bikermutt07
Horween CXL Question
Today I started on a new wallet with the burgundy horse strip. Got a nice straight edge on it and ran my Tandy original strap cutter. I cut my pattern length and two card pocket pieces.
I went to split the pieces down to about 3.5 ounces on my weaver 8 inch skiver splitter. Even though it was tough the main body went thru ok. But the 2 card pockets stretched all kinds on crazy.
So, my question is, will these pieces return to their cut dimensions after a day or so?
I haven't had much stretching with veg tan pulling thru it.
I have $23k band knife splitter and CXL  still stretches some for me... I can't imagine a "pull-splitter".   Make oversized pieces, split first, then cut your pockets.
Well, they are over sized now....Ha!
It was a little brutal.
Update: It wasn't fun but I was able to split it. This was only 4ounce horse strip and I was able to split it to 2 ounces.
I took the long 4" ish strap I cut for my wallets and worked it upside down. This put all the stress onto the flesh side of the piece. Now I have a strip about 24" to use for some wallets. Yay!
YinTx
A 4" piece stretched to 24"??!!?  That is some stretch!  and apparently a way to increase your yields!
YinTx
YinTx
If that's correct CXL just got 6x cheaper for OP...
Haha, no. It is still 4" wide.
Create an account
Register a new account
Sign in
Sign In Now
