gluing station to the outside. Keep about 3 to 6 feet between fresh air inlet and the exhaust outlet to prevent recycling the fumes back to your work space. Many high efficiency homes are now built with air to air heat exchangers, so they are available in many different sizes and different types of control. Unless you are using it a lot, you will find that payback will likely be around 10 years or so at a guess. I have a residential air to air heat exchanger that was built about 30 years ago as a research project. I have it installed in my workshop attic and use it to supply tempered air to a hood/helmet that I use when doing dusty wood work, or applying paint or varnish to projects. It exhausts room air and exchanges heat with the incoming air to the helmet (works winter or summer). Means I am tethered to a hose which is not all that convenient at times. Means no one else can be in the shop at the same time as they have no protection. It sure saves me a lot of headaches and sinus problems. Tom
  10. If you go to the home page and scroll down, you will find the forum names along with descriptions. There is also a search box upper right. When you get into the search you have options as to what search parameters you want to use. You can also do Google searches like this: "site:leatherworker.net finishes top coat" without the quotation marks. The site parameter restricts Google to searching the site specified. Add what ever parameters following that you want to search for. It is a Google search so follows all their standard conventions. Tom
  11. You need to resize the pics to fit within the limits. 800x600 pixels will do, can then post about 100 pics with no problems. See this link for some suggestions. Lost of other info in this thread too that might be useful for you. Please upload your photos here. According to the rules for marketplace, which you should read and adhere to, you need to post the price you are selling the machine for. Tom
  12. @FleurFeroce moved your post to leather sewing machines Tom
  13. You can upload to Youtube and post the link here. Tom
  14. @MichelleWall Moved your post to Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners Have you looked through this part of the forum? Tom
  15. No picture attached. There is a thread about posting photos that might help you. Some of it is dated, and not fully applicable, but should give you some ideas of the process. Tom
  16. Working here at this point in time. Tom
  17. You can send text messages (SMS) from your computer using Skype. https://support.skype.com/en/faq/FA34828/how-do-i-send-sms-text-messages-in-skype?q=sms Need to buy some Skype credit to be able to text (SMS) from Skype. Tom
  18. Great job all around! Tom
  19. @Contric Moved your post to Patterns and Templates. Have you searched here? Tom
  20. @talon Please update this thread with pricing, location, shipping info, etc. as per the marketplace rules. Tom
  21. @bok873 Please update all your your marketplace posts with shipping information. Will you package and ship, etc? Conform to the rules for the marketplace. Tom
  22. Some were. However that doesn't protect the integrity of posts here if yours changes any policies or is bought up by another outfit. Also doesn't help if you decide to reorganize your files, or your account is closed at some date in the future. I just see way too many threads that have become useless due to 3rd party hosting. Some of the people who posted 3rd party links haven't been back here for years, so can't be reached to fix their posts. Same can be said for some of those that have provided links to their own websites for patterns. Their website no longer exists. I was able to source the patterns for a couple projects recently where the fellow's site is gone, and it appears he may have passed away. As luck would have it, I had downloaded one, and other members had downloaded the other, so they are now both available to all members again. We really want to preserve the integrity of all threads for current and future members to access when looking for resources to help them. Tom
  23. That would be a good way to do it. There are several reputable 3rd party hosts that have gone out of business or changed their policies. PhotoBucket doesn't allow 3rd party hosting, and you will see that in several posts here. Tom
  24. @Spyros Please upload your photos here in the future. 3rd party hosting results in photos disappearing due to people changing permissions, moving files, deleting files, 3rd party hosts changing their rules, 3rd party hosts going out of business, etc. If you look through a number of the older threads here, you will find the pictures missing, and the thread may become useless to all future readers since they won't be able to see what it was all about. If your photo files are too large, reduce their file size to fit. 800 x 600 pixels in most cases is adequate. Smaller files helps people on the fringes of the internet as well, as they don't take so long to download. Occasionally I'm at a location where my download speed is so slow I have to walk away and wait 5 to 10 minutes for the page to load. Tom
  25. Gently warm it with a hair dryer to soften the glue. Heat is the enemy of most glues and contact cements. Tom
