LatigoAmigo
Contributing Member-
Everything posted by LatigoAmigo
I use several different types of chrome tanned leathers, and I typically don't use anything, just let the leather age naturally. But when it does need protection, I'll use something like Fiebing's Aussie Leather Conditioner with beeswax. It will help keep the leather from picking up nicks and scrapes.
That is a very interesting site, thanks for sharing. I'm sorry to say, but I'm getting old and have found that very few things are actually "free." When you click through to this book, you don't just get to download it from the site, but have to provide your contact information first. Not quite "free."
Since you have a few projects in mind, you might want to get the best book I know of on the subject, "The Art of Hand Sewing", by Al Stohlman. It is available through Amazon. https://www.amazon.com/Art-Hand-Sewing-Leather/dp/1892214911/ref=sr_1_1?keywords=leather+stitching+book&qid=1580585416&sr=8-1
This has not been my experience when cutting leather. My laser cutter has an air assist pump that forces fresh air through the nozzle when in operation, and a ventilation system that removes the smoke from the cutting area. The lens is located 2+ inches away, up inside of the laser head, much removed from the surface of the material being cut. None of the smoke I make from cutting leather reaches the lens, and I have never encountered the issue of etched lenses. I'm only speaking about leather (chrome-tanned and otherwise), as I can't speak to PVC or poly-carbonates related issues.
I've read that also, but with proper ventilation, have had no adverse effects, although I only do it a few hours per month at the most.
I use a 100 watt CO2 laser to engrave and cut chrome tanned leather. To limit exposure to the toxicity I've read about, I've installed an inline HEPA filtration system that vents to the outdoors, plus work in a well ventilated space. So far, so good. For what it's worth, a print shop near here has a Purex fume extraction system that vents indoors, and that seems like the ultimate, although expensive solution.
What are you engraving with? Are you referring to laser engraving?
You might consider TAP Plastics. They have stores throughout California, plus they have a great website. I've found them very helpful. https://www.tapplastics.com/
I think that this qualifies as a trick question... There are too many variables to use a "formula." The thickness of the lace, the spacing of the holes, the distance from the edge, the type of braid (round braid, edge braid, etc,), and the thickness of the leathers that you are lacing together will all play into the length of the lace you will need. Since you have a better idea regarding most of these issues, your best bet is to cut a given length of lace and see how much distance it will cover. I've attached two pages from one of Bruce Grant's books regarding length of lace, where he suggests that one uses shorter lengths of lace and splicing them together. It is advice I've used for years. Encyclopedia of Rawhide and Leather Braiding pp290-291.pdf
I know this is a reach... but you might consider perforating it with a laser cutter, that is, if one is available.
Maverick Leather sells white kangaroo lace in three widths. Not cheap, but awful pretty. https://maverickleathercompany.com/product/white-roo-lace-6mm/
I'm currently working on a project that incorporates rawhide. You can't do much of anything with it until you wet it, otherwise it cracks and breaks. Then when it dries, it goes back to being stiff. Not the friendliest material for lacing.
Patterns/Templates Copy Right
LatigoAmigo replied to stampingdelight's topic in Patterns and Templates
Correct me if I'm wrong, that this will be the case, unless that the seller gives authorization to do whatever the buyer wishes to do with the pattern. -
I am using quite a bit of chrome tanned bison these days. It has the lack of color in the middle (not blue/gray but light tan) which indicates that the color has not fully penetrated the hide, and I've had no problems with the leather breaking or cracking. I use chrome tanned leather almost exclusively, and find that most of what I have is not dyed all the way through.
The type of leather will make little or no difference, it has more to do with the thickness. What I do is add 1/8 - 1/4 inch (depending on the look I want) to the outside (or subtract from the inside) layer. With the inside being smaller there will be a slight pucker when you open the wallet, so once you've done this you will get a better feel for how much of an adjustment to make.
The next question is what dies does this press use, and how do the prices of those compare to the Tandy/Buckle Guy dies? Typically you will want to have different sizes of rivet setters, snap setters and grommet setters, so you will want to factor those purchases into the total cost of the press.
You might search for decorative scissors on Amazon.com. They offer quite an assortment of patterns.
This is good information... hope it's OK to post some info from that link, just in case it gets "disconnected." “A set of 16 punches for closing round bezels around stones or evening prongs. The tempered punches have concave faces that are ideal for stone setting. You simply insert the stone into the setting. Use the appropriate size punch to press the stone into the prongs or to press the bezel around the stone. The set includes punches from 2mm to 9mm, a wood storage box, and a hard wood handle.”
The Hide House carries some water buffalo. https://hidehouse.com/products/
Looking for Glove Pattern/ How-To???
LatigoAmigo replied to GuitarLeatherDopeFiend's topic in Patterns and Templates
You might try what I've done... pick up a pair at the Salvation Army/Goodwill/thrift store and take them apart. -
Can you post a photo so we can have a better understanding of the problem? Otherwise it is hard to imagine the root of the problem, i.e., rivet too long, etc.
If what you mean is "firm", then you might try the Hide House in Napa. They carry what they call California Latigo, and it is very firm, pretty much water proof, and oil tanned. Comes in a variety of colors (although mostly deep, rich colors) and weights. https://hidehouse.com/
