Everything posted by alpha2
Clever but easy
alpha2 replied to AndrewWR's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
"leather lock"...Ha! Now I know what the name of my affliction is!!! Nice to see you blew past it. Nice case. Jeff- 24 replies
- pencil case
- great for carvers
(and 1 more)
New rifle scabbard
alpha2 replied to JKHelms's topic in Gun Holsters, Rifle Slings and Knife Sheathes
I've thought of doing one for my Henry Golden Boy, but it would have to fully cover the stock. It's pristine, and I have my old Marlin 39A Golden for banging around. And THAT one is my most accurate .22 rifle. Also interested in if it's lined, and how, if so. Jeff Hey, wait! What? Battlemunky has changed his avatar!!! What's next? Dogs and cats, living together??? -
P320 Carry and P320 Compact
alpha2 replied to JLSleather's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Pythons can be ornery critters. Even in death. Full disclosure, I don't form well, either. Holsters are fine, as per usual. the other Jeff -
I haven't tried it, but with some paints, an under coat of white will lighten the top coat.
How about instead of dying it blue, you use acrylic paint in blue or turquoise? Maybe even white coat first, then the blue, for even lighter blue? Jeff
My first shot at carving and tooling...UGH!
alpha2 replied to StarcrossedReed's topic in Figure Carving
Hey, we all have to start somewhere! The important thing, is to start. I look back on my early stuff, and some of my later stuff, and shudder. Your ain't so bad! Jeff -
Money Clip Wallet
alpha2 replied to Bob Blea's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Looking good, Bob. Different design. I like different. Jeff- 10 replies
If you're ever going to do more than one of these, get the splitter from Tandy, or others. It's 6" wide and will do just what you need. It's also handy for just about anything you'll ever want to adjust the thickness of strap goods. I don't know where you'd get a razor blade that would do 2 1/2" wide strip, but a box cutter with the break-off blades would have the right blade for what you are thinking of. Jeff
You guys are killing me! I barely have room for my Cowboy 4500, and now you have me craving multiple machines! I'm all about fixing and reconditioning stuff. I just have to say NO! I think. Mostly. Jeff
Phone Cases
alpha2 replied to KornelKobak's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
nice work! -
Etsy has some tips on their web page. I'd go there first. There's tips there from sellers that are getting good images with just a cel phone. Jeff
- 5 replies
- photo
- photo projects
(and 1 more)
Next she'll want to vote, you to nip this in the bud. Nice work, as always. When do you find time for school? Jeff
- 12 replies
- spur straps
- breast collar
(and 4 more)
Streaky Dye
alpha2 replied to superpacker's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Don't just go over the lighter areas. I have never had the results I expected when I've done that. I have had luck with going over the whole thing with neatsfoot oil, however. Seemed to blend thing better, but it will darken it, also. Not as much as another coat of dye, though. Jeff -
If you just need a few Chicago screws, Ace hardware stocks them. Jeff
I try to skive my leather so that it is the best thickness for the application. But, when I try to select a snap, or rivet length, they are always too short, or too long. I know that brass and copper rivets with the burr, I can cut it properly. But it seems that all the "factory" length ones are just wrong, as opposed to just right. Is there a source of "in between" sizes? Jeff
Probably doesn't help this particular issue, but I have different burnishers for "raw", "clean" leather, and dyed leather. Also, I can't imagine that cocobolo in the amounts we're talking about, is particularly toxic. PPM, and all that. It's not like you'll be doing it commercially for years. Jeff
I did not know that chaps had pockets! Add that to the long list of things that I didn't know about chaps. Beautiful work, as usual. Don't you just LOVE dyeing background? Jeff
I don't know how tight it is, but I'd try spinning it in. That is, chuck an end in a drill and slowly spin it while trying to insert it. If it's really still a tight fit, maybe take it all the way out, lube it and try again? Then find a way to crimp the end shut to preclude it happening again. Jeff
Safely clears the mag release, and plenty of grip available! I'd say you have a winner there. Lonestar state bit is icing on the cake. Jeff
Whatever you end up using, it needs to be buffed well afterwards. Just about anything grain side will buff up nicely.
Where to find pins with custom logo with a rivet back closure?
alpha2 replied to Frankzweekhorst's topic in Suppliers
Sorry, misunderstood.
