rickdroid
Hand sewing tip for people with arthritis
I have arthritis and hand sewing can get painful at times.  The problem is having to grip the needle hard enough to be able to pull the needle through several layers of leather or, sewing some really tough leather.  I have been using nitrile gloves (the same ones I use for dying leather) to give me some extra grip on the needle.  Problem is they make your hands sweaty and are pretty uncomfortable for a long sewing session.
A few days ago i came across a container of  'fingertip moistener',  trade name "Tacky Finger" that is normally used by people who have to handle lots of paperwork.  'Tacky Finger' is used instead of having to continually wet your fingers when sorting through reams of paperwork.  I used to use the stuff and remembered that it did make my fingers feel tacky so i thought that i would try it to see if it was of any help - and it worked very well.  It makes my fingers tacky enough to be able to grip the needles without feeling like i have to squeeze them in half.  The grip is pretty close to what i got with the nitrile gloves but didn't cause any problems handling the thread.
Thought this tip might be of use to some of you.
JD62
:You_Rock_Emoticon: "Thanks!"
Edited by JD62
3 hours ago, electrathon said:
http://www.michaels.com/bead-landing-mini-flat-nose-pliers/10443467.html#q=pliers&start=8
You might try these.  if my holes are tight I use them to pull, or push, the needle.
I've got a pair or those and occasionally need to user them but they really slow me down.  The Tacky Finger allows me to work at a pace closer to people who don't have arthritis.  Saves me a lot of time and a fair amount of pain.
I just thought that some others might find the information helpful.
480volt
I started waxing my thread with shoemaker's wax, and I find it makes a huge difference in gripping the needles.
JD62
Hmm wish I could find needles for that thread!
JLD
Great tip thank you :)
:lol:
Imagine the size of the cow the leather came off.:cow:
Great tip and I was just daydreaming about sometime like this today!! and here I find the answer. I have a bad thumb....
one question or concern is.. if it gets on the leather from handling before it is finished how does it affect the leather taking colour etc.?
Currently I use the vinyl gloves And needle nose when needed AND I have a plug of bees wax on the side of my horse and pony jaws and I 'dip" my awl in it ever hole or two so the wholes are waxed and the needles pick some up along the way.
shoe makers wax on the thread would likely act the same way and I will look into it
I am about to experiment with finger cots to avoid the sweaty hand action:
http://www.ebay.ca/itm/100Pc-Orange-Natural-Latex-Rubber-Finger-Cots-Sleeve-Textured-End-Tacky-Multiuse-/131813555791?hash=item1eb0b33e4f:g:fS4AAOSwInxXNpKq
I can t find Tacky Finger in Canada but seem that SortKwik is essentially the same thing and available at staples.
I have never noticed any reaction between veg-tan and Tacky Finger or SortKwik but as always Test Test Test.
I have used both Tacky Finger. and Sort Kwik or a similar spelling without any problem.
Thanks
rick
Thanks Rick. I will pick SortKwik up today as I hope to get some bench time on my holiday this next few weeks.
I have carpal tunnel syndrome and it gets painful to sew...
A saddle maker told me to pull the needle through the leather with a piece of bees was each time the needle was tight, my fingers took on some of the wax each time and now I never have to use a plyers when sewing. It was the best piece of advise I have received so far in leather working.
Deuce
Thanks for the Tip! Anything to cut down on my hand pain ....
For what it's worth, I often use a sailmakers palm to help push the needles through tough or thick leather. For those who aren't familiar with this tool, it's worn on your hand and has a hard, textured plate to protect your hand when pushing the needle, almost like a flattened thimble. Once you get used to it, it's quite comfortable.
All the best, Mike
Well I just did my first 7 hours of stitching in the last 12 months... from 2 layers of 4oz through to 3 layers of 10-11 and that SortKwik is amazing stuff. Thanks for the tip. Much nicer not wearing vinyl gloves.
I will say that after a year away from riding the stitching horse I was very much beginners again and did not really come back up to speed and accuracy until last piece... oh well good to have gotten some hobby time.
Edited by plinkercases
Create an account
Register a new account
Sign in
Sign In Now
