Hildebrand
Everything posted by Hildebrand
  1. Without seeing pictures everything is just a guess but even for a seasoned leather worker it would be difficult to add a liner and sew it in. Since it is well seasoned you would probably run into issues getting the glue to stick to the existing belt even with contact cement plus using the old holes to sew would be difficult at best. Best advice I can offer is if it is a keepsake then put away and only wear it on special occasions and get a new belt for everyday wear. Todd
  2. The latest holster. Made for a friend. Herman oak 3-5 oz lined. Dark brown Fiebings die. Comments and critics welcome. Todd
  3. Texas Custom Dies. I ordered a slot punch from then not long ago and it showed up when they said it would the size I asked for and sharp. All you can ask for plus they are a advertiser on this site. Todd
  4. Very nice, its always nice to give a handmade gift in appreciation. Todd
  5. Looks good, your tooling held up well to the forming. Todd
  6. Don Gonzales has a great utube video that explains this perfectly. Todd
  7. @chrisash it was never meant to be a compromise. It was designed from the ground up to do what it does. Having shot my share of deer, antelope and 1 elk with one they lack nothing. In skilled hands that pistol can put rifle shooters to shame in terms of accuracy. Todd
  8. It’s been said here frequently. Make sure your skills are not the limiting factor in your final results. Honestly until you have been tooling for quite awhile the Tandy tools will serve you fine, it’s only when your skills reach a point where you can’t improve without better tools that the more expensive tools are warranted. Just my .02 Todd
  9. I always thought that looked like a likely place for something to catch the thread and potentially cut it allowing the stitches to unravel. Seemed cleaner and safer for the thread to all be on the belt loop. Todd
  10. No expert but best guess is the leather is tipping into the hole in the sewing machine as the needle pushes down, and it is doing this in varying amounts. I have to be very careful when I sew holsters that are double thickness plus a welt down the seam or the back doesn't match up with the front and it will vary like yours does. Todd
  11. Nice job @chuck123wapati that looks great. Perfect engineering to get an unavailable tool. Todd
  12. @leather20 I have started using one of the circular light/magnifier combos when I tool. It is on a movable arm andI can position it so I am looking through it or it is above just lighting the project. It makes it much easier to get the tool exactly where you want it. Also makes the swivel knife cuts easier. Todd
  13. @Loquai as someone who had a Tippmann Boss, pretty much like the Outlaw, I don't recommend it. It did a good job sewing but I spent a ton of time fiddling with tensions and was constantly afraid to even change out the thread color for fear of something going out of tune. The second part of that is you only have one hand to hold what you are sewing with the Outlaw, while you crank the handle with the other hand. it was amazing to me how much easier it is to sew certain things since I can use both hands to guide them. Todd
  14. Looks great I am getting ready to make myself one for a 1911 10mm. Todd
  15. Depends on the end use of the belt. Very few single layer belts will hold up to carrying a holster daily without stretching. Todd
  16. Looks really good Frodo. Luckily we don't have that big of a snake problem around here, its enough to just be cautious and watch where you walk. Todd
  17. @Paultalks in reading this thread maybe back off just a hair. You have been beating on these people pretty hard. Given they blocked you on social media I am not surprised you haven't gotten responses to your emails and letter. Maybe take a step back, order online for a bit and see if things slowly return to normal. Like it or hate it businesses have to operate under the state, county and city guidelines until this pandemic is over. Todd
  18. Another impressive piece Josh. Todd
  19. To prevent any chance the metal from the back of a snap contacting the gun in any way. In most cases it is the back of a snap on a thumb break. You can't really predict where the snap goes on the piece which crosses over the gun, this leaves the back of the snap exposed once you set it in place. I place as many snap backs between layers of leather as I can but occasionally you have one end up exposed. Todd
  20. Thank you Josh I appreciate the kind words. Todd
  21. I use the little plastic screw covers the Home Depot sells. I just glue them on, I think they come in different colors. Store SKU #583539 Todd
  22. Thank you all. Chuck, that is double layer 16 or 17oz it is right at or just over 1/4" I don't think I measured it once it was stitched. Todd
  23. This is a set I just finished and will be picked up tonight. Its for a Smith and Wesson MP .40 full size. All comments and advice welcome. Todd
  24. I would go to JLS Leather on Etsy. He sells a pattern pack for mag pouches. It has single and double pouches for 1911. I have several of his patterns and they are all spot on stitching line wise. Todd
